Old 11-12-2012, 02:21 AM   #1
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
perrin pulley causing noise when shifting?
ok so i got my perrin crank pulley installed and now every time i shift i hear an almost honking (maybe a quick humming) noise from somewhere under then hood. Did i screw this up somehow or is this a common problem? Need help fast!!!
garf is offline   Reply With Quote
Old 11-12-2012, 02:37 AM   #2
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Assuming you torqued the bolt correctly I would say get your head in there while the engines running and hit the throttle a couple times. You should be able to find it. It's also possible you got a pulley that's out of balance, but that's highly unlikely..
oh, and you did get the pulley lined up on the key, right?. Look at it while it's running and see if the pulley looks like it's wobbling.
GL
Starscream15 is offline   Reply With Quote
Old 11-12-2012, 09:01 AM   #3
mhigham
I think this is a pretty common noise for our cars. Some say its in the VVT. I hear a similar noise from the rear end on a shift, likely LSD.
Mike
mhigham is offline   Reply With Quote
Old 11-12-2012, 05:05 PM   #4
garf
Great Member
garf's Avatar
GL
it spins perfectly, no wobbling. when i am just sitting parked and hit the throttle it sounds fine, its only when i put my foot on the clutch to shift up around 3-5k rpm that i get the honk/rubbing noise. and yes i lined up the key correctly idk what it is or if its even the pulley causing it but its got me worried. no issues aside from the noise but im worried im going to get on it one day and see my pistons on the road shortly after.
Old 12-01-2012, 03:12 AM   #5
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
did u remove the honk box thats connected to your intake?
Teknian_Culprate13 is offline   Reply With Quote
Old 12-01-2012, 08:58 AM   #6
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Watch the tach next time you shift, bet you're just climbing a few revs when you put the clutch in to shift.
Kwaziekeller is offline   Reply With Quote
Old 01-06-2013, 12:47 PM   #7
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
I just recently started to hearing a very slight honk/duck quack noise when i shift. I always usually have the music turned on so I just started heard it for the first time last night. At first, i thought it was the shift light/beep but i had turned off the beep and limited to the light only. It only happens sometimes but something I listen for....any idea what it could be?
ap5512 is offline   Reply With Quote
Old 01-06-2013, 01:19 PM   #8
Celica00
Celica00's Avatar
Drives: 86
guys. it's something to do w/ the transmission, most likely a bearing. this has nothing to do w/ the perrin pulley as the belt is constantly moving regardless of what your transmission is doing. i have this problem too. the best way to ignore it until they release a fix for it is to just have really clean shifts.
Celica00 is offline   Reply With Quote
The Following User Says Thank You to Celica00 For This Useful Post:
ap5512 (01-07-2013)
Old 01-07-2013, 03:16 PM   #9
ap5512
ap5512's Avatar
Well my shifts are usually clean but I hear the noise right when I press the clutch down and before moving the shifter so it's really before I shift. I just hope it's nothing serious...the honk sounds stupid and harmless but if it's the tranny then I'm getting a little worried here.
Old 01-08-2013, 12:27 PM   #10
_hollywood
Drives: 97 itr sold
My bone stock frs does this, im 99% sure its the diaphram inside the sound tube, since it is a pressure activated device.
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 01-08-2013, 12:35 PM   #11
gmookher
take it off, put a plug in and let us know?
Old 01-08-2013, 08:43 PM   #12
_hollywood
Drives: 97 itr sold
I might, since its pretty annoying and i think the cold weather makes it worse....i dont need all the duck hunters here taking shots at me
The Following 3 Users Say Thank You to _hollywood For This Useful Post:
bakerr6 (03-25-2013), Celica00 (01-08-2013), Freeman (01-08-2013)
Old 01-08-2013, 08:52 PM   #13
Celica00
Celica00's Avatar
Drives: 86
Old 01-09-2013, 08:57 PM   #14
White64Goat
Moo
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Perrin Pulley ArKiTeCkT Issues | Warranty | Recalls / TSB 12 11-06-2012 11:57 AM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 05:45 PM
