Old 01-08-2013, 01:25 PM   #29
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Originally Posted by pastuch View Post
Here is what gets me about the responses to this thread...
What if I didn't opticoat the car? Most people don't and there shouldn't be a spec of rust on the car until years down the line.
My ex's white (non-coated) GTI had rail dust on it. I clean it off with a clay bar, and it never came back. It's not the car rusting.
Also, do you live in the city? It could just be rail dust/pollution that got on your car after it was Opti-Coated.
Grimlock is offline   Reply With Quote
Old 01-08-2013, 01:30 PM   #30
pastuch
pastuch's Avatar
Originally Posted by shu5892001 View Post
If you can get it off then it's rail dust.. Just clay it more often since you have a white car it's a lot more visible than other colors
Does it look like this?
Sorry, I've been reading this thread at work and my proxy server strips the photos. Just looked at this photo on my phone and it does look pretty similar. I've called both my dealer and my detailer/opticoater.
I do live in the city and drive under a railway over pass everyday. I also think the rail dust/pollution/iron deposits could be from driving around country roads in Quebec on the way to the ski hills.
Thanks for the suggestions everyone.
pastuch is offline   Reply With Quote
Old 01-08-2013, 01:33 PM   #31
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
If it was rusting I honestly wouldn't be surprised. When the 08 WRX remodel came out there was a recall for rust on the front of the rear quarters from the front tires flinging sand/rocks at it. They ended up putting thick clear bra like film on that location from the factory.
TOMIMOTO is offline   Reply With Quote
Old 01-08-2013, 01:33 PM   #32
jeebus
yeah, either your detail guy didn't prep well enough or you are getting iron fallout on your paint from another source now. Either way, it has nothing to do with the car you bought. I'm fairly certain your car will need to be properly stripped down, removing any opti-coat you have, for this problem to go away.
jeebus is offline   Reply With Quote
Old 01-08-2013, 01:47 PM   #33
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Thanks for mentioning earlier you live in a city and drive under a railway after everyone said it was likely rail dust. Your problem is a dirty car, not a rusty one. Now that I read this I'm sure your detailer did I fine job and you've picked up iron dust since. It's really easy to see on really light colored cars.
Old 01-08-2013, 03:10 PM   #34
jesperswe
Drives: GT86
All white cars look like that. It's not rust. If you have studded winter tires it usually gets even worse.
It's what someone stated it's just crap that's on the roads (from railways and such). All cars get's this but on white it's ALOT more visibile.
It will be better or worse depending on where you live and how much you drive
You can remove it with cleaner clay and at my workplace we have a special liquid that you can apply to the
"rust spots" and it will erase them with just water flushed over.
jesperswe is offline   Reply With Quote
Old 01-08-2013, 04:07 PM   #35
jduffy
jduffy's Avatar
What is this rust that you speak of?
jduffy is offline   Reply With Quote
Old 01-08-2013, 05:04 PM   #36
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so much misinformation in this thread!
these are IRON deposits that eat themselves into the clearcoat, also known as rail rust and it's present on all cars that were train-sported and left untreated by their original buyers.
that's why when i bought my car i had it cleaned by a professional (In my case, Hamza) by using a combination of claying and special compound that helps to remove these iron deposits.
here is my car, see that purple stuff, that's iron deposits, my entire car turned purple after the application of IRON-X
so after a wash, iron-x, claying, and polishing, my paint was sealed using opti-coat
i have no rust spots on the car.
the dealership will most likely deny coverage but good luck anyway.
i suggest you contact a local detailer to see if they can iron-x/claybar/polish because the last thing you want is to actually re-paint a brand new car.
and if you live in an area of high air pollution/rail sediment then invest into a high protection wax/coating/sealant and re-apply/clean regularly to avoid the contaminates from getting to the base layer
Old 01-09-2013, 10:02 PM   #37
White64Goat
Also do a search in the forums for spots or brown spots. I've seen a thread where someone else has had this type problem.
Old 01-09-2013, 10:55 PM   #38
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
This isn't always just from shipping and transport. If you live/work/drive in an area where there's a lot of industry you'll see this too. There are a lot more things that contribute to iron or metals in the air, it's not just trainspotting! LOL
Yes, there is a lot of misinformation here...
CircuitJerk is offline   Reply With Quote
Old 01-09-2013, 11:40 PM   #39
MattZ28
Drives: 2005 S2000
Not just that, but if you drive PERIOD, you're going to get iron deposits from brake dust.
MattZ28 is offline   Reply With Quote
Old 01-11-2013, 11:12 PM   #40
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
I have a white BRZ and I have A LOT of those rail dust near my trunk area only. My car has been opticoated since August.
My question is:
If I put iron x on the area do I have to reapply opticoat?
ArKiTeCkT is offline   Reply With Quote
Old 01-13-2013, 05:44 PM   #41
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
My question is:
Think of opti coat as a layer of wax, except much harder and sustainable to much harsher conditions (rain, pelt, high/low temps).
So as long as the opti coat was put on the car in good clean condition (which most detailers who do opti coat know prepwork is a must) then you wont have to take it off and re apply.
IronX isn't designed to deterior things like wax, sealant, opti coat or clearcoat. It's simply targeting the rust and iron deposits that are most likely sitting on top of the opti coat. Hope that helps a bit.
Jared0934 is offline   Reply With Quote
Old 01-17-2013, 01:48 AM   #42
ArKiTeCkT
ArKiTeCkT's Avatar
I believe its ON TOP of the opticoat. I've been driving through railroads, considering I live beside one.
Rust on tow hook ayau BRZ First-Gen (2012+) — General Topics 30 04-08-2014 03:54 PM
Good Rust Proof, Clear Bra places in GTA Eclipse218 CANADA 64 02-05-2014 10:48 AM
Underbody rust prevention/Tectyl etc Thobjo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 01-10-2013 01:10 AM
Rust Speck Jehuty77 CANADA 16 11-15-2012 10:30 PM
Rust already? Fugazi BRZ First-Gen (2012+) — General Topics 9 08-26-2012 03:36 PM
