Old 01-08-2013, 08:56 PM   #211
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
@dwx What Shocks are you going with??? Koni?? I hear Ohlins going to have some too..
Bill
Scooby South is offline   Reply With Quote
Old 01-08-2013, 09:02 PM   #212
whataboutbob
AutoX-10/10ths every run
Originally Posted by dwx View Post
Yeah in the end I'm hoping I have enough time at our first test and tune to try one bar in the morning and the other in the afternoon. Usually Whiteline is pretty good about providing exact stiffness specs if you email them, I emailed them Friday and I'm just waiting to hear back from them.
I put the Whiteline 20mm adjustable with adjustable end links on about a week and a half ago. Haven't done any events yet, but daily driving it seems really good.
Build thread:Here
Old 01-08-2013, 09:42 PM   #213
xwd
Originally Posted by ayau View Post
Can you explain your math?
OEM wheels with tires weigh about 40lbs.
40 - 36 = 4
4 x 4 = 16lbs savings
When I weighed my stock wheels and tires on this scale they were about 42 lbs. maybe it reads a little high. Theoretically my wheel and tire combo is supposed to be around 34 lbs.
Old 01-08-2013, 09:45 PM   #214
ayau
Drives: Some rust bucket
When I weighed my stock wheels and tires on this scale they were about 42 lbs. maybe it reads a little high. Theoretically my whel and tire combo is supposed to be around 34 lbs.
Oh ok.
TireRack has OEM tires listed at 20lbs.
http://www.tirerack.com/tires/tires....odClar=Limited
Old 01-08-2013, 09:46 PM   #215
xwd
Better scale than mine.
Old 01-08-2013, 09:50 PM   #216
ayau
I'm guessing that "extra" weight comes from the TPMS sensor and the wheel balancing weights.
I'm under the assumption that the OEM rims are 20.1 lbs and the OEM tires are 20 lbs.
Old 01-08-2013, 09:53 PM   #217
xwd
Bill
MCS. I was working with another shop but the MCS setup was cheaper and they are local. Should have them in a few weeks.
Old 01-08-2013, 09:55 PM   #218
Scooby South
Conedancer
niiiiiice... Jr.'s stuff... should be good then..
Bill
Old 01-08-2013, 10:01 PM   #219
Scooby South
Conedancer
Pretty much the same thing I got when I weighed mine..
Old 01-08-2013, 10:09 PM   #220
xwd
Same here it's a nice setup. I will continue to use the endlinks even if I go with the Strano bar. Do you know the exact stiffness of the 20mm in both positions? I found some specs for the 22 but not the 20.
The 74% I used for the Cusco bar was off their catalog.
http://www.cuscousainc.com/jpg/Toyot...3%82%B8_05.jpg
Old 01-08-2013, 11:41 PM   #221
whataboutbob
No. I'd be interested to know as well. I'm currently on the softest setting.
Build thread:Here
Old 01-09-2013, 03:30 AM   #222
simpleisbest
Senior Citizen
Drives: Scion FR-S
I'm running the Hotchkis (couldn't wait for Sam's and wanted to get a front sway in place) massive 25.4mm front sway on the soft setting with their adjustable endlinks. Feels good so far, but have only had one event on it so the jury is still out as to whether or not its too much bar.
http://www.hotchkis.net/scion-frs-fr...-sway-bar.html
I have to say I am very impressed with the build quality. The sway has welded shaft collars to keep the bar centered and the mounting brackets have zerk fittings to make reapplying grease possible without dismounting the bar.
So far, I am very pleased after 1 event. The car handles the transitions much better now. Nut behind the wheel still needs tightening, though...LOL!
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
whataboutbob (01-11-2013)
Old 01-09-2013, 11:20 AM   #223
xwd
Yeah I've never heard anything bad about the Hotchkis bars, nice to see they have the Zerk fittings, was one nice thing about some of the Cobb swaybars.
That bar is about 2X the stiffness of the Strano bar even on its lowest setting, it will be interesting to see how the bigger bars play out. I'm mainly going off Sam's feedback and where he felt the bar should be, and I definitely respect his opinion.
Old 01-09-2013, 12:03 PM   #224
cityhugo
Drives: white
Ur transition might feel great but ur sweeper stuff is going to suffer big time with that bar. u do have some control with the driving style to get some of those sweeper speed back. At the end is all about balance...
cityhugo is offline   Reply With Quote
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
What SCCA autocross class will the FRS be most competitive SVThis Tracking / Autocross / HPDE / Drifting 5 07-30-2012 04:29 PM
Share/discuss (this mornin) 86 Newsletter... RebootWindows AUSTRALIA 6 07-19-2012 04:15 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
Discuss.... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 12 02-11-2012 12:55 PM
