Old 11-25-2012, 02:18 PM   #127
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Originally Posted by ProjectD View Post
Well to be fair, you were technically using all "150lbs of tq" .....lol......hahaha get it?
I'll admit it wasn't like I just put a wrench on there and broke it free immediately, like popping a lid off a stubborn jar. Some of us have a little more than 150lbs of tq as well I've attempted to loosen bolts and done pull ups on the wrench,split sockets, twisted the ends off of extensions (etc), so the stubborn-ness scale it's hardly maxed out.
Kwaziekeller is offline   Reply With Quote
Old 11-26-2012, 11:10 PM   #128
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
Originally Posted by 2point0 View Post
Is this before or after you replaced the frayed belt?
I installed a pulley this past week and notice what sounds like gear whine. Searching hasn't yielded much result, but my best guess is that the lighter pulley transmits more NVH. This sound is directly related to engine speed and not the car speed. In or out of gear, it is noticeable at around 2500 RPM and higher. Seriously sounds almost like a supercharger, but once the revs get high enough, the exhaust (Nameless axleback) drowns it out.
Nothing else seems to be affected, the pulley doesn't wobble and I've seen no leaks. All Subarus make funny noises anyway, so I'm not freaking out. Just looking for a little validation in my life.
Aside from all that, I really like the more natural feel of rev matching. I no longer have to double-blip!
well it was the strangest coincidence but if you search the forums for a noise while shifting youll find im not alone in this problem. guess it just happened to start the same day i did the install. apparently the noise im hearing has something to do with the clutch or trans. and only happens in colder weather. weirdest thing.
garf is offline   Reply With Quote
Old 11-28-2012, 01:24 PM   #129
ML
ML's Avatar
Drives: 13 White MT FR-S
http://forums.nasioc.com/forums/showthread.php?t=444518
Isn't replacing the stock harmonic damper (pulley) bad? Subarus do not come with a harmonic damper or balancer like some other vehicles do. For other manufacturers' vehicles, this is a legitimate concern. Proof:
"Thank you for your patience as I checked with our Technical Services Department regarding your message below. They advised that the crank pulley is a pulley and nothing else. It is not used as a harmonic damper/balancer.
Thanks for the opportunity to be of assistance. If you need any future assistance, please feel free to contact us again."
Best wishes,
John J. Mergen
Customer Service Department
Subaru of America, Inc.
The Following 3 Users Say Thank You to ML For This Useful Post:
Fender0122 (08-16-2016), Marrk (11-28-2012), mRdeMs83 (03-07-2013)
Old 11-30-2012, 12:32 AM   #130
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
Originally Posted by Kwaziekeller View Post
Also for you AT guys looking for a way to lock the flex-plate. Not recommending it, but there should be an "inspection cover" on the bell housing (where the front of the trans and the rear of the engine meet, manuals will have them too). If you remove the cover you should see the teeth on the flex-plate (flywheel for manuals) that the starter uses to start the car. You'll need two people, but often times you can finagle a flathead screwdriver or pry bar in between the teeth and hold the flex-plate by prying against the bell housing. Only reason I don't really recommend it is because if you slip and damage a tooth it can damage your starter and replacing both is $$$. Best bet is to use an impact or buy the proper tool to hold the flexplate tho.
whats that tool called... flexplate grabber lol? so that when i call the shops around i can ask if they have one before i take it?
got the pulley and am very anxious to get this thing on
Teknian_Culprate13 is offline   Reply With Quote
Old 11-30-2012, 07:13 PM   #131
Teknian_Culprate13
Drives: Scion FR-S
having trouble with my AT frs, the shops cant even get that flexplate tool, its not available
to independent shops guess ill take it to subaru
Old 12-02-2012, 04:28 PM   #132
Kwaziekeller
If I knew I'd tell you... lol. I've always used an impact on other auto cars and had no problems.
Old 01-01-2013, 02:27 AM   #133
Hawk77FT
Drives: GTS 86
I installed mine today and after I struggled with a 16" braker I used a 1 metre steel bar attached half way to the 16" breaker. And bang! Done!
Hawk77FT is offline   Reply With Quote
Old 01-01-2013, 03:34 AM   #134
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
How do you like it? I'm struggling with getting this mod done. Not sure if its worth it or not.
ravenblackfrs is offline   Reply With Quote
Old 01-01-2013, 06:07 PM   #135
Hawk77FT
Drives: GTS 86
It is ok, dont expect huge gains 100hp or anything like that. It does make a slight difference, but than again it could be subjective. I have taken it out so I can have my first 1000km service done. I will put it back in once that is done.
Old 01-01-2013, 08:57 PM   #136
jybrd
jybrd's Avatar
Drives: 2013 Scion FRS
Just ordered mine, kind of nervous about the whole install. Ive avoided these types of upgrades because of the uncertainty. If anyone has any additional tips tricks or comments feel free to throw them my way. My pulley will be here next week.
jybrd is offline   Reply With Quote
Old 01-01-2013, 09:15 PM   #137
ravenblackfrs
Nah, I wouldn't expect that... lol. Wish it was that simple.
I have read some other posts on here... I was under the interpretation that the pulley being replaced was a harmonic balancer... but from what others have been saying, its not... its just a pulley. Suppose the car is eccentrically balanced.
Old 01-01-2013, 09:46 PM   #138
Hawk77FT
Drives: GTS 86
Yeah, but from the feedback here, some might expect huge gains. I did notice the car being quieter though. Yes, and maybe a bit rev happy but not by much. Is it worth it? yes, I think it does if you add few other things with it in the future. LIghter flywheel, intake, exhaust, etc. Otherwise, it feels like the engine wants more, but it is still limited by other bits so you're not extracting the full potential out of it. PLus a dyno tune will be a must if you want to make the most of it. So if you plan on doing more to the engine in the future, this is worth it, otherwise it will be just some bling under the hood. My 2 cents.
Old 01-01-2013, 09:49 PM   #139
ravenblackfrs
Yea, I have intake and axel back exhaust on my car now. Taking it to get dyno'd tomorrow.
Old 01-07-2013, 06:46 PM   #140
so26
Drives: Raven FR-S 6MT
Installed the Perrin crank pulley and I have to say that it definitely improves the feel of fast down-and up-shifts by removing some of that rotational inertia that our cars seem to have too much of.
One con that I have noticed however is that if I go to gun it at idle without a load on the motor (like you would do to show off your exhaust to someone in a parking lot) that the rpms will momentary dip followed by a chattering noise before the rpms recover. This is most likely due to air within the intake manifold stalling because of the sudden onset of WOT. The additional rotating mass of the stock pulley would keep things spinning and therefore making this a non issue. Note, this issue does not seem to be a problem actually driving the car and can be avoided by gradually applying the throttle initially.
FYI, you may not need to purchase a breaker bar if you can slip a 3/4" black pipe (3' in length) on the handle of your ratchet.
Also you don't need a fancy torque wrench for this job a bar-type wrench will work fine; however, you may want to use a 12-pt socket to get the best angle for applying the required force on the handle.
so26 is offline   Reply With Quote
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
