Old 10-01-2012, 12:39 PM   #29
Cudgel
Drives: 2008 Mazda3 GT Hatchback
That looks sooo much nicer! Thanks for the write up!
Cudgel is offline   Reply With Quote
Old 10-01-2012, 12:51 PM   #30
empower-auto
Kouki-Monster
empower-auto's Avatar
I want a larger wangan-style version of this..
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-18-2012, 05:55 PM   #31
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i cna't decide if i liek this wing as idk if its aggressive enough like the trd/5axis. but this is great because i have the limited wing and no oen around here has wingless trunk i cna swap for becuase no one has galazy blue. if anyone else has other pictures of htis wing please post up!
and what does this cost, and does it come paint matched?
Jive Turkey is offline   Reply With Quote
Old 10-19-2012, 01:02 AM   #32
Chee-Hu
Chee-Hu's Avatar
I think I'd much prefer for the back portion to be a tad higher. Otherwise, this would be perfect for me.
Thanks for the write up. Nicely done!
Chee-Hu is offline   Reply With Quote
Old 10-19-2012, 01:16 AM   #33
Xenocide117
Xenocide117's Avatar
Drives: 2008 Honda Fit Vivid Blue Pearl
Am I the only one who, even though they know it's super sticky, doesn't trust tape? I would be checking every time I got out of the car.
Such a good looking spoiler though. I want that one.
Xenocide117 is offline   Reply With Quote
Old 10-19-2012, 02:32 PM   #34
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
ever try to remove emblemsor body mouldings? While they are smaller they aren't coming off on their own. This is the same type of tape. Its not coming off if applied correctly. I've been debating between this spoiler and TRD/ViS but I'm leaning towards this now. I like that you don't have to drive holes. Anyone know how the color match is with Whiteout?
FastLane1000 is offline   Reply With Quote
The Following User Says Thank You to FastLane1000 For This Useful Post:
Ray@Carsmo (12-05-2012)
Old 11-04-2012, 06:41 PM   #35
coletuck
Drives: stock frs (for now)
does anyone have the link to where i can get one of these duckbills
coletuck is offline   Reply With Quote
The Following User Says Thank You to coletuck For This Useful Post:
Old 11-04-2012, 10:02 PM   #36
mach330
Drives: Ultramarine frs
http://www.ft86club.com/forums/showthread.php?t=19013
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
The Following User Says Thank You to mach330 For This Useful Post:
Old 01-07-2013, 10:52 PM   #37
slaxx
Drives: '13BRZl, '14FiestaST2, '10Insight2
Any noticeable weight difference between the spoilers?
slaxx is offline   Reply With Quote
Old 01-07-2013, 11:19 PM   #38
Selvedge
@Draco-REX I have a stupid question: how do you remove the trunk liner? As in, how do you pop off the plastic rivets?
Selvedge is offline   Reply With Quote
Old 01-08-2013, 09:28 AM   #39
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The CARSMO is maybe a pound lighter if I remember correctly. The stock spoiler is very light as-is; there's no appreciable weight savings for doing this.
There's a center pin to the fastener. Use a flat bladed screwdriver and carefully pop out the center pin. You don't have to pull the pin out, just enough so it's loose, then you can pop the whole fastener out.
Tip: If you try to hold the pin all the way out as you pry, you'll have difficulty. Keep the pin at about halfway between all the out and all the way in and the fastener will come out a lot easier.
The Following User Says Thank You to Draco-REX For This Useful Post:
Selvedge (01-08-2013)
Old 01-08-2013, 10:05 AM   #40
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
how long did this whole process take you?
chenshuo is offline   Reply With Quote
Old 01-08-2013, 01:51 PM   #41
Draco-REX
Corner Junkie
Draco-REX's Avatar
Not counting the car wash, maybe an hour. It's really simple to do. Just pay attention to the details.
Old 02-28-2013, 04:11 PM   #42
dammitcubs
Drives: 2008 EVO X
thank you for posting this. this will really help when i do the exact same procedure. I think i'll wait on the opt-coat until I get this one there
dammitcubs is offline   Reply With Quote
CARSMO Rear Spoiler (FR-S/BRZ) Introductory Group-Buy Ray@Carsmo Groupbuys 206 10-26-2012 01:47 AM
~*# CARSMO FR-S Rear Spoiler #*~ Ray@Carsmo Exterior Parts - The Rest 147 09-17-2012 10:00 PM
New rear spoiler choice: Carsmo rear spoiler Ray@Carsmo Cosmetic Modification (Interior/Exterior/Lighting) 46 08-10-2012 02:20 AM
TRD Spoiler Installed JDMSushi AUSTRALIA 9 08-07-2012 12:49 PM
Carsmo rear spoiler test fit request on BRZ Ray@Carsmo Southern California 12 07-27-2012 08:25 PM
