#43 | |||||
In front though? What *really* happens is the steering wheel self centers and you don't have a real side to side difference. 1/4 inch toe-in on one side and 1/4 in toe-out on the other is still zero total toe. The car will drive straight, turn the same left vs right, it will just have a steering wheel that isn't centered. Fix it with the tie rods or fix it by pulling the steering wheel and centering it. You won't see any difference between the two methods until you get to full steering lock, and you might not see it then. Quote:
As for the question in the original post, I still maintain that you can throw on some camber bolts, max out the neg. camber and call it a day. It will be fine for daily driving. I do agree, that at some point an alignment is in order, but the tires aren't going to wear excessively while you figure out what you actually want, and why. |
#44 | |
I was not happy with the first two alignments however, I do not think the values were spoofed. I do not question your experience, however you have not provided alignments before and after installing camber bolts for this car. I am. Is this the be all end all? No but it clearly shows that a car that was within factory specs of alignment, WAS NOT after installing the bolts, both OEM and aftermarket. After installing OEM crash bolts: TOE Front Left -0.25 Front Right 0.10 After Installing SPC Camber Bolts TOE Front Left -0.12 Front Right -0.23 Are these good alignment values, no. Unacceptable for an enthusiast as well as a dealership doing a to spec alignment. We can argue all day about changes in steering feel, low speed feel, high speed stability of alignments however this is all driver dependent. Again I am trying to answer the question of the poster with data not with guesstimates.
#45 |
Overthinking it
Drives: BRZ in CS
I think this thread has lost its way.
OP wants to install Camber bolts. Camber bolts provide more camber. You adjust camber and measure by getting an alignment. Should OP get an alignment? Yes, you absolutely *want* an alignment. If you are going to the effort of installing something, install it correctly so that the bolts do what they are supposed to do. Do you *need* an alignment? No, but I don't understand why you would install bolts if you were just going to slam the struts all the way in. The toe change may be minor with camber change, but 1/16" toe in vs. 1/16" toe out can have a big effect on the way a performance car handles. Camber bolts aside, "factory spec" for an alignment is usually pretty crappy for most cars. Any car out of the box would benefit from a performance alignment. |
| The Following User Says Thank You to mla163 For This Useful Post: | chulooz (01-02-2013) |
#46 | |
Drives: Some rust bucket
#47 |
Even if you're running full size bolts, there's enough wiggle room that the alignment won't be the same on both sides, or ideal unless you're REALLY lucky. Just because it's within "spec" doesn't mean it's the same, or good. I think stock front camber spec is 0* +/- 0.8*, that means you could have a net difference of 1.6* between the two sides and still be within spec.
#48 |
Exactly right. The range of "within spec" is large and has tons of variance straight from the factory and that's the real problem. "Within spec" can be quite shitty, if you are lucky maybe not. But who knows until it is on an alignment t rack. I would recommend an alignment even without the bolts! If you are going to the trouble of putting them on do it right and get an alignment.
#49 | |
Site Moderator
Drives: Stuff
![]() Also, the camber bolts changed my toe exactly 0.00 degrees. YMMV.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | celica73 (01-03-2013) |
#50 | |
![]() But yeah, realistically, you probably can't get anything more than -2.2 on the camber bolts and lowered springs. I'm guessing you'll need camber plates if you want to get -3.0 or more camber. @CSG Mike is currently running that setup. |
#51 | |
Site Moderator
Drives: Stuff
![]() I'll be running threaded body coilovers soon with plates so I'll be going to -3.0 up front initially.
-Dave
#52 |
Are most coilovers threaded with a bigger slot?
#53 |
Site Moderator
Drives: Stuff
You mean at the strut to knuckle/upright mount? Many are. I'm not sure if the Eibachs are, but between the crash bolts (or other camber bolts) and the camber plates up top I'll have more than enough camber adjustment. I'll max out what I can at the bottom so I can make easy adjustments at the top during alignments, etc.
-Dave
#54 | |
Getting camber in the rear doesn't seem to be a problem as lowering the car will gain you a lot of negative camber in the rear; it's fine tuning/balancing both sides that seems to be the issue. |
#55 | |
Site Moderator
Drives: Stuff
-Dave
#56 |
| Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Camshaft Bolt Coming Loose After Perrin Pulley Install | WhiteBRZ | Engine, Exhaust, Transmission | 25 | 09-20-2012 08:07 AM |
| Coil Install + alignment in Bay Area? | BlaineWasHere | Southern California | 21 | 08-27-2012 12:10 AM |
| Alignment needed after lowering car? | Lowellrenzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-16-2012 02:57 PM |
