Old 12-23-2012, 08:46 PM   #57
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
I just finally installed mine today and it was easy and works great. It took me longer to find a comfortable way to crawl under the steering column than it did to switch out the flasher. Tie wrap to hold it tightly in place and done. Now my dad wants one for his 4Runner.
thorlius is offline   Reply With Quote
Old 12-27-2012, 01:07 AM   #58
developer
Drives: BRZ Limited
Just ordered mine today. Does it have a louder "click" sound then the stock relay? I have a hard time hearing the stock relay when I have the stereo turned up.
developer is offline   Reply With Quote
Old 12-28-2012, 11:31 AM   #59
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
Does the proximity key set have remote buttons on it for door lock / unlock?
scottmcphee is offline   Reply With Quote
Old 12-28-2012, 11:32 AM   #60
scottmcphee
I think 4runner uses the same flasher module, so it should work no problem!
Old 12-28-2012, 12:11 PM   #61
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes it does, and the Windows are Auto Up Auto Down.
From our email conversations and since the BRZ has auto up/down windows, can I just get the Basic set, install it and get Up/Down functionality with they Key Fob?
Thanks for your prompt replies.
Old 12-28-2012, 07:42 PM   #62
scottmcphee
When you say auto up and auto down does that mean one-touch of the interior switch will make the windows go all the way, instead of having to hold the switch?
This is essentially what the dei530t module does, except it also remains powered when the car is off, and will apply power to window motor if commanded by one of its input lines.
Ironically, autowindow does not care or need or use the one-touch feature of the dei530t, it simply uses this module's capabilities for powering and driving the window motors while the car is off.
Now, if the BRZ can move windows while key is out, then we have something to look into further.
Q: does your car have "retained accessory power" whereby after stopping the car and taking the key out, you can still use the radio and other interior accessory powered devices for a while? On some cars this works until you open a door. I think you know what I'm talking about. My Legacy doesnt have this feature and just wondering if BRZ got around to adding this very thing? (Guess what? I made an add-on module for this feature and now have retained accessory power... Like it should have come with in the first place!)
Old 12-28-2012, 07:49 PM   #63
scottmcphee
What I can and will do for you is drill a few sound hole "grills" through the flasher case and this will allow more sound out.
Also be sure to physically mount the Tapturn flasher the same way as your stock one is mounted solidly to a plastic box. This helps resonate sound in the dash. People who want softer sound might let the module dangle in air or zap strap it loosely to something nearby.
The Following User Says Thank You to scottmcphee For This Useful Post:
developer (12-28-2012)
Old 12-28-2012, 11:42 PM   #64
developer
Drives: BRZ Limited
Thanks Scott, That's great! Can't wait to get it.
Old 12-29-2012, 01:21 AM   #65
Sportsguy83
Drives: Limited BRZ
Yes, you don't need to hold down the button, its one touch up and one touch down.
On your second question its also a yes. After you turn the car off (push button off), windows keep power until you open a door.
Now I ask, given all of this information, do I still need the DEI530T or would autowindow be able to use this feature (able to control windows for a short period of time after car off) to not need DEI530T?
Old 01-01-2013, 05:13 PM   #66
scottmcphee
Happy new year! I've repackaged the Tapturn module by shrinking the PCB to fit a smaller space, now resides inside the flasher case itself and looks like the photos attached. It's functionally identical to earlier packaging just neater all around.
The Following 2 Users Say Thank You to scottmcphee For This Useful Post:
developer (01-01-2013), Sportsguy83 (01-01-2013)
Old 01-01-2013, 09:54 PM   #67
scottmcphee
This sounds all very promising. I have to ask another question about the resumption of accessory power... When you approach your parked car that is sitting there off, what are the steps you'd have to do in order to use power windows WITHOUT starting the car?
And another question about retained accessory power. Suppose you shut off the car and use power windows while sitting there inside, and you don't open the door.. How long have you got (time in minutes) to use windows before the car just cuts off accessory power anyway - without you ever opening a door. Does it go on indefinitely?
Old 01-01-2013, 10:01 PM   #68
Sportsguy83
Drives: Limited BRZ
For the firs question, The power windows can be operated when the engine switch is in the “ON” position.
For the second question, The power windows can be operated for aproximately 45 seconds even after the push-button ignition switch is turned to “ACC” mode or turned off. They cannot, however, be operated once either door is opened.
Old 01-01-2013, 10:06 PM   #69
Sportsguy83
Drives: Limited BRZ
@scottmcphee
See wiring car diagrams attached.
Wouldn't it be possible to replace the relay that turns off the power to the windows for a relay that stays on all the time and that way tap turn works all the time? Just brainstorming, I have no idea if that is the way it works.
Old 01-02-2013, 12:00 AM   #70
developer
Drives: BRZ Limited
Will this be the one I am getting? Ordered a few days ago.
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
FINALLY My Turn! Gaiakai Scion FR-S / Toyota 86 GT86 General Forum 10 06-12-2012 12:52 AM
