Old 01-10-2013, 01:54 AM   #1
madcap
Drives: 2013 Hot Lava FR-S
Wheel Directory: Axis X-Factor 18x8.5 +45
Fitted. Love it. Pretty flush in the front and almost in the rear.
madcap is offline   Reply With Quote
The Following 3 Users Say Thank You to madcap For This Useful Post:
ayilar (08-12-2014), killboy (03-03-2015), red_comet (06-14-2013)
Old 01-10-2013, 10:29 AM   #2
madcap
A couple of more pictures since I had a little let up of rain this morning before work. I'll still get some more if the Sun ever shines again.
Old 01-10-2013, 10:49 AM   #3
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
are you lowered?
Got3n is offline   Reply With Quote
Old 01-10-2013, 10:51 AM   #4
madcap
Originally Posted by Got3n View Post
are you lowered?
No, it will be eventually. I've only owned the car 62 hours now.
Old 01-10-2013, 10:55 AM   #5
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
Ah ok, was asking cause im getting 8.5's all around and need to decide on 225/40/18 or 245/35/18 for my tires. Just afraid to go with 35's cause of bumps and what not :-/, Also that looks really nice on stock suspension, i dont mind that gap at all.
Old 01-10-2013, 11:06 AM   #6
madcap
I don't see lowering the rear being any issue at all. The front is slightly more flush but I still don't think lowering an inch would be a problem.
I do notice the bigger wheel and thinner tire being slightly less forgiving than stock but I don't mind it.
Old 01-10-2013, 11:16 AM   #7
madcap
check out http://www.1010tires.com/tiresizecalculator.asp
245/35R18 is closer to stock diameter so your speedo will be a bit more accurate. Also, the difference in overall diameter between 225/40R18 and 245/35R18 is only about a quarter of an inch, so an eightth of an inch on each side of center. I don't see that making a huge difference in ride between the two.
Old 02-21-2013, 11:39 AM   #8
zooplane
Drives: SSM BRZ
Originally Posted by madcap View Post
Fitted. Love it. Pretty flush in the front and almost in the rear. More pictures to come if sunlight ever shows up in Louisiana again. I've had the car 53 hours and it's been raining for around 40 of that.
Dying to get these wheels!! Could you PM me some more pics of your set up from all angles?? Back and front as well!!
THANKS!!
zooplane is offline   Reply With Quote
Old 02-22-2013, 06:33 AM   #9
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
They look sweet. Contrast is nice. Axis rims are notoriously heavy though. You also appear to have added a heavier tire. Do you know the overall weight gain ?
miodculae is offline   Reply With Quote
Old 02-28-2013, 10:02 PM   #10
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 03-12-2013, 03:38 PM   #11
madcap
I'm sure it's around 5 pounds total added per corner. The rims are 23.1lbs each. I knew that going in and was willing to accept it for the look I wanted. I've kept the stock wheels and will either use them or some lightweight forged wheels for autocross applications in the future with sticky tires mounted to them.
Old 03-12-2013, 03:40 PM   #12
madcap
THANKS!!
I've been meaning to do an amateur photoshoot one day. I'll post more pics here when I do.
Old 03-24-2013, 01:03 AM   #13
zooplane
Drives: SSM BRZ
Anything?? Thanks!!
Old 03-30-2013, 04:57 PM   #14
madcap
Updated with a few more pictures in original post.
Wheel Directory: WedsSport TC105N 18x8.0 +42 King Tut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 12-20-2015 08:58 AM
Wheel Directory: TSW Interlagos 18x8.0 +35 denkigrve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 03-19-2014 03:01 PM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
FS: FL set of 18x8(45) RPF1 5x100 with tires Scooby South Wheels and Tires 2 01-08-2013 10:35 AM
The Forester factor: an unexpected reason for limited BRZ / FR-S / 86 production jruhi4 BRZ First-Gen (2012+) — General Topics 7 04-22-2012 09:37 AM
