Old 12-28-2012, 02:36 PM   #127
Hanakuso
For all Toyotas registered in those states or just the FR-S? Smell's getting fishier...
Not sure. I got the letter but i'm from California and it did mention only the states in the OP's list
Hanakuso is offline   Reply With Quote
Old 12-29-2012, 01:00 PM   #128
mr2lor
Drives: 2013 Scion FR-S Asphalt MT
Strangely, they also change my brake fluid as shown on the order receipt.
mr2lor is offline   Reply With Quote
Old 12-29-2012, 06:02 PM   #129
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Do you think it was related to this recall?
davesrave is offline   Reply With Quote
Old 12-29-2012, 07:53 PM   #130
mr2lor
I supposed the brake fluid change is part of the recalled because that's what I brought my car in for.
Old 12-30-2012, 12:14 AM   #131
DR1FT
Drives: MBC300
I had the ecu recall done earlier. Like some of you guys my throttle was a bit sluggish at first then after a few miles everything went to normal.
DR1FT is offline   Reply With Quote
Old 12-30-2012, 12:46 AM   #132
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
Yeah i got a letter telling me this last week. I'm gonna ignore it till my next oil change, i'm not getting smogged anytime soon.
LeavingNormal is offline   Reply With Quote
Old 12-30-2012, 01:19 PM   #133
Opposed
Drives: 2013 Asphalt FR-S
Originally Posted by chaotichoax View Post
In comparison to all other vehicle I've owned/driven this car takes more time to warm up completely.
I also agree. I find it strange for a modern car to take this long to get to normal opp. temp.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 12-30-2012, 01:25 PM   #134
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Originally Posted by ngabdala View Post
Hmm wonder why it's just these states. I wonder if there is more going on with this update that is not being shared with us. I see some strict states when it comes to emissions listed there.
Maybe we don't pass an OBD II with one cat if we change our exhaust system.
The ecm reflash is for smog purposes only. It does not alter performance
20valvewynn83 is offline   Reply With Quote
Old 12-31-2012, 01:28 AM   #135
jduffy
jduffy's Avatar
Yeah, I had the reflash done and oddly my teeth are whiter now. Related? I'm not so sure.
jduffy is offline   Reply With Quote
The Following 4 Users Say Thank You to jduffy For This Useful Post:
20valvewynn83 (12-31-2012), Batman (01-07-2013), gonzo (01-07-2013), OrbitalEllipses (12-31-2012)
Old 12-31-2012, 11:44 AM   #136
whtchocla7e
Drives: 2013 FR-S Hot Lava
Just had my car reflashed.
How can I visually confirm that it was really reflashed?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 12-31-2012, 11:53 AM   #137
Foobar
SLO NO MO
Foobar's Avatar
Visually? No way to tell. You'll need some ECU diagnostic tools hooked up to your car's OBD2 interface to check the ECU version, I imagine.
Old 01-01-2013, 08:56 AM   #138
cagster
cagster's Avatar
Drives: Hot Lava Scion FRS
For those with the FRS, here is the quote from the letter I received:
" On certain early 2013 Model Year Scion FR-S vehicles, the On Board Diagnostics II (OBD-II) System may need to be updated to meet the regulations set forth by the Calif-ornia Air Resources Board (CARB). An update for the Engine Control Module (EVM) to improve the monitoring parameters within the OBD-II system is now available. The correction ensures that the 'Check Engine Light' will illuminate should an abnormal condition develop (such as the engine coolant not reaching or maintaining the proper operating temperature)."
"Any authorized Scion or Toyota dealer will inspect the calibration of the ECM and if necessary update the ECM at no charge to you. This Special Service Campaign is offered to vehicles currently registered in the following 12 states that have adopted the California Emission Standards: CA, CT, MA, MD, ME NJ, NY, OR, PA, RI, VT and WA."
cagster is offline   Reply With Quote
Old 01-01-2013, 11:57 AM   #139
BRZnut
Drives: BRZ DGM Limited
Mine too...I can drive 10 mins to work and it is still not at normal temp according to the dash temp gauge, but the odd thing is the heat from the heater is hot. Can't figure that one out.
Old 01-02-2013, 02:28 PM   #140
karbon
Drives: DGM BRZ
Anyone in LA get the GPS fix? If so, which dealership? The dealership I went to in Sacramento wasn't able to do it because they said they didn't have the bracket or whatever.
karbon is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
