Old 01-05-2013, 11:12 AM   #771
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Originally Posted by RoryTate View Post
Blatantly stolen from an Outback forum:
I've had my FRS for a few weeks. My idle was dipping near stall then bouncing up to 1000 or so then settling back down. Turns out it was the A/C compressor cycling from these dial settings. Put it to another setting and it never skipped a beat.
Thanks for the post!
FRSFirestorm is offline   Reply With Quote
Old 01-05-2013, 01:30 PM   #772
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Doesn't it mean it will have idle dip if you turn on the AC?
Old 01-06-2013, 09:22 AM   #773
FRSFirestorm
Red is Fastest
I'd say it will.
I have some experience with tuning GM LS series engines. There appears to be a hole in the tuning for A/C cycling in this Subaru platform. Tweaking routines in the GM tune you could really minimize the effect of A/C compressor kick at idle.
The Following User Says Thank You to FRSFirestorm For This Useful Post:
Sigh-on-Rice (01-06-2013)
Old 01-06-2013, 03:52 PM   #774
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I'd say it will.
My tC had a similar but much worse idle dip than my BRZ, with or without the A/C on. I'll bet Toyota had a hand in the idle programming of these cars.
Subie is offline   Reply With Quote
The Following User Says Thank You to Subie For This Useful Post:
Old 01-07-2013, 07:30 PM   #775
jesseps
Drives: Scion FR-S
My car started to rough idle this morning and it smelling really bad.
Thing is I put in the right gas in the car. I am actually scared to drive the car to the dealership. I guess I will have the car towed there.
jesseps is offline   Reply With Quote
Old 01-10-2013, 12:29 AM   #776
Wankel Rex
Wankel Rex's Avatar
Drives: Silver Premium Edition BRZ
I've been having inconsistent idle the past two days. Tonight I noticed something cycling on and off in conjunction with the idle changes. Sure enough, I had the fan set to a mix between floor and defrost as it's been raining for the past two days.
Switched to floor only, idle issue stopped.
Wankel Rex is offline   Reply With Quote
Old 01-10-2013, 12:40 PM   #777
Sigh-on-Rice
To me, there shouldn't be idle issue regardless of the compressor on or off.
How low does your idle RPM drop to with the compressor on?
Does it drop to like 400 and the car shudders?
Old 01-10-2013, 12:44 PM   #778
whtchocla7e
Drives: 2013 FR-S Hot Lava
I've mentioned it before many times that my idle drop only happens when the compresor is running. Nobody seemed to care. At least now there's another person who confirms it.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 01-10-2013, 01:03 PM   #779
Sigh-on-Rice
Mine happens only when the compressor is running too. But what gets me is that it only happens a few times a month. Idle drops every 15 seconds or so when the compressor turn on and off, and low enough for it to shudder a bit. It keeps doing that until I turn the engine off and turn it back on. Other than those few times a month, the idle is stable even with the compressor running. It's weird.
Old 01-10-2013, 10:13 PM   #780
Wankel Rex
Wankel Rex's Avatar
It normally idles at roughly 650 RPM, drops to 500 or so as the compressor kicks on. Same thing happens if you press both power window switches; dips for a second then compensates for the added load.
I wouldn't say it shudders, but it gets a little rough when it dips. I can feel it mainly if I'm resting my hand on the shifter (which I usually am when stopped at a light).
Old 01-22-2013, 02:06 PM   #781
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
Mine idles roughly around 600 as well. Not much shuttering though. Is it safe to assume 600rpm idling is ok?
EK_Golfer is offline   Reply With Quote
Old 01-22-2013, 03:06 PM   #782
Sigh-on-Rice
My manual trans idles at 600 without A/C and 650 with A/C.
I heard automatic trans idles a little bit higher.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
EK_Golfer (01-23-2013)
Old 01-28-2013, 02:44 PM   #783
Craig
Craig's Avatar
Drives: Asphalt FRS
My car just starting exhibiting some strange idling issues. I've got an AT, when sitting in park with heat off / dials not set like @FRSFirestorm said, and RPM goes from 600 (normal) drops to ~350 then shoots up to ~750, then dips to 600.
Goin in for my free oil change/crickets/odds and ends, i'll be sure to bring this up if it continues.
Craig is offline   Reply With Quote
Old 01-29-2013, 04:54 AM   #784
atledreier
Drives: GT86 DGM
Mine had a weird idle dip yesterday as well. No CEL as of yet, but I guess it's only a matter of time now...
GT86, Norway, 3500km, MT, VIN 009099
atledreier is offline   Reply With Quote
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2012 11:38 PM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 01:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 12:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 12:58 AM
