#16 |
Drives: 22 BRZ
Am I blind or do they not have the drive shaft listed on the site? I see the axles....
#17 |
That Guy
Drives: 2013 asphalt FRS MT
#18 |
im sorry i should of clarified, the aluminum shaft is 3.5" diameter and is 10lbs lighter, the CF shaft will be in the same range of weight decrease though
#19 |
Make love
Drives: H8R.. Not really
If a driveshaft breaks under a hard launch, I'd rather have the carbon fiber one under there (:
#20 |
Drives: 2003 Subaru Outback
#21 |
Reverse Burnouts
Drives: 2013 Argento FRS
umm toyota is developing a mechanical diff (probably trd)?
could a supra rear diff be equipped? im sure someone has a rear diff you can buy that is better its been soo long, is the rear diff out of an is250? if it is im sure you can find an aftermarket solution through the lexus is forums
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#24 |
That Guy
That's one sexy shaft you have there.
| The Following User Says Thank You to Calum For This Useful Post: | RWD_FR-S (02-23-2013) |
#27 |
That Guy
And make sure all fasteners are sufficiently tight.
| FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! | Diode Dynamics | Interior Parts (Incl. Lighting) | 155 | 11-19-2014 11:42 AM |
| Automatic Carbon Fiber Driveshaft? Yes! | RallySport Direct | Engine, Exhaust, Transmission | 13 | 12-15-2012 12:40 AM |
| Custom Audio Shop | LPC_FRS | Mid-Atlantic | 0 | 09-17-2012 07:42 PM |
| Custom Audio Shop | LPC_FRS | Mid-Atlantic | 0 | 09-17-2012 06:11 PM |
