#771 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
I've had my FRS for a few weeks. My idle was dipping near stall then bouncing up to 1000 or so then settling back down. Turns out it was the A/C compressor cycling from these dial settings. Put it to another setting and it never skipped a beat.
Thanks for the post! |
#772 | |
Waited 5 years for this
Drives: '18 MX-5 Club
#773 | |
Red is Fastest
I have some experience with tuning GM LS series engines. There appears to be a hole in the tuning for A/C cycling in this Subaru platform. Tweaking routines in the GM tune you could really minimize the effect of A/C compressor kick at idle. |
#774 |
Señor Member
Drives: 2013 SSM DZE BRZ
My tC had a similar but much worse idle dip than my BRZ, with or without the A/C on. I'll bet Toyota had a hand in the idle programming of these cars.
#775 |
Drives: Scion FR-S
My car started to rough idle this morning and it smelling really bad.
Thing is I put in the right gas in the car. I am actually scared to drive the car to the dealership. I guess I will have the car towed there. |
#776 |
Drives: Silver Premium Edition BRZ
I've been having inconsistent idle the past two days. Tonight I noticed something cycling on and off in conjunction with the idle changes. Sure enough, I had the fan set to a mix between floor and defrost as it's been raining for the past two days.
Switched to floor only, idle issue stopped. |
#777 | |
How low does your idle RPM drop to with the compressor on? Does it drop to like 400 and the car shudders? |
#778 |
Drives: 2013 FR-S Hot Lava
I've mentioned it before many times that my idle drop only happens when the compresor is running. Nobody seemed to care.
At least now there's another person who confirms it.
Live to drive another day
#779 | |
#780 |
It normally idles at roughly 650 RPM, drops to 500 or so as the compressor kicks on. Same thing happens if you press both power window switches; dips for a second then compensates for the added load.
I wouldn't say it shudders, but it gets a little rough when it dips. I can feel it mainly if I'm resting my hand on the shifter (which I usually am when stopped at a light). |
#781 |
Drives: 2013 Whiteout FR-S AT
Mine idles roughly around 600 as well. Not much shuttering though. Is it safe to assume 600rpm idling is ok?
#782 |
#783 |
Drives: Asphalt FRS
My car just starting exhibiting some strange idling issues. I've got an AT, when sitting in park with heat off / dials not set like @FRSFirestorm said, and RPM goes from 600 (normal) drops to ~350 then shoots up to ~750, then dips to 600.
Goin in for my free oil change/crickets/odds and ends, i'll be sure to bring this up if it continues. |
#784 |
Drives: GT86 DGM
Mine had a weird idle dip yesterday as well. No CEL as of yet, but I guess it's only a matter of time now...
![]() GT86, Norway, 3500km, MT, VIN 009099 |
| A Small Easter Egg | avusblue | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 06-28-2012 11:38 PM |
| Subaru BRZ - The biggest small car ever | Laika | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 06-09-2012 01:21 AM |
| Received my FR-S with a small ding | Neurytic | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-03-2012 12:53 PM |
| Isn't 6-10 miles on a new car kinda high? | houseofsuffering | BRZ First-Gen (2012+) — General Topics | 45 | 05-15-2012 12:32 PM |
| Kinda make me worry! (Radiation related thing) | EJ20 | Off-Topic Lounge [WARNING: NO POLITICS] | 32 | 05-09-2011 12:58 AM |
