Old 01-02-2013, 03:59 PM   #15
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Originally Posted by Mac1235 View Post
I have smelled this once and awhile and yes it is transmission or clutch related. The one time I smelt it the most was packing into a parking spot on an incline. The reverse gearing in this car is bad and to get the clutch out in reverse it wants to go 20 mph. So I had to ride the clutch a "little" bit because someone walked behind me while I was backing up and I smelled this smell. For me, I only smell it on those occasions and not sure if it is syncros burning or the clutch. If you smell this during daily driving you might want to get someone with a lot of manual driving experience to ride with you and watch your shifting style, you might be riding the clutch when shifting.
Yeah I kinda know what you mean .. I might just start heel-toeing the reverse Lol
Old 01-02-2013, 04:21 PM   #16
Mac1235
Mac1235's Avatar
Originally Posted by Khánh View Post
is this smell actually the smell of the clutch or the smell that people say it's the coating and will go away after awhile?
I have 4k miles on mine right now. The smell only happens when I have to ride the clutch backing up because the gearing is terrible on the reverse. I would say happens once every 1/200 times and only on an incline. In normal driving, not reversing up a hill, I don't smell this smell at all.
There are certain smells you will smell in the beginning of valve's seating themselves and possible coatings and oils burning off but this is not the smell we are smelling. This smell is a burning metal like smell. If you smell this during normal driving you are not shifting correctly or riding the clutch or your car has some mechanical problem. I would suggest people get a very experienced manual transmission driver to shadow them and see if they are driving incorrectly.
I said smell a lot.....
Mac1235 is offline   Reply With Quote
Old 01-04-2013, 01:57 AM   #17
qijian
Drives: FRS
i had this smell when i first started driving the car... it was horrible. Some people told me maybe the clutch needs a break-in time for it to work properly. 100 miles now and the smell is less significant. I smell a little bit of it if i got out the car after a drive and sniffed the exhaust area a bit (probably because im a lil paranoid about burning/killing the clutch) but otherwise... it seems to be getting better.
qijian is offline   Reply With Quote
Old 01-04-2013, 04:22 AM   #18
Supermassive
Supermassive's Avatar
The clutch does need break in time, but you will occasionally still smell it because the pressure plate for the stock clutch is very lightly sprung so it's more prone to slipping when not fully engaged. This makes the car easier to drive, but also easier to slip and cook a little clutch material. I have a 6 puck clutch in mine now and I don't get any burning smells (ceramic pucks don't really burn) but it is much more aggressive and not exactly smooth from slow speed starts.
Supermassive is offline   Reply With Quote
Old 01-04-2013, 09:26 AM   #19
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I tend to only smell it during stop and go traffic on hills.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
_F-R-S_ (01-04-2013)
Old 01-04-2013, 10:42 AM   #20
MI FR-S
MI FR-S's Avatar
Drives: Ultramarine FR-S MT
I'm getting an occasional light burning smell through the heat vents. No idea what a burning clutch smells like, but I once had a sticking brake pad and it smells kind of like that but much fainter.
In order to smell it I need to have the heat on for a good 25 minutes at least. Vehicle must be idling and stationary. Car can be in neutral with clutch engaged or in 1st gear with clutch disengaged, doesn't make any difference. Best chance is after a hilly bit of road for some reason.
I wasn't too worried until I read this thread. Sound like the same thing you guys are experiencing?
MI FR-S is offline   Reply With Quote
The Following User Says Thank You to MI FR-S For This Useful Post:
Brzce (01-21-2013)
Old 01-04-2013, 12:17 PM   #21
Sargy
Long Distance Driver
Sargy's Avatar
Well Kevin, I could only say this
have you considered your undercoat burning excess gunk off through the vents before thinking of your clutch?
your welcome
Sargy is offline   Reply With Quote
Old 01-04-2013, 01:09 PM   #22
whtchocla7e
Drives: 2013 FR-S Hot Lava
What does the clutch smell like? (lol)
Rotten eggs?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 01-04-2013, 07:23 PM   #23
Fire
Drives: Scion FR-S Firestorm
Like Mac1235, I did smell it couple time when I park mine on an incline. Normal driving is fine. The smell is like metal burning smell.
Fire is offline   Reply With Quote
Old 01-04-2013, 08:07 PM   #24
Mac1235
Mac1235's Avatar
Yeah it 100% the clutch slipping and the burning of the two plates spinning against each other instead of locking into one another and driving the car. Unfortunately with the way this car is geared for reverse there almost has to be some slipping when backing into certain situations.
Old 01-04-2013, 08:22 PM   #25
ScionRacer
ScionRacer's Avatar
Drives: 2013 Scion FR-S Ultramarine
I am still smelling it on occasion,but its not as bad as it was when the car was new.i have 6k on it now and I really have to "smell" for it.
One thing is for sure,its very hot under the hood of these cars,Like others have stated,its probably oils/paints/coating and such.It was much worse when it was hotter out,once november hit,I did not notice the vent smell as much.
ScionRacer is offline   Reply With Quote
Old 01-04-2013, 08:47 PM   #26
Mac1235
Mac1235's Avatar
I think there are some smells from coatings burning off but by 6k miles those are gone, if the smell is metallic, then it is the clutch slipping and burning. I think that is what we are smelling from what I read from others.
Old 01-15-2013, 12:14 PM   #27
MI FR-S
MI FR-S's Avatar
Update on my burning smell:
Took it to the dealership to have a look. They believe it is a clutch in the AC compressor and have ordered a part. Apparently the compressor was misbehaving. I'll update again once it is installed.
The Following 3 Users Say Thank You to MI FR-S For This Useful Post:
Brzce (01-21-2013), tripjammer (02-25-2013), Wolfking (01-18-2013)
Old 01-18-2013, 12:25 AM   #28
kramerica_industries
kramerica_industries's Avatar
Drives: 2013 Ultramarine FR-S
I've smelled the same on mine but only after high speed runs, like 10+minutes at over 90 mph. I have 12k miles on it.
kramerica_industries is offline   Reply With Quote
Severe Shaking while in Idle from 0-5 mph ScionFR-S Engine, Exhaust, Transmission 1 10-15-2012 09:42 PM
towed at 717miles CEL severe shaking (apparently a huge issue) gdi2290 Issues | Warranty | Recalls / TSB 45 08-31-2012 10:25 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Clutch/brake smell mr2lor Scion FR-S / Toyota 86 GT86 General Forum 8 05-24-2012 01:45 PM
