#15 |
That one I dont know, Im pretty sure my kit comes with an upgraded fuel pump but I wont be 100% sure til its delivered. Its one of those things that I feel is better to have for peace of mind, regardless of the need. Sorry I couldnt give a better answer, I would PM one of the turbo kit builders on here and see if they might be able to better clarify this stuff for you.
#16 |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
Well I figure I'll buy the AVO kit, run it on the tune they supply... and over a weekend do injectors/pump and boost controller, then dyno tune it on E85... make some decent power with it.
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
#17 |
UCanThrottleMyBody
Drives: 2015 GM 370z Sport
If im reading this correctly I would need new injectors at 200-240whp? Why? And what would you guys think would be a comfortable size?
#18 | |
Drives: 2003 Subaru Outback
Injector size = (HP x BSFC) / (number in injectors x duty cycle) Or you can ask a tuner on here like Visconti who has extensive fuel system R&D done on this car. **Note: You will need to compensate for about 30% more fuel at a given rwhp rating if using e85. |
#19 | |
UCanThrottleMyBody
#20 |
#21 | |
Drives: Matte Black STI
I have been messing with this ECU for a long time, tweaking maps that may or may not do anything just to see what happens. All I can say is that I am not seeing a need for bigger injectors running the Vortech SC kit in both stock form (tuner kit) and even an upgraded form we will be offering. That means a pretty decent savings in $$$! |
#22 | |
Tells it like it is
Please note this is likely to be on E85 and as a result the injectors will need to be larger to make that power level than on 93.
#23 |
Drives: 2013 Raven Black FRS
If the stock rhp is 167.... I'd like to be about 250+ rhp. I cant imagine pushing 400+ rhp from this car. I can get mine sideways with the car running stock. At some point its not even fun to drive anymore. Problem I had with my stock X Runner, when the road was wet, I couldnt keep the ass end from sliding. Sucked having to granny it cause the ass end kept sliding when I didnt want it to.
#24 |
Drives: 2013 White Out FR-S
Youll get close to 300whp so the 280whp mark is a good point to stock at without pushing the duty cycle too far
#25 | |
| My oil level was low! | FRSjeff | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 12-15-2012 11:22 PM |
| Deatschwerks Injectors - Released | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 0 | 09-08-2012 04:20 PM |
| Deatschwerks BRZ/FR-S Fuel Injectors! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 2 | 09-07-2012 06:29 PM |
