Old 12-29-2012, 04:38 PM   #15
Joeprelude
Joeprelude's Avatar
Drives: 2013 FRS, 2002 WRX Wagon
I always used http://rimsntires.com/specs.jsp but always wished they had a visual for the specific car's suspension and fender/QP.
Joeprelude is offline   Reply With Quote
Old 12-29-2012, 05:21 PM   #16
itdansharpe
itdansharpe's Avatar
My fender gap calculation is strictly vertical gap, it doesn't account from the edge of the tire, as I can't assume what the corner radius of your specific brand of tire is.
Originally Posted by jeebus View Post
also, the fender gap calculation can't be right. I just picked a tire that was 9mm taller in diameter and the fender gap shows 9mm less...shouldn't it be 1/2 that?
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 12-29-2012, 05:32 PM   #17
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Rim width was removed?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 12-29-2012, 07:46 PM   #18
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Can you add camber to the mix? I feel like that would help.
Tansey86 is offline   Reply With Quote
Old 12-30-2012, 03:32 PM   #19
jeebus
No, that's not what I mean. Compare a 215/45/17 to a 225/45/17. The diameter of the tire is 625mm vs 634mm, a 9mm difference. Your fender gap calculation shows a change from 54mm to 45mm, also a 9mm difference. But what you aren't factoring in, is that increasing tire height doesn't push it directly closer to the fender. The tire is attached to the car at the hub, and the height change occurs above AND below that. So it would be 4.5mm closer to the fender, the other 4.5mm increase at the bottom would increase ground clearance, not decrease distance to the fender.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
itdansharpe (12-30-2012)
Old 12-30-2012, 07:05 PM   #20
itdansharpe
Correct. I will adjust this shortly.
The Following User Says Thank You to itdansharpe For This Useful Post:
jeebus (12-31-2012)
Old 12-31-2012, 12:17 PM   #21
jeebus
Yay I win at math today. :P
Old 01-03-2013, 11:55 PM   #22
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Dayam, this is sweet! Added as one of the first links in the Wheel Directory!
http://www.ft86club.com/forums/showthread.php?t=7535
The Following User Says Thank You to DarrenDriven For This Useful Post:
itdansharpe (01-09-2013)
Old 01-03-2013, 11:59 PM   #23
OrbitalEllipses
Drives: Attitude
Neat, but without wheel width this tool is very incomplete in showing you changes in fitment as width changes fitment the most drastically.
Old 01-04-2013, 02:54 AM   #24
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Oh wow this is pretty awesome stuff!
Thanks a ton for this!
Old 01-04-2013, 03:15 AM   #25
qijian
Drives: FRS
pretty nice tool to have handy since i can't get the miata one to work properly on my firefox.
qijian is offline   Reply With Quote
Old 01-05-2013, 12:01 AM   #26
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
Pretty cool. Very nice job.
Customize the piss out of it and call it yours!
Skywgn1 is offline   Reply With Quote
Old 01-05-2013, 10:01 AM   #27
JDMenrique
DEEEERP
JDMenrique's Avatar
Very nice! Thanks
JDMenrique is offline   Reply With Quote
Old 01-05-2013, 10:34 AM   #28
Foobar
SLO NO MO
Foobar's Avatar
So this tool assumes that the wheel width is equal to the tire width?
Nice work, in any event, but if you can somehow include wheel width in this, that would make this the mots comprehensive tool available to us. Unfortunately, I'm not sure of the math involved with using wheel width and tire width together to come up with the exact fitments.
BBK Fitment Database? F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 164 02-09-2026 12:48 AM
Auto Fitment Calculator itdansharpe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-28-2012 01:09 PM
FR-S Speed/RPM Calculator FR-S #2637 Engine, Exhaust, Transmission 8 09-19-2012 11:41 AM
Spring Rate Calculator yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-28-2012 11:31 AM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
