Old 01-10-2013, 12:37 AM   #1
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
And They Said it Couldn't be Done!!
Put in the Whiteline rear Tranny bushing and the Perrin support, TOGETHER!!
I was told not compatible, but give me something to potentially screw up and I'll find a way! Used an air tool and a sharp little bit to open up the hole in the Whiteline bushing JUST enough to squeeze the Perrin in there.
And holy Moses, it is a night and day difference. I have never felt so connected to my machine, sounds and feels like a beast!
Make sure to hit up Jeremy @FT-86 SpeedFactory and Jeff and Chris down @PERRIN to get yours!!
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
The Following 3 Users Say Thank You to Batman For This Useful Post:
FT-86 SpeedFactory (01-10-2013), PERRIN_Chris (01-10-2013), ProjectD (01-30-2013)
Old 01-10-2013, 12:41 AM   #2
B L U E S L A T E
Drives: BMW E84
You have a detailed and focused photo?
B L U E S L A T E is offline   Reply With Quote
Old 01-10-2013, 12:49 AM   #3
Batman
Easy, Tiger.
Batman's Avatar
I tried a ton to get it to focus on the foreground and it wouldn't. I wasn't planning on putting these in today, but there was a lift available and I didn't have my camera. Everything fits like a glove in there though!
The Following User Says Thank You to Batman For This Useful Post:
Old 01-10-2013, 12:55 AM   #4
Hawk77FT
Drives: GTS 86
OMG @Batman...this is fantastic. Funny I was thinking about this today. I have both parts and I have been told they wont fit as well as the perrin is bigger in diameter than the Whiteline part. What di you use to increase the size of that hole? I remember having to shed about 4-5 mil of the hole so any help of how you did it would be grately appreciated. How big was the drill bit you have used?
Hawk77FT is offline   Reply With Quote
Old 01-10-2013, 01:00 AM   #5
Batman
Easy, Tiger.
Batman's Avatar
This is the closest picture I could find to the bit we used:
We tried it in a cordless drill and it wouldn't even shed some yellow.. So we stuck it in an air tool and it tore right in. We went a couple tries, and ended up getting it just JUST barely smaller than the perrin, so that they would stay together if we pushed it on. Then as I tightened the bolt on the bottom it all sealed right in together! Surprisingly very easy!
The Following 2 Users Say Thank You to Batman For This Useful Post:
Hawk77FT (01-10-2013), ProjectD (01-30-2013)
Old 01-10-2013, 01:17 AM   #6
Hawk77FT
Drives: GTS 86
Is the drill bit end the size of the perrin part or much smaller and you went on the edges sheding bit by bit?
Old 01-10-2013, 01:19 AM   #7
Batman
Easy, Tiger.
Batman's Avatar
Our drill bit was somewhat small, so we just ground down the outsides of the hole and kept placing it up to the Perrin to gauge how much more was needed.
Old 01-10-2013, 01:20 AM   #8
B L U E S L A T E
Drives: BMW E84
I know this is a pain in the ass to do..., but it sounds like it is worth while.
Old 01-10-2013, 01:28 AM   #9
Hawk77FT
Drives: GTS 86
The thing is I was inclined to use a hot wire to make a perfect cut instead of shreding it. Even a very sharp knife would probably do it just fine. I am not sure yet. At the end of the day how many times i am getting my self underneath the car to look at my Perrin and Whiteline combo? I will try to do it this coming weekend!
Old 01-10-2013, 01:51 AM   #10
Batman
Easy, Tiger.
Batman's Avatar
You would only see that cut if you removed it, and you may not climb under there to see them, but you will feel them every time you turn that key
Old 01-10-2013, 01:56 AM   #11
Hotdawwgman
Used Car King
Hotdawwgman's Avatar
Drives: 13 White M/T BRZ
hmmmmm Pretty damn cool!
Have you ever danced with the devil in the pale moon light?
Hotdawwgman is offline   Reply With Quote
Old 01-10-2013, 02:17 AM   #12
Hawk77FT
Drives: GTS 86
The thing is I have the positive shift bushing as well, and the whiteline rear bushes too. And if I go under the car, I am doing all of them not just one: Perrin transmission mount, perrin positive shift bushing, Whiteline part. And If I have time whiteline bushes. So it will probably be quite hard to pinpoint which part contributes to what, but still...I am sure I will feel the difference.
You said you heard the difference? Any more noise than normal from the transmission? or what ?
Old 01-10-2013, 04:56 AM   #13
number1Tango
Drives: Silver FRS
Thats a pretty cool find. but question, with all that stiffening wouldn't you have to stiffen up the motor mounts as well? if the motor is moving around wouldn't that put more stress on the tranny?
number1Tango is offline   Reply With Quote
The Following 3 Users Say Thank You to number1Tango For This Useful Post:
Batman (01-10-2013), jliongh (09-27-2016), Laika (01-10-2013)
Old 01-10-2013, 06:52 AM   #14
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Nice. We are going to do the same here and see how it works out. Videos of it with just whiteline alone and then add the perrin part. Just have to find the time.
-Jeremy
FT-86 SpeedFactory is offline   Reply With Quote
chris@perrrin, ft-86 speedfactory, perrin, perrin performance, whiteline
