Old 01-11-2013, 02:54 AM   #869
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
While I like this kit, I prefer air-to-air intercoolers on the street simply because there's less to go wrong. AWICs can cool very well, I've just always been wary of that scenario where I need to fill some water and I don't have any, thus stranding me.
Though trying to get a blown coupler reaffixed onto an air-to-air IC charge pipe on the side of the highway is no better AND I've actually been in that situation.
Boost is controlled with your foot. You wouldn't be stranded... just have to drive slow and stay out of boost. Alternatively, have your non-cooled program selectable in EcuTec.
Jeff86 is offline
The Following User Says Thank You to Jeff86 For This Useful Post:
gosaints420 (01-11-2013)
Old 01-11-2013, 03:35 AM   #870
Noob4Life
86 Noob
Drives: Firestorm FR-S
X2 most of the heat comes from boosted air. If youre not boosting youll be fine without water
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline
Old 01-11-2013, 04:48 AM   #871
OrbitalEllipses
Drives: Attitude
It's just not something I want to risk right now. My coupler blowing off the charge pipe stranded me for 30 minutes because the car stalled from running that rich and I had to wait for engine bay temps to SLIGHTLY drop so I could finangle the coupler into place. Luckily I was on my way to a shop anyway.
Forced induction is just mental masturbation for me; I can't afford a non-warranty replacement of critical/expensive components.
OrbitalEllipses is offline
Old 01-11-2013, 07:35 AM   #872
2forme
Don't mental masturbate too much, or it will mentally fall off.
2forme is offline
Old 01-11-2013, 08:20 AM   #873
Opposed
Drives: 2013 Asphalt FR-S
And you could mentally go blind...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 01-11-2013, 08:41 AM   #874
Calum
That Guy
Drives: 2013 asphalt FRS MT
Maybe that's where the band name Third Eye Blind came from.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
Sportsguy83 (01-11-2013)
Old 01-11-2013, 08:50 AM   #875
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
Anyone know if it'll be possible to have a stage 1 with the intercooler? I only want to run about 5psi anyway.
BoostedWrbBrz is offline
Old 01-11-2013, 09:11 AM   #876
cruzinbill
Drives: Argento 6spd FR-S
They said you can order it for the stage one.
cruzinbill is offline
The Following User Says Thank You to cruzinbill For This Useful Post:
drifter (01-11-2013)
Old 01-11-2013, 10:41 AM   #877
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
If they're setting up the Stages by heat output of the supercharger, Stage 1 will run less boost, and thus less heat. Stage 2 would run more boost, thus more heat, which would be counteracted by the Laminova.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline
Old 01-11-2013, 10:49 AM   #878
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
How much boost were you running? Bead rolled pipe with a properly sized silicone coupler and T clamps properly tightened? With those three things and a mere 10 psi, I don't think anyone going the turbo route needs to worry about blowing off any couplers.
King Tut is offline
Old 01-11-2013, 11:37 AM   #879
Noob4Life
86 Noob
X2. Ive blown hoses off but it wasnt bead rolled and im pushing 22psi. Your pipe must not have been installed properly.
Old 01-11-2013, 12:48 PM   #880
OrbitalEllipses
Drives: Attitude
14 psi. I didn't tighten it well enough the night before. Purely my fault, but a PITA nonetheless.
Old 01-11-2013, 01:43 PM   #881
RYU
RYU's Avatar
Drives: really slow...
The Laminova is a restrictive intercooler. It might drop your PSI by 1psi or so.
Then you have to consider the lost power from heat soak/high boost pressure vs. cool air/low boost pressure. Pros/Cons both way. It is certainly possible to create more power at lower boost pressure though. It all depends on the conditions
5lbs with no intercooler on the street should be fine. Your IATs shouldn't really go up further than 130-160F (which is rather high but not crazy high). It's when you're on the track that this kit might reach dangerous levels where an intercooler is needed.
A great alternative to cool for the twin screw is to place meth/water mist sprayers/injectors after the supercharger and directly into the pressured air. No one here has mentioned this here I don't think. There are a lot of room in the intake runners which is a plus for this kit.
RYU is offline
Old 01-11-2013, 02:31 PM   #882
Unleashed
Unleashed's Avatar
Drives: 13' WRX
[quote/]
A great alternative to cool for the twin screw is to place meth/water mist sprayers/injectors after the supercharger and directly into the pressured air. No one here has mentioned this here I don't think. There are a lot of room in the intake runners which is a plus for this kit.[/quote]
There was a frs at SEMA running nitrous and it used the intake runners by just drilling into them to place the injectors, so this is a totally feasible idea and one I might look at, concourse using meth/water like mentioned not nitrous lol
Unleashed is offline
The Following User Says Thank You to Unleashed For This Useful Post:
Calum (01-11-2013)
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
