Old 11-12-2012, 08:19 PM   #43
nashsnazzy
Drives: 2013 Scion FR-S White Out
Does that closed cell foam stuff smell like Dynamat used to? I put a whole bunch of Dynamat all over my car once and it didn't make much of a difference in the road noise but it made a huge difference in rattles. The issue I had, and this was a LONG time ago, was it smelled awful. I want something that wont ruin the smell of my car, to put on my doors, door panels, and perhaps a dynamat type product to put behind and around the door speaker.
nashsnazzy is offline   Reply With Quote
Old 11-12-2012, 09:03 PM   #44
PatrickSAN
Drives: SWP GR 5DR
CCF should NOT have an odor.
PatrickSAN is offline   Reply With Quote
Old 11-30-2012, 01:20 AM   #45
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
The original Dynamat was an asphault-based mass loader. Dynamat Pro was their butyl based CLD product that didn't smell. Most modern sound deadening supplies shouldn't smell unless you are using adhesive to attach something... and that should fade quick. The closed cell foam shouldn't smell like anything.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 01-08-2013, 01:56 PM   #46
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Anyone have sound recordings of audible noise before and after installation? If not, is there a marked difference? I have no experience with this media and would like to explore sound deadening application. Thank you!
Anthonytpt is offline   Reply With Quote
Old 01-08-2013, 02:01 PM   #47
jshadeck
jshadeck's Avatar
I have a box of second skin damplifier pro being delivered today, install sometime this week if i can fit it in before my next trip. Not sure how good of a before/after audio clip i can do, but i will record my 5 min drive home today and then will be able to roughly repeat that clip once installed. I have a custom muffler delete made by a fellow forum member, and it drones pretty bad sometimes.
jshadeck is offline   Reply With Quote
Old 01-09-2013, 12:28 AM   #48
mashal
DADA
mashal's Avatar
Drives: 2013
Sweet , I'll be looking forward to those pictures.
I couldn't get the guys at second skin to reply back to my 10 emails to them, so I looked into the BAM focal sound deadening . High quality material , little pricey .. but i heard a set up in person and bought them right away,haven't installed yet too frigging cold ;(
mashal is offline   Reply With Quote
Old 01-09-2013, 08:58 AM   #49
jshadeck
jshadeck's Avatar
Well, i put the second skin in my trunk, but i cant tell the difference! Waste of money
...but seriously, im hoping to install tonight or tomorrow
Old 01-09-2013, 11:16 AM   #50
wootwoot
Drives: FRS
lol...
Old 01-09-2013, 04:50 PM   #51
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
Attachment 24884
Gave me a heart attack until I viewed the picture. I got a free sample from GTMat back in November and a friend with some leftover Peel & Seal, but a slew of health issues arose that prevented me from touching anything on may car since then.
I'm very curious to see how your trunk-only install turns out, as my SRT headerback is also quite droney. I've been debating using the GTMat for addressing plastic rattling in the front doors and dash and Peel & Seal for the trunk since there's no need to worry about adhesive failing when gravity isn't tugging it anywhere.
Smudgeous is offline   Reply With Quote
Old 01-09-2013, 09:41 PM   #52
xjohnx
Grip>Slip
xjohnx's Avatar
Also very interested in how the trunk install helps. Are you going to do under the rear seats at the same time? or just the trunk/tire well/wheel wells?
Old 01-09-2013, 09:52 PM   #53
jshadeck
jshadeck's Avatar
Just the trunk area for now, if it makes a really big difference but not quite enough ill go further, but i have a feeling the trunk should be enough for my purposes
Old 01-10-2013, 09:17 AM   #54
jshadeck
jshadeck's Avatar
So i used my phone to record a video while driving last night for a "before" audio, and it picked up the drone along w what sounds like a raspy clicking sound, which is not actually heard in person, so due to the db and pitch of the drone i think the mic is not picking it up well :/
Old 01-10-2013, 10:37 PM   #55
jshadeck
jshadeck's Avatar
I kept focusing on work and kept forgetting to take pics. Till i was done, every inch of white in the second pic has been covered. I also did the majority of the beam under the rear deck/ 3rd brake light and into the wheel wells. Im not done w the trunk lid but had to call it a night, and i can get to that with out taking anything apart so itll be an easy fix.
As for the effect, i have not driven it far since, so i may come back and add comments, but the cruising drone has minimized a fair amount, however WOT seems to be the same. It has "cleaned" up the noise coming in through the trunk, so it is less harsh to the ears, and has minimized the couple rattles i had when letting off the gas from 5k down to 2k, i now have 1 rattle somewhere left to find...
My 16sq ft i ordered weighed 14lbs, and i used a little over half. If anyone is curious as to sq ft or weight. I would suggest 10+ sq ft to be safe (just the deck lid, rear deck underside, entire spare tire floor area, and wheel wells. Basically everything behind the rear seats) for doors, under seats, roof, obviously you would need alot more.
Old 01-10-2013, 10:54 PM   #56
schtebie
Drives: CBS BRZ Limited
Might want to also take a look at www.sounddeadenershowdown.com
There are some pretty comprehensive articles on how sound deadening should be approached to minimize and even kill sound. A buddy of mine used the suggested methods on his project car (AE86) and it's made a dramatic difference.
schtebie is offline   Reply With Quote
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 07:24 PM
Southeast sound OFF! OldSkoolToys Southeast 133 05-25-2012 12:31 AM
86 Sound System Skorov AUSTRALIA 25 05-09-2012 04:51 PM
BRZ exhaust sound! ilikecars86 BRZ First-Gen (2012+) — General Topics 16 04-13-2012 03:26 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
