Old 01-10-2013, 01:46 AM   #2045
nix
nix's Avatar
Drives: AVO BRZ
8 laps is not that much with Japans ambient temps. It's 85+ F here being mid summer. I guess we will do a new radiator, fans and shrouding for my car if necessary as well as oil cooler.
nix is offline   Reply With Quote
Old 01-10-2013, 06:41 AM   #2046
ashmostro
Drives: TBD
My thoughts exactly.
ashmostro is offline   Reply With Quote
Old 01-10-2013, 09:08 AM   #2047
RYU
RYU's Avatar
Drives: really slow...
Originally Posted by AVOturboworld View Post
Technically, we do have a form of a post-turbo oil cooler. At least, in regards to the oil that flows through the turbo itself. The oil is pulled (not pushed) through the turbo into an oil reservoir tank, and then runs through quit a bit of tubing before it gets back into the engine. It's completely possible that the oil is the same heat it was at before it went into the turbo by that time.
We've also discussed secondary oil cooling, and may implement that in the near future. One of many projects to tackle.
would it make sense to plumb in-line somewhere on the feed or return oil supply line (for the turbo) an oil cooler? Seems like the plumbing is already there but not sure if the diameter is at least AN8 and the pressure.
I would love that idea so no oil filter sandwich plate is needed.
I'm a supercharger guy and the fight against heat (at the track) always seems a bit more challenging than my turbo counterparts. Pros and cons because they sometimes overboost too- just to keep things partial..
RYU is offline   Reply With Quote
Old 01-10-2013, 09:15 AM   #2048
ashmostro
Drives: TBD
I'm thinking with the way the turbo plumbing is done, the flow going through those lines may be a parallel circuit, not series... so it's not 100% of the flow. Oil cooler there wouldn't be as effective. I think a sandwich plate adapter is still probably the best option for performance benefit. Plus you'd want a thermostatic one for street use (which would yet again be difficult with the inline approach).
AVO, correct me if I'm wrong here.
Old 01-10-2013, 09:39 AM   #2049
ft_sjo
Drives: GT86
Has the turbo oil temperature been monitored? If so what were the results please?
Old 01-10-2013, 09:51 AM   #2050
Pete
Pete's Avatar
Drives: 22 BRZ
Sweet car, the front end looks slick.
Pete is offline   Reply With Quote
Old 01-10-2013, 10:03 AM   #2051
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Originally Posted by Tansey86 View Post
Are we limited to only AVO made turbos for this kit? If not can share what lineup we could use if we had to replace one?
This is a really good question since the stock turbo is journal bearing. A ball bearing turbo that requires significantly less oiling could be a real benefit. Can something like a GT28RS be fitted easily on this kit?
Jeff86 is offline   Reply With Quote
The Following User Says Thank You to Jeff86 For This Useful Post:
Tansey86 (01-10-2013)
Old 01-10-2013, 11:00 AM   #2052
wcbjr
Drives: 2006 Subaru LGT
There any list of suspension/wheel/tire specs to this particular vehicle? I am wanting to offload my 2006 LGT and will be looking to create something like this.
wcbjr is offline   Reply With Quote
Old 01-10-2013, 11:35 AM   #2053
AVOturboworld
The car has been at the track throughout the summer/fall/winter - and Tokyo hits 90+ F, plus has that pesky 90-100% humidity going for it as well. One of the reasons I decided to leave Japan after 15+ years there was the summer heat.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
nix (01-10-2013), zohare (01-17-2013)
Old 01-10-2013, 11:41 AM   #2054
FasterpromsFRS
FasterpromsFRS's Avatar
Drives: FRS
Off topic, but I agree. Standing at the train station in 90+ sun is no fun.
FasterpromsFRS is offline   Reply With Quote
Old 01-10-2013, 11:36 PM   #2055
Cal3000
Drives: Panda FR-S
It can't really be a benefit. Remember the turbo is turning at really high speeds. With ball bearings you are just setting yourself up with an earlier failure in the bearings. So much heat will be generated, it isn't practical. Journal bearing is a better way to go.
Cal3000 is offline   Reply With Quote
Old 01-10-2013, 11:50 PM   #2056
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Running a non-avo turbo could benefitial. And or some people may have turbos lying around that they may want to use instead of spending money to upgrade.
Tansey86 is offline   Reply With Quote
Old 01-11-2013, 03:06 AM   #2057
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
It's just as easy to end up with shaft play on a journal bearing turbo and need a rebuild. I switched from one to a GT turbo for exactly that reason when it came time to rebuild my old turbo. i've now had years of reliable service from my GT3076R and it spools faster too.
Old 01-11-2013, 03:17 PM   #2058
Klar
Drives: 2013 FR-S Whiteout
http://www.turbobygarrett.com/turbob..._ball_bearings
Read up.
Klar is offline   Reply With Quote
The Following User Says Thank You to Klar For This Useful Post:
Alienate (01-12-2013)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
