Old 12-16-2012, 11:11 PM   #127
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yes, you can activate it and turn the volume up or down up to level 7
That's great! Will order one now. Thanks!
HRTROB is offline   Reply With Quote
Old 12-29-2012, 02:41 AM   #128
8987846
Drives: BRZ MT SWP
Originally Posted by xjohnx View Post
Anyone here experienced with this software?
It came with my OBD2 cable and I've been able to use it to change some of the dealer settings like headlight auto-off delay time, disable the auto-off for rear defroster, adjust the buzzer volume from the remote, disable passenger side seatbelt warning buzzer. You can also disable DRL, adjust the sensitivity of the auto headlights to come on when it's darker or lighter out.
I've posted some screenshots below (VIN removed). I'm most curious about the "Inspection Mode" function in this screenshot. I wonder if this would be a way to semi-permanently disable traction control/VSC without having to hack up a solution to the switch?
here are some other random shots, for the curious:
Do you know what other things you can configure with Techstream? I have a few things in mind that would be great!
auto-locking at >15km/h etc
'Guide me home' low beams that stay on for a few minutes after car is turned off
automatic door unlock when car is turned off
automatic right-mirror parking assist on reverse selection
8987846 is offline   Reply With Quote
Old 12-29-2012, 10:27 AM   #129
xjohnx
Grip>Slip
xjohnx's Avatar
Not possible at the moment.
My BRZ does this, I'm almost positive TechStream has the option for enabling and adjusting the length of time they stay on.
These weren't possible through techstream when i last checked into it.
Old 12-29-2012, 01:38 PM   #130
8987846
Drives: BRZ MT SWP
Thanks. i bought the cable as well, but i couldn't find these setting either.
in the region setting, choose Japan or Europe give me a little more settings, but not the one i wanted.
perhaps we shouldn't use toyotas diagnostics software? use subarus instead?
Old 12-30-2012, 07:17 AM   #131
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I was looking into the Subaru option and there is actually a free version fully developed for Subaru. Its called FREE SSM (Subaru Select Monitor). I haven't tried it and didn't read much into it because I think I need a new cable for that one, but look it up in the internet. I am not 100% of BRZ compatibility, but I don't see why it wouldn't be compatible.
https://www.google.com/search?q=suba...w=1277&bih=723
Old 12-30-2012, 11:08 AM   #132
xjohnx
Grip>Slip
xjohnx's Avatar
Not sure if it would be compatible or not, the last build date on it seems to be 2.5 years ago. http://developer.berlios.de/project/...group_id=10320
Old 12-30-2012, 11:10 AM   #133
Sportsguy83
Drives: Limited BRZ
Man, I swear I'm not kidding. I just opened the page a minute ago, must be right at the same time you were looking at it LOL!
Yeah, it does seem that free one will be outdated for the BRZ.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
xjohnx (12-30-2012)
Old 12-30-2012, 11:18 AM   #134
xjohnx
Grip>Slip
xjohnx's Avatar
That's a shame. I bet if enough people contacted the developers (and someone offered up their car for a little testing) they might be willing to update it. Especially any of you guys in Germany, since that seems to be where they are located.
Sportsguy83 (12-30-2012)
Old 01-06-2013, 03:26 PM   #135
gmookher
okay, I got the cable off ebay and it came with a techstream CD but no registration code. where can I get this or software that works with the cable?
ver 7.10.030 is what came
I cant get past that screen..
Old 01-06-2013, 03:55 PM   #136
Foobar
SLO NO MO
Foobar's Avatar
Typically, the eBay copies of the software has a key somewhere on the CD. Some of them have gone so far as to put actual keygens on their discs.
Worse comes to worse, your typical warez site will have an answer for you, but we won't get into that here.
Old 01-06-2013, 05:47 PM   #137
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
7.31.003 is available at www.auto-professionals.co.uk
JP is offline   Reply With Quote
Old 01-06-2013, 09:11 PM   #138
Sportsguy83
Drives: Limited BRZ
I downloaded 7.20.041. It includes instructions for activation (replace Main Menu file, then use some keys to activate).
I replace the Main Menu file, run Techstream, but when I go to the activation menu, I input the supplied keys and hitting software activation opens a webpage. Well, that webpage never connects. I close the webpage and go back to activation window. I click ok and nothing happens... Then, eveytime i try to connect to the car, it tells me i have X amount of days (now at 25) for using techstream without activating it.
Anyone has any idea what am I doing wrong?
Old 01-06-2013, 11:01 PM   #139
gmookher
yeah I need some help with mine..
Old 01-07-2013, 03:51 PM   #140
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Is anyone using a Tactrix Openport 2.0 cable with Techstream, and if so have you been able to program TPMS ID's with it? I'm thinking about spending the $170 for a Tactrix cable, but only if I can confirm it will program TPMS.
Production Toyota FT-86 Details and Design Previewed by Toyota Sports Vehicle Boss ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 541 11-18-2011 09:04 PM
Toyota FT-86 G's Sport Concept moved to Toyota Mega Web showroom at Odaiba Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 05-02-2011 01:11 AM
Toyota FT-86 G-Sport Concept car displayed with AE86 at Toyota Amlux, Tokyo Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 03-08-2010 11:09 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 11:36 AM
