Old 01-09-2013, 11:11 AM   #337
Marrk
Drives: Honda Fit
Originally Posted by whtchocla7e View Post
I definately hear a popping sound coming from the back of the car. Used to it by now, lol.
It's not the PD shooting at you again, is it?
Oh, wait. You're not in L.A. Sorry.
Marrk is offline   Reply With Quote
Old 01-09-2013, 11:57 AM   #338
Jayde
Jayde's Avatar
Jayde is offline   Reply With Quote
Old 01-09-2013, 03:45 PM   #339
sieeegel
Drives: rsx was stolen :(
How to fix rear deck sound
This is how i fixed my issue. I discovered that the noise is coming from the passenger side rear airbag. To get at the rear passenger side airbag, refer to this tutorial http://www.ft86club.com/forums/showthread.php?t=10002
I will skip some steps here and get to the point.
Once you remove the outer plastic trim, you will see the following (See below)
The red outline is where the PRIMARY sound is coming from. Gently tapping the airbag device will reproduce the sound. The clamp (outlined in red) is not fully attached to the chassis and makes a clinking noise. I simply took a 3inch x 3inch piece of t-shirt and wrapped it around the clamp outlined in red to dampen the sound.
In addition, I sprayed from WD40 over the metal clamp outlined in blue.
After i did all that, the noise went away.
sieeegel is offline   Reply With Quote
The Following 3 Users Say Thank You to sieeegel For This Useful Post:
gzpermadi (04-20-2014), Sigh-on-Rice (02-11-2013), Tor (03-28-2017)
Old 01-09-2013, 04:14 PM   #340
Jayde
Jayde's Avatar
So you put the piece of shirt behind the clamp against the frame of the body or against the part that is next to the plastic cover?
Old 01-09-2013, 09:09 PM   #341
CJB
Drives: 2013 BRZ Premium MT
Thanks for the write-up! I tried this earlier tonight, but I don't want to declare victory until I give it a few days as the noise had a tendency to come and go. The metal clip definitely hits the frame though, so it makes sense.
CJB is offline   Reply With Quote
Old 01-09-2013, 09:46 PM   #342
sieeegel
I kind of shoved it in between the frame of the car body and the clamp, but also wrapped it around the entire clamp as well.
The Following User Says Thank You to sieeegel For This Useful Post:
Jayde (01-09-2013)
Old 01-14-2013, 07:28 PM   #343
Jayde
Jayde's Avatar
Any update?
Old 01-14-2013, 08:12 PM   #344
Burrcold
Drives: Subaru BRZ Limited
Mine's going to the dealer on Wednesday for this and a few other little things. Will report back (there is no way they can give me a "no trouble found" either, because it's not even intermitten...it's all the time).
Old 01-16-2013, 03:34 PM   #345
CJB
Any update?
Issue still remains. I now think it's coming from behind the rear seat, under the deck panel (where the center brake light is). I put some leftover dynamat under it and the noise is reduced, but still there. Next step is to dynamat the whole deck panel.
Old 01-17-2013, 08:34 PM   #346
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I had the second part of the TSB performed (I already had the first part of it done earlier) and the noise remains. Additionally, there is now some rattling from the rear shelf that wasn't there before. I'll be in contact with SoA to resolve this, but for now, I'm a bit disappointed.
Subie is offline   Reply With Quote
Old 01-17-2013, 08:55 PM   #347
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
I did the first part of the TSB, still have the popping noise. I notice the sound isn't there if the seats are folded down. Anyone else have the same issue?
jacjac3 is offline   Reply With Quote
Old 01-17-2013, 09:09 PM   #348
Burrcold
Got my car back yesterday and the popping is gone!! Finally, thank god silence!
All they said they did was add extra insulation to the rear parcel shelf. I could tell that they must have sprayed silicone in the rear holes as well though.
Only annoying thing now is that it's so quiet I'm noticing all the other tiny rattles in other areas. Oh well, a good trade off
Old 02-01-2013, 03:59 PM   #349
CJB
I finally broke down and took it in to the dealer. End result - they couldn't reproduce it. I drove with them and pointed it out, but unfortunately the roads are smooth near the dealership so it wasn't nearly as bad as it sometimes can be. They basically said "there's nothing we can do if we can't pinpoint the source". No shit, that's what I need THEM to do. Nice way to spend a day off.
Might just keep trying other dealerships in the hopes that one decides to put some effort into it.
Old 02-01-2013, 10:00 PM   #350
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
I sprayed some WD40 in mine, last weekend. Haven't driven it since, I'll let you know the results I get tomorrow. I did not remove anything, just sprayed WD40 is all.
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
