Old 01-03-2013, 04:15 PM   #71
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Any thoughts on using the BRZ ones on a FR-S with Koni's?
Old 01-03-2013, 04:30 PM   #72
bpracer
Drives: Asphalt FR-S
I'm using the BRZ part number on my FR-S. I've spent too much money on the car recently to upgrade the dampers.
The damping is OK with the stock units but I think the front may be a bit more under-damped. I don't have enough time with good weather to have a definitive opinion.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 01-03-2013, 05:46 PM   #73
JoeBoxer
JoeBoxer's Avatar
So you're saying the 3.8 fronts could stand to be stiffer? Like RCE Yellows maybe? I've got some soft front springs now and i'm looking to get something stiffer per RCE and others recommendation.
Old 01-03-2013, 05:54 PM   #74
mach330
Drives: Ultramarine frs
Yes they do, but they list the wrong rates for the BRZ part number, the FR-S listing is correct.
What's the rates for the brz compare to frs on these swift springs if they are different?
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
Old 01-03-2013, 05:56 PM   #75
JoeBoxer
JoeBoxer's Avatar
Tap'd from my G-Nex
BRZ is 3.8/4.5 and FR-S is 3.0/4.5 I think.
Old 01-03-2013, 08:15 PM   #76
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
We have these instock.
-Randy
Evasive Motorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to Evasive Motorsports For This Useful Post:
garfull (08-03-2013), LeavingNormal (01-03-2013)
Old 01-03-2013, 08:21 PM   #77
mach330
-Randy
Wanted to get a quote to install these and do alignment. Was thinking of doing this during dyno day.
Tap'd from my G-Nex
Old 01-04-2013, 03:19 PM   #78
wparsons
wparsons's Avatar
If that's true then these are a fair amount software than the RCE yellows (400lbs all around?)!
flickr
Old 01-04-2013, 03:27 PM   #79
JoeBoxer
JoeBoxer's Avatar
Here's a link with more info
http://www.vorshlag.com/forums/showt...7516#post57516
The Following User Says Thank You to JoeBoxer For This Useful Post:
Old 01-04-2013, 03:37 PM   #80
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
RCE yellow is 250
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-04-2013, 07:45 PM   #81
wparsons
wparsons's Avatar
Hrmm... not sure where I got the 400lb/in figure from, 250 isn't even 4kg/mm even so it's not like I just added zeroes. Must be too much vegging over the holidays
It sounds like the BRZ rates are probably a pretty good neutral rate with the FRS rates being more tail happy (although a bit less than stock looking at the front to rear rates).
Has anyone driven an FRS with both these and the yellows to compare the balance?
flickr
Old 01-04-2013, 11:02 PM   #82
bpracer
I think you would be hard pressed to find somebody that had driven these back to back. My car feels pretty neutral at speed with the Swift BRZ springs. Low speed, it is still rotates fine, doesn't push. Between the Racecomps and the "BRZ" Swift's it may be more personal preference. The drop is slightly lower on the Swifts.
I have slightly wider track (10mm spacers) than the front. That softens the rear rate a bit.
I got tired of waiting for what the BRZ STI springs rates might be and if they would be available.
If I lived somewhere with nice smooth roads I probably would have already gone with the Racecomps. As it was, the Swifts offered a slightly less aggressive spring rate for the front while still not biased too far to the rear.
If my car had come with the worldwide Toyota GT86 rates, I might not have changed the springs. But yeah, it looks better lowered and I will admit to that bit of form, rather than function, with my choice.
Asphalt FR-S
Ducati 848
The Following User Says Thank You to bpracer For This Useful Post:
JoeBoxer (01-04-2013)
Old 01-07-2013, 11:29 AM   #83
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
I just installed the production version of the BRZ Swift springs on my FR-S. (3.8F 4.5R) I previously had a pre-production set of of the FR-S rates (3F 4.5R) They are still very neutral, but not quite as tail happy as the FR-S rates were. I expect increased stability on track, but the FR-S rates would likely be better for slower more technical use, such as AutoX or other parking lot antics, if that is your bag.
mines13 is offline   Reply With Quote
Old 01-07-2013, 11:53 AM   #84
gmookher
so what are the correct rates for swifts?
Swift Springs Fitting - SoCal Only schtebie Southern California 16 11-29-2012 03:29 PM
WGP Looking for a BRZ For LS Swap Prototype Doug@WGP Announcements, Contests, Giveaways 25 10-10-2012 05:20 PM
FS: Swift Motorsports Motorized Plate Holder kanundrum Exterior Parts (Aero, Lighting, Etc.) 4 06-12-2012 01:12 AM
Different wheels on the prototype ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-20-2011 05:00 PM
Wheels on the Prototype joshuo Scion FR-S / Toyota 86 GT86 General Forum 13 11-03-2009 07:37 PM
