Old 12-30-2012, 03:09 PM   #71
jflogerzi
jflogerzi's Avatar
Originally Posted by FT-86 SpeedFactory View Post
You are correct. No CEL for removing the cat on the front pipe. We have been running the catless front pipe with no CEL issues. The header is where the O2 sensor gets it reading.
Also, you can always keep that stock front pipe to put back on for inspection. I know it's a hassle, but an option!
Cheers!
-Yo
Yes I know. I plan to keep all my stock parts for a just in-case moment. This car is my DD. Would the Q300 plus front pipe be to loud? I want something that sounds mean, deep, but not overly load and obnoxious like the big potato shooters on older Civics and WRX's ( you know the large fart can that you can hear from a mile away)
jflogerzi is offline
Old 12-30-2012, 03:54 PM   #72
jflogerzi
jflogerzi's Avatar
Also when you have a video up with the Q300 and catless front pipe. This is the combo I am eying Maybe along with a light weight pulley for good measure. Then finally a tune in the coming few months to bring everything together with my aFe intake
Old 12-30-2012, 03:54 PM   #73
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
The Q300 with catless front pipe is not loud at all. It's sounds almost identical to it with the stock front pipe. The Q300 and catless front pipe is perfect for a DD in our opinion.
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Dipstik-sportech (12-30-2012)
Old 06-23-2013, 11:20 PM   #74
FT-86 SpeedFactory
Got a video for us?
Old 06-28-2014, 07:07 PM   #75
Sleeper86
Drives: FT86 GTS white AT
Couldn't get q300 align properly.
Need help guys, I installed the q300 on my car yesterday, but it just would align properly, the driver side tip is poking more than the passengers, some guys from the Facebook page also said their having the same problem, can someone please confirm if they can fit it properly evenly? I don't know what I did wrong but I've follow some advise to drive all day to break it in? I was told somehow the metal flexes after heat and the alignment changes automatically? So far I have not seen change after all day of driving, the driver side still poking out more. I've also tried adjust the rubber hanger and loose the clamp and twist and turn and tighten the clamp many time but still the same, not sure if this info helps but if I pushed the driver side in it will stay and looks perfect, but once driven it changes back to uneven, any ideas?
Sleeper86 is offline
Old 07-14-2014, 02:12 AM   #76
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
@Sleeper86 I just installed mine and have the same problem so don't worry you're not alone. From what I gather it's because the weight is all on the left side since that's where the bend to get around the diff is. I tried adjusting it and redoing the clamp a couple times but it still always slides back to that state. I have a feeling that adding a longer hanger on the left side rear might do the trick but have yet to try it. For now I just live with it.
jimmillion is offline
Old 08-21-2017, 05:58 PM   #77
nyfries
Drives: 14 FRS Whiteout
Can you reused the gasket from stock exhaust? my second hand q300 doesn't come with the two bolt and gasket thats show in the first photo
nyfries is offline
Old 08-22-2017, 02:23 AM   #78
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
Yeah, but is it recommended to use new ones.
Blue Bird is offline
Old 08-26-2017, 08:17 PM   #79
nyfries
where do i find new gasket and bolts?
nyfries is offline
Invidia N1 - VIDEOS and Installed Photos ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 200 05-16-2017 06:07 AM
**INVIDIA** >>SUPER SALE THREAD<< - Invidia N1 - Invidia Q300 - Invidia Front Pipes - FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 629 12-11-2016 09:21 PM
**BLACK FRIDAY!! Invidia Q300 FRS/BRZ 614.25 SHIPPED!! +10% off Special!** RallySport Direct Announcements, Contests, Giveaways 0 11-23-2012 02:16 AM
***Invidia N1 FRS / BRZ SALE*** Videos and Photos - FT-86 SpeedFactory does it again! FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 33 10-24-2012 10:11 PM
Invidia Q300, Frontpipe & N1 Teaser Videos! RallySport Direct Engine, Exhaust, Transmission 18 10-17-2012 04:00 PM
