Old 01-02-2013, 09:06 AM   #15
gmookher
Originally Posted by ngabdala View Post
I have to say being an experienced manual transmission driver that I stall alot in the BRZ, 5200 miles later. I will be using the DIY here to adjust the catch point. I've just been too lazy
remember less adjustment is more
Old 01-02-2013, 10:13 AM   #16
OrbitalEllipses
Drives: Attitude
This is my first manual as well, and I stalled a fair bit in the first few weeks. If I tried to describe the clutch on this car I'd say the pedal is soft, with some dead travel at the beginning and a wide area of modulation. It definitely took some getting used to, but I find it to be really forgiving though feel is definitely a problem; the friction area isn't necessarily hard to find, rather it's numb at its "borders" so to speak.
Gurus feel free to correct,
Old 01-02-2013, 11:48 AM   #17
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
DIY for Clutch Adjustment - http://www.ft86club.com/forums/showthread.php?t=8040
It makes a huge difference
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
The Following User Says Thank You to kykiee For This Useful Post:
arleewa (01-02-2013)
Old 01-02-2013, 01:40 PM   #18
Khánh
Khánh's Avatar
Drives: sc00ter
Originally Posted by DarkSunrise View Post
I used to own an 09 STI hatch. Compared to the STI, the FR-S/BRZ clutch is much lighter and the engagement point is higher. You can lower the engagement point with the DIY mentioned above.
Once warmed up, I prefer the FR-S/BRZ transmission over the one in the STI, but the engagement point did take me a couple of weeks to really get used to.
I thought the 370z's clutch was one of the strangest I've tried. When lifting your foot off the clutch pedal, it feels like the spring is stronger in the last 1-2" travel, almost launching your foot off the pedal at the end. Never felt anything like that before.
I can't really complain about the FR-S/BRZ clutch pedal, except for the high engagement point and soft spring.
I'm so glad I'm not the only one that needs some time getting used to driving frs/brz clutch.. for a minute, i thought i suck at driving stick haha
Khánh is offline   Reply With Quote
Old 01-02-2013, 02:28 PM   #19
DarkSunrise
DarkSunrise's Avatar
Haha yeah I felt the same way a couple of times in the first few weeks I had the car. Try the DIY clutch adjustment posted above. I eventually got that done and it helped a lot for me since I was used to cars where the clutch engages early on. Much better/more intuitive now.
2022 BRZ Build
2013 FR-S Build
Old 01-02-2013, 02:38 PM   #20
Khánh
Khánh's Avatar
Drives: sc00ter
will do
Old 01-02-2013, 03:35 PM   #21
CTB727
Drives: 2013 Subaru BRZ
This is probably the best way to describe it.
CTB727 is offline   Reply With Quote
Old 01-02-2013, 03:35 PM   #22
JSUB
JSUB's Avatar
Drives: 2026 BRZ tS coming
Originally Posted by Jive Turkey View Post
i came from a 2011 STi and the brz is a joke to drive compared to the STi. the clutch is lighter, has less travel, needs way less throttle input and is so much easier to drive smooth than the sti simply because its rwd and not AWD.
Indeed ! Clutch is way easier specialy in heavy traffic compared to my past LGT. Wouldn't go back.
JSUB is offline   Reply With Quote
Old 01-02-2013, 08:10 PM   #23
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
I think I've stalled the car once but I will definitely be adjusting the clutch a bit. I'm coming from a 2010 WRX where the revs dropped too slow and made fast shifting hard where as the revs drop much quicker in this car and make leisurely shifting harder. I'm finding the revs dropping too far and I have to tap the gas to bring them back up to engage the clutch in the next gear. This is really only an issue when the trans is cold and I need to shift easy. Once it is warmed up and I can shift faster it isn't as much of an issue. Glad to hear other people have the odd issue though, makes me feel like I'm not too much of a shit driver.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 01-02-2013, 08:18 PM   #24
sierra
Drives: Skoda Yeti DSG diesel 4x4
I found the throttle response pulling away in first was delayed when it was new but after over 1000km it has come good. I'm assuming this was ECU learn but it was strange I only noticed it pulling away and could double clutch easily, which needs a quick response.
I wish the brakes were a bit more responsive.
sierra is offline   Reply With Quote
Old 01-02-2013, 09:20 PM   #25
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Keep your foot ever so slightly on the throttle while you clutch/shift. It'll take a couple tries to find that sweet spot but you'll have extremely smooth shifts like this
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
A5D5TRYR (01-02-2013)
Old 01-02-2013, 09:33 PM   #26
A5D5TRYR
A5D5TRYR's Avatar
Thanks for the tip. I've done this a few times and I seem to be fine once it's warm but the engine RPM just doesn't act the same when it's cold and makes it really hard to engage smoothly when it's cold. I've only had the car almost two weeks so I figure with practise I'll get better. Changing out the trans fluid will likely help as well as I should be able to shift faster when it's cold. To be fair it is way easier to drive this car smoothly than my WRX was and much easier to launch without bogging the engine.
Old 01-03-2013, 04:04 PM   #27
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Yup, pedal feel has nothing to do with power. My 4cyl pickup is neither sporty nor powerful, but you almost have to stand on the clutch pedal.
Mobius357 is offline   Reply With Quote
Old 01-03-2013, 09:27 PM   #28
OrbitalEllipses
Drives: Attitude
I thought about this and I think a better way to put this is that while the friction area is wide, it is also vague feeling. You can definitely feel the point of engagement, but stray from that and I can't necessarily tell what I'm doing.
Clutch.. RedRocket Forced Induction 37 11-11-2012 04:52 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
