Old 12-11-2012, 02:12 PM   #85
djdnz
1337
Drives: 2013 BRZ WRB S/C
Oh my knee HATES the stock plastic ones, but I am saying that I expected more from the JDM ones. They look comfier in pictures. They are better than stock, but I don't know if they are as good as they cost. I imagine someone like JPM could make them better EASILY.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
Surok (12-17-2012)
Old 12-11-2012, 05:47 PM   #86
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
definitely gonna do all this.... but I may wait since I'm going to Japan next year. These 4 panels... the clear signal/marker lights... maybe even the frameless mirror. Get it duty free maybe, lol... it's not so much about the savings as actually buying it from Japan!
sbxjap is offline   Reply With Quote
Old 12-17-2012, 10:35 PM   #87
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
my knee hits right on the stitching so its actually not very comfortable.
and maybe they should be padded a bit more..
Surok is offline   Reply With Quote
Old 12-17-2012, 11:05 PM   #88
joop1987
Drives: 2013 FRS, Raven, Auto
It's pretty easy to change the foam inside the knee pads. The cover is easily removeable. Use the stock foam and trace it on the new foam. The stock foam is a soft sponge material.
joop1987 is offline   Reply With Quote
Old 12-20-2012, 11:15 AM   #89
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
How to remove the bottom tray/USB/AUX/Start Button panel without scratching it.
I did a bunch of searching on this but this technique was the one that I finally used. This is from this thread and I'll quote the relevant portions of the post in here. Thanks to Lil Abner who originally posted this, and I hope he doesn't mind me quoting his excellent post. If you do, feel free to PM me and I'll remove the quotes.
http://www.ft86club.com/forums/showthread.php?t=8336
Originally Posted by Lil Abner View Post
Remove panels (one on each side). Pull straight out (towards the outside of the car)
Reach around, and push the USB/Aux plug out. Then unplug.
Pull panel out
Remove 2 screws
Basically after you remove the bottom panels you can get in behind the USB/Aux switch and push it out and unplug it, then push the harness back into the hole and use the hole for the switch to stick your finger through and pull. Worked well for me and no scratches... and I have a BRZ Limited with the push button start, so some of the other prying solutions don't really work well.
Thanks again to Lil Abner for this most informative post. I suggest following The Original Post By Lil Abner and reading the rest of his DIY since it includes almost all the steps required to replace the knee pads.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
The Following 2 Users Say Thank You to WolfSongX For This Useful Post:
DoomsdayJesus (08-28-2013), tiz22 (09-13-2013)
Old 12-20-2012, 01:28 PM   #90
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I used the same technique on my BRZ Limited this weekend to remove the shifter and it worked great.
Old 01-10-2013, 08:41 PM   #91
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
stoked to have found this! thanks for a great write up!
tuckdaddy is offline   Reply With Quote
Old 01-11-2013, 10:14 PM   #92
Grayian
Drives: 2013 BRZ Ltd MT SWP
I thought the USB/Start button removal too tough using just a finger in the USB hole. Getting a long flathead and pushing from behind helped a lot.
The scariest part was the door handles when removing the door panels. There is a tiny indentation below the handle, look on the bottom of it. Pry there, then once the bottom half is out, it feels like you will break if if you inch it out going higher. I decided to just yank it up and out and it comes out. I wouldnt try to pop the top out since it isn't snapped in like the bottom is.
Grayian is offline   Reply With Quote
Old 02-28-2013, 09:35 AM   #93
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Just got mine in. Can't wait to tackle this!
Old 02-28-2013, 10:32 AM   #94
OrbitalEllipses
Drives: Attitude
Ricer.
Old 02-28-2013, 11:42 AM   #95
DKPJester
DKPJester's Avatar
Drives: 2013 Whiteout FR-S
Ricer.
Troll.
But once again we must turn to the baby Jesus who once said "He who shall be last, shall be sideways and smiling."
DKPJester is offline   Reply With Quote
Old 02-28-2013, 11:47 AM   #96
OrbitalEllipses
Drives: Attitude
Originally Posted by DKPJester View Post
Troll.
Chano and I are good internet buddies so I can call him a ricer. But who the f*% are you?
Go play somewhere else.
Old 02-28-2013, 11:56 AM   #97
DKPJester
DKPJester's Avatar
Sorry! I thought you were just randomly being a ****. Looking back through the thread it should have been more obvious that you were just messing with him. :happy0180:
Old 02-28-2013, 12:05 PM   #98
OrbitalEllipses
Drives: Attitude
Naw, we cool.
Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR nigel-jdmparts Interior Parts (Incl. Lighting) 89 02-01-2013 04:00 PM
HID Retrofit Kit install Jidonsu NY / NJ / CT / PA 1 08-04-2012 01:24 AM
How do you install the mud guards? Moshpit37 Scion FR-S / Toyota 86 GT86 General Forum 11 07-27-2012 11:13 PM
FS: console knee foam pads 86_ZN6 Interior Parts (Incl. Lighting) 9 07-21-2012 09:46 AM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 10:43 AM
