#15 |
Overthinking it
Drives: BRZ in CS
The point of camber bolts is to add camber. Yes, you want an alignment.
#16 |
Drives: 13 GTI
You do NOT need an alignment if you are simply replacing 2 of the bolts with the camber bolts.
There are 2 shock bolts per side, and the camber bolts only replace 1 per side, so if you leave one untouched on each side, the alignment doesn't change.
#17 | |
Ugh. The ignorance that abounds on these forums amazes me sometimes. -Mike Paisan ![]() 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#18 |
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
It does not matter if you change 1 bolt per side. You will STILL need to get a proper alignment.
| The Following User Says Thank You to Calidrifter For This Useful Post: | AZP Installs (12-31-2012) |
#19 |
Drives: 13 GTI
You are 100% wrong.
#20 |
@Executive_chicken
I'm not saying it will be out of spec.
I think we need more information before this thread gets out of hand. @ayau what are you trying to get out of this setup? Track, street or stance? Once that's answered a better answer can be given. |
#21 | |
Drives: Some rust bucket
in the future, i may go with some coilovers and the camber bolts will help dial in the exact camber settings. |
#22 |
@Executive_chicken
Ok, so as stated it shouldn't be out of spec with just the 2 upper bolts being replaced.
When do you think you will get the suspension? If its sooner rather than later wait until then to dial it in. If its going to be over a year than just get the alignment done now for piece of mind. Hell if the shop is a quality shop they will let you know if you need it done prior to touching anything on the car as they will do a baseline. |
#23 | |
#24 |
The alignment isn't related to your tires or rims, so you can go ahead and get that alignment. Once camber bolts are remove/reinstalled or installed for the first time you absolutely will need to get an alignment. Unless you are planning to upgrade your suspension within a month or 2 then get the alignment done to prevent premature wear and unsafe handling.
Will you be installing the bolts yourself or having a shop do it? -Mike Paisan ![]() 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#25 | |
#26 | |
Drives: Attitude
#27 |
@Executive_chicken
Is your upgrade path:
Bolts-Tires-Suspension? Either way I would get an alignment once you change the tires, as the stock will be way more forgiving than the stickier ones as far as wear is concerned. |
#28 | |
the reason why i chose to mount the oem tires on the aftermarket (ce28n) rims is because the oem tires are good to learn on for a novice driver such as myself. i just happened to run into a good deal on the rims. |
| Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Camshaft Bolt Coming Loose After Perrin Pulley Install | WhiteBRZ | Engine, Exhaust, Transmission | 25 | 09-20-2012 08:07 AM |
| Coil Install + alignment in Bay Area? | BlaineWasHere | Southern California | 21 | 08-27-2012 12:10 AM |
| Alignment needed after lowering car? | Lowellrenzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-16-2012 02:57 PM |
