Old 11-22-2012, 12:07 PM   #1
arleewa
arleewa's Avatar
Drives: 2013 Satin White Pearl Subaru BRZ
BRZ vs WRX STI Clutch
so i got to drive my buddy's 2009 (i think?) sti not too long ago.
the BRZ is my first stick car so needless to say ive done my fair share of stalling while learning how to REALLY drive stick (i had driven other vehicles before but only in parking lots, etc.)
when i drove my friends car i noticed that the clutch's catching point was VERY early...i mean like 1 cm off the floor early. it was MUCH easier to shift in his car than in mine, or at least in my opinion.
i was just wondering if there was an explanation for this? im not a mechanical guru, but i had always assumed that more HP meant a stronger clutch and therefore a stiffer peal as well (for all i know this assumption could be HIGHLY inaccurate). this seemed to tell me the opposite.
im a little lost as to why this may be, maybe because the transmission is different? basically i was hoping someone would be able to explain this to me
arleewa is offline   Reply With Quote
Old 11-22-2012, 01:13 PM   #2
dori.
Seρor Member
dori.'s Avatar
Drives: white BRZ 6MT
every car is different
different transmission, clutch disk, pressure plate, master/slave cylinders, pedal position...
pedal stiffness can come from the pressure plate and/or the clutch line... try driving a six puck clutch with a strong pressure plate and stainless line and you'll know
dori. is offline   Reply With Quote
Old 11-22-2012, 01:51 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The catching point has nothing to do with how strong the clutch is, or how much HP the car has. This clutch grab point can be adjusted in any car (There's a DIY thread here on how to adjust it for the BRZ). Clutch stiffness CAN be an indication of how much power the car has BUT it is not always true, as you can have a 91 civic with 108 HP and install a 4 pluck bronze clutch and high pressure plate and it will be stiff as f*$%k but that will not mean the car has any big amount of HP. In the other hand, you can have a high HP car in which you use a sprung clutch, and even though it can hold a big amount of HP, the pedal is not as stiff.
Old 11-22-2012, 02:35 PM   #4
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I have to say being an experienced manual transmission driver that I stall alot in the BRZ, 5200 miles later. I will be using the DIY here to adjust the catch point. I've just been too lazy
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 11-26-2012, 12:01 AM   #5
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i came from a 2011 STi and the brz is a joke to drive compared to the STi. the clutch is lighter, has less travel, needs way less throttle input and is so much easier to drive smooth than the sti simply because its rwd and not AWD.
Jive Turkey is offline   Reply With Quote
Old 11-27-2012, 09:18 AM   #6
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
The BRZ's clutch feels really odd to me. The clutch's resistance is not the same (or linear) through out its range. As if the first few centimeters has resistance, then all of the sudden its soft and resistance free. My '11 STi had more of a traditional (normal) clutch feel. The clutch is the only thing I do not like about the BRZ/FR-S. Feels like the 370's clutch (this is not a compliment). Yuck!
iLuveKetchup is offline   Reply With Quote
Old 11-27-2012, 09:52 AM   #7
sierra
Drives: Skoda Yeti DSG diesel 4x4
When the clutch engages that close to the floor it's unlikely to be disengaging properly when it's used to change gear. That's bad news for the gearbox and the clutch.
About 2/3 up from the floor is about right.
sierra is offline   Reply With Quote
Old 11-27-2012, 12:08 PM   #8
chutrain
chutrain's Avatar
Drives: WRB BRZ
The BRZ clutch took me a little to get used to. Very forgiving coming from my E30 M3 or
LGT. The LGT is extremely stiff and catchy, and the E30 is extremely sensitive and small engagement zone.
Just take your time and you'll pick up little tricks. The LGT took me a little bit as well due to the drive by wire, but go used to it after time.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 11-27-2012, 02:45 PM   #9
DarkSunrise
DarkSunrise's Avatar
I used to own an 09 STI hatch. Compared to the STI, the FR-S/BRZ clutch is much lighter and the engagement point is higher. You can lower the engagement point with the DIY mentioned above.
Once warmed up, I prefer the FR-S/BRZ transmission over the one in the STI, but the engagement point did take me a couple of weeks to really get used to.
I thought the 370z's clutch was one of the strangest I've tried. When lifting your foot off the clutch pedal, it feels like the spring is stronger in the last 1-2" travel, almost launching your foot off the pedal at the end. Never felt anything like that before.
I can't really complain about the FR-S/BRZ clutch pedal, except for the high engagement point and soft spring.
Old 11-29-2012, 01:04 PM   #10
arleewa
arleewa's Avatar
i just drove my other friend's 370z..i know what youre talking about. it really was a pain the butt to drive. i could NEVER see myself getting one of those as a daily drive. not fun and man is it scary changing lanes in that thing!
Old 11-29-2012, 02:07 PM   #11
iLuveKetchup
Drives: EFF JAY
You described it exactly how I felt about the clutch.
Old 11-29-2012, 02:10 PM   #12
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
I agree that the clutch is soft. It took me a while to get used to. I'm pretty smooth with it all the time now. However, when anyone else drives my car, they stall it. Happened four times with the only four people to drive my car: my dad, the mechanic at the exhaust shop, my tint guy, and the mechanic where I got my snow tires. I've only stalled it once in 5,000 miles.
fender9530 is offline   Reply With Quote
Old 12-01-2012, 11:52 AM   #13
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
The transmission unit and associated clutch etc are completely different than that found in the awd Subies. The unit is derived off the Lexus IS, so it will feel more like a toyota or lexus.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 01-02-2013, 03:31 AM   #14
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
If you think the BRZ catch zone is off you should see my M3... It is like 2-3 times farther
RAWR BRZ is offline   Reply With Quote
Clutch.. RedRocket Forced Induction 37 11-11-2012 04:52 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
