Old 01-11-2013, 09:56 AM   #15
Dustin@Dynosty
10lbs lighter
Dustin@Dynosty is offline   Reply With Quote
The Following User Says Thank You to Dustin@Dynosty For This Useful Post:
Pete (01-11-2013)
Old 01-11-2013, 10:28 AM   #16
Pete
Pete's Avatar
Drives: 22 BRZ
Am I blind or do they not have the drive shaft listed on the site? I see the axles....
Pete is offline   Reply With Quote
Old 01-11-2013, 01:06 PM   #17
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Dustin@Dynosty View Post
10lbs lighter
Any idea how much lighter the aluminum shaft will be?
Old 01-11-2013, 01:20 PM   #18
Dustin@Dynosty
im sorry i should of clarified, the aluminum shaft is 3.5" diameter and is 10lbs lighter, the CF shaft will be in the same range of weight decrease though
Old 01-11-2013, 02:30 PM   #19
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
If a driveshaft breaks under a hard launch, I'd rather have the carbon fiber one under there (:
tech4pdx is offline   Reply With Quote
Old 01-11-2013, 02:53 PM   #20
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Diff.
We have heavy duty diffs available?
Tansey86 is offline   Reply With Quote
Old 01-11-2013, 03:03 PM   #21
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
umm toyota is developing a mechanical diff (probably trd)?
could a supra rear diff be equipped?
im sure someone has a rear diff you can buy that is better
its been soo long, is the rear diff out of an is250? if it is im sure you can find an aftermarket solution through the lexus is forums
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 01-11-2013, 03:52 PM   #22
Dustin@Dynosty
will have a new post up shortly with the install pics and official pricing details
illmatic (02-22-2013)
Old 01-11-2013, 03:56 PM   #23
OrbitalEllipses
Drives: Attitude
Aroominum?
Calum (01-11-2013)
Old 01-11-2013, 04:12 PM   #24
Calum
That Guy
That's one sexy shaft you have there.
The Following User Says Thank You to Calum For This Useful Post:
RWD_FR-S (02-23-2013)
Old 01-11-2013, 04:14 PM   #25
Pete
Pete's Avatar
Drives: 22 BRZ
Are you considering putting that shaft in your undercarriage?
The Following User Says Thank You to Pete For This Useful Post:
Calum (01-11-2013)
Old 01-11-2013, 04:16 PM   #26
OrbitalEllipses
Drives: Attitude
He'd have to make sure to properly lubricate it first.
Calum (01-11-2013)
Old 01-11-2013, 04:55 PM   #27
Calum
That Guy
And make sure all fasteners are sufficiently tight.
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 11:42 AM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 12:40 AM
Custom Audio Shop LPC_FRS Mid-Atlantic 0 09-17-2012 07:42 PM
Custom Audio Shop LPC_FRS Mid-Atlantic 0 09-17-2012 06:11 PM
