gmookher
Old 12-28-2012, 08:54 PM   #225
roddy
roddy's Avatar
Drives: '13 Ultramarine
Originally Posted by gonzo View Post
Check it again, it says the tran and diff gear oils can be 75w-85 and/or 75w-90
I'm looking at page RM-3.
Checked it again... Section 6-1, under specifications, page 348.
MANUAL TRANSMISSION
Gear oil capacity - 2.3 qt. (2.2L, 1.9 Imp qt.)
Gear oil type and viscosity - Use either of the following:
- "TOYOTA Genuine MG Gear Oil special II"
- Other gear oil that meets API GL-3 and 75W90 specifications.
No mention of 75W85 for the transmission...maybe the Canadian manual/spec is different .
Old 12-29-2012, 12:11 AM   #226
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
To clarify in this thread, none of us who are advocating a thinner fluid are saying it is defined as the spec by Toyota / Subaru. That's clear in their documents. Ok
Thinner fluids are used by all manner of enthusiast and have been proven in many, many different types of transmissions and in everything from street use to full blow racing. We're talking HIGH loads. Ok, got that too
I wanted to hear it from the right person(s)...
Every year, I attend the PRI show. I made it a point and I spoke with several lubricant manufacturers (at least ten plus attend the Professional Racing Industry show every year). I wanted to know how they look at this situation and if this is something we should all be concerned with.
From what I gathered after speaking to a few respected people, the additive packs in the speciality oils we are discussing should be adequate in protecting the gears under most all conditions and that the gears themselves are not as dependent on viscosity as one might think. The additive packs also protect the synchronizers.
The take away was that thinner gear oil is not going to cause damage to the gearbox unless its providing far too little protection (overheated / depletion of additives).
Do you know what trend was extremely common amongst all the specialty racing oil manufactures i spoke with: Not only 75w85, 75w80... But 75w75 and 70w70 oils! This was new, even to me.
Modern additives have allowed for lower viscosity, even racing, while the gear boxes hold up and shifts are smoother.
Also...
The close cousin of our gearbox, the Aisin found in the S2k. Many, many people use Honda's MTF, rated in viscosity right around 75w80.
Take away: 75w80 as 75w85 GL-4 may not be what listed in the manual.
If your using a superior oil you should match the viscosity to the temperature range you expect to use and can even go with a thinner oil that allows for faster gear synchronization in your gearbox.
Last edited by Esoteric; 12-29-2012 at 02:20 PM. Reason: bolding and italicizing, making easier to read
Esoteric is offline   Reply With Quote
The Following 4 Users Say Thank You to Esoteric For This Useful Post:
Amadeus (12-29-2012), Bonburner (06-25-2013), gonzo (12-29-2012), rice_classic (01-03-2013)
Old 12-29-2012, 05:45 AM   #227
gonzo
Drives: frs
MANUAL TRANSMISSION
I'm going off of the manual that is posted on this forum, check that one out perhaps it's different from yours
gonzo is offline   Reply With Quote
Old 12-29-2012, 07:33 AM   #228
roddy
roddy's Avatar
Ok, I see where you're coming from. It looks like a bit of a generalization, as it says transmission and differential. In my owner's manual it lists 75W90 for the trans, and 75W85 for the diff (with 75W90 acceptable as well). I'd be interested to see if your owners manual is any different than mine. Regardless, I chose to use Pentosin (75W80) on Gem's glowing recommendation, and it works great even at temps well below freezing.
Edit: yay...my 500th post!
Old 12-29-2012, 09:36 PM   #229
gonzo
Drives: frs
I will check my car manual to see what it says. I dont experience cold enough weather so i went with redline 85 and it def feels better
Old 12-30-2012, 08:06 AM   #230
roddy
roddy's Avatar
I'm sure the MT-85 will be fine. Others have tried it and reported good results. I used MT-90 for my first change, and it was a vast improvement over the OE fill. The only reason I drained it out was once the temps got below 40F, the shifting got pretty stiff. I skipped right over the MT-85 and tried a blend of MTL (70W80) and Honda MTF (75W80ish). I did this as an experiment to see if the transmission liked a thinner fluid and to use up some stuff I had laying around from other projects. This improved cold weather performance and effort substantially. I didn't want to spend $30 a quart on Pentosin until I was sure the trans would like a thinner fluid. If I had tried MT-85 for my first change, I may still have it in there.
Esoteric has some good points above ^.
Old 01-03-2013, 02:23 AM   #231
001BRZ
Honda MTF 06 is working amazingly in my brz, I've started a thread on it in the Aussie section!
001BRZ is offline   Reply With Quote
The Following User Says Thank You to 001BRZ For This Useful Post:
gmookher (01-03-2013)
Old 01-03-2013, 09:18 AM   #232
gmookher
Honda's MTF uses some kind of sulphury-smelling compound that smells like gear oil.but, Its a GL4 just like Pentosin, unless your MTF-06 is different from our US MTF-2. The photo I found of the MTF 06 looks like nothing else I've seen.
Honduh MTF2 Virgin Oil Analysis on Bobistheoilguy.com shows a viscosity of 7.5cst at 100*C. most of people who are activley tracking their cars are using something that is designed to withstand more abuse than the OEM oil, in honda-land too.
There are lots of claims (and a VOA IIRC) that suggest Honda MTF is nothing but a 20(synth)/30(dino) weight oil mix with some EP additives thrown in for good measure.
As you are probably aware, Honda back in the day used to specify motor oil in their MT's until ZDDP started disappearing when the newer API specs came on the scene longside OBD2. I must be showing my age on this one. honda MTF "shears" down in weight overtime, as is common with fossil fuel oils.
I used Pentosin knowing its a full synth and that Honda is not. It will work great tho, as its very similar to Pentosin, which is a group IV/V oil mix. No dino in there like Honda, thats at best a III, as is the case in most semi synth formulations.
here is a basic breakdown, tho its fun to watch folks try stuff clearly not in the right range, just to try it..
Manual Transmission Oil Viscosities
ATF type MTFs: 6.0 – 7.5 typical
Honda semi synthMTF II 7.5
Royal Purple Synchromax 7.7
Pentosin MTF2 7.5
GM/Chrysler Synchromesh type: 8.5-10.0 typical
Torco MTF 8.35
Pennzoil Syncromesh: 9.08
Amsoil MTF (5W-30) 9.6
Red Line MTL 10.6
Honda MTF 1 10-11?
75-85 Gear Oils: 12.0-12.5 typical
Specialty Formulations MTL-P 12.0-12.5
Castrol Syntorq 75W-85 12.0???
Nissan 75W-85 12.0???
MT-85
90 weight Gear oils: 15-16.5 typical
Royal Purple Max Gear 14.5 (Published: 21)
Amsoil MTG 14.7
Pennzoil GL4 75W-90 15.3
Red Line MT-90 15.6
You choose, the Honda is a perfect oil, I would just change it out more frequently with track usage. Its the cheaper stuff to put into an aisin tranny compared to the german fluid.
The Following User Says Thank You to gmookher For This Useful Post:
001BRZ (01-07-2013)
Old 01-03-2013, 10:19 AM   #233
Dezoris
Dezoris's Avatar
After coming from 4 Hondas with 6 speeds including two S2000s I would never run Honda MTF again. Feels great for about 6k-10k miles but get a few track days in it and syncros get balky. It just does not hold up well. I am hoping the Pentosin does not have the same issues.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
001BRZ (01-07-2013), gmookher (01-07-2013)
Old 01-03-2013, 12:33 PM   #234
gmookher
this.
Old 01-03-2013, 05:54 PM   #235
getbent
Drives: 2013 FR-S Blue MT
So is everying going to 75W80 simply to solve the performance in the cold? Nobody has any reservations that the operating temperature thickness of 75W80 (7.7 cSt) is significantly less than 75W90 (~15 cSt)?
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
The Following User Says Thank You to getbent For This Useful Post:
coyote (01-08-2013)
Old 01-03-2013, 06:13 PM   #236
aced86
aced86's Avatar
Drives: 2013 frs asphalt m/t
Had the opportunity to drain and put the pentosin new fluid in today . Will report back over the next couple of days to see how it does. Also I stated I may be able to find a better price on this fluid through one of my wholesalers . Found out I get it for the same price as the website gmookher listed in his first post .
aced86 is offline   Reply With Quote
Old 01-07-2013, 05:31 AM   #237
001BRZ
Interesting info guys on the honda oil, I think I'll try out some of the pentosin in the future!
Old 01-07-2013, 10:06 AM   #238
gmookher
seeing as you tried the honda stuff, I am VERY curious on your feedback on Pentosin, as a comparo
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 06:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 09:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
