Old 12-27-2012, 06:20 PM   #15
DookDookDGM
BR-Zizzle
DookDookDGM's Avatar
Drives: 2013 BR-Z, 1985 AE86, 1986 AE86
Send a message via AIM to DookDookDGM
Originally Posted by be6sti View Post
I'm not saying the car won't start in the cold. It just takes a bit more effort. Also I've noticed the car misses at high idle while cold.
mine has missed out on cold fast idle below 30F a handful of times. i try not to think much of it
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ
1986 Toyota Corolla GT-SR5
1985 Toyota Corolla SR5
DookDookDGM is offline   Reply With Quote
Old 12-30-2012, 08:09 AM   #16
be6sti
be6sti's Avatar
Drives: 2013 scion frs
Mine almost shoots steam rings XD
"Fuck it lets go!"
be6sti is offline   Reply With Quote
Old 12-31-2012, 09:25 AM   #17
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
My last car turned over much quicker, and the other vehicle I would drive had Dodge's "tip start" (turn the key and let go, and it cranks till the engine starts on it's own) so I often out of habit dont hold the key long enough, as this vehicle takes a few more turns to start than the average car (I expect the compression ratio has a huge part in that). What really stinks about that is, it seems to flood out when you do that, and its takes two or three times as long the second try.
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna
5AD Spoiler
205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only)
Rally Armor mudflaps in black with red logos
RazorHawk is offline   Reply With Quote
Old 12-31-2012, 10:22 AM   #18
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
I don't own an 86 (yet), but when I went to test drive one it didn't turn over on the first try. I turned the car all the way off, then to "on" for a bit, and then proceeded to turn it over. Worked like a charm.
Panda Grahams is offline   Reply With Quote
Old 01-02-2013, 10:33 AM   #19
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Yea in cold weather or really in any weather you should leave the key in the on position for a few seconds to prime that fuel pump.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 01-02-2013, 11:08 AM   #20
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Mine almost always turns over just fine in the cold (coldest I have tested is 30 F). I do sometimes have that rough running feeling just after ignition (similar to knock or piston slap), but it only lasts a few seconds and only in cold weather, so not worried about it. The oil is new and full btw.
Aren't subie boxer motors somewhat known for a bit of piston slap until it heats up?
tech4pdx is offline   Reply With Quote
Old 01-02-2013, 11:09 AM   #21
tech4pdx
Make love
tech4pdx's Avatar
I have a tune and it was this way before the tune too. (: After coming out of a Trans Am, I'm used to slap in the cold. Lol
Old 01-04-2013, 10:56 PM   #22
Maz
Drives: scion Fr-s
I have experienced this twice now but the second time i check all my settings. I drove from work 43 mile, the engine was completely warm by the end of the trip. It was 6:15 when i got home. Then left for a friends about 7:30,for a 6 mile drive. The temp. gauge was on the C, so it was slightly warm when i left. Then parked about 7:45 on top of snow covered lot. The area is extremely windy do to a lake across the street. Got Back in my car about 10:15. Tried to start it. It wouldn't turn over so i turn the key back and then repeated the process. the car took an abnormal amount of time to fire up. The car was in 1st, i had the A/C dial at a neutral temp, level 2 air, on both feet and dash, radio was on at a low volume, engine temp was completely cold, temp, out side was 34F Sorry for all the detail but i thought i mite help figure out why it does this. Do to the wind the engine mite have been cooled much faster, would that have an effect on start up?
Maz is offline   Reply With Quote
Old 01-05-2013, 09:45 AM   #23
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I've had this happen several times. No issues since I have been cautious of priming the fuel pump. Next time it happens I'm putting a multimeter to the battery
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 01-05-2013, 09:57 AM   #24
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
OP I had the same issue last week. Very rough start with a noticeable clanking noise for a couple seconds. I shut the car off at home and let it sit tried it again and no issues. It was very cold I think in the high 20s low 30s.
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 01-05-2013, 01:29 PM   #25
Nate219BRZ
Nate219BRZ's Avatar
Drives: Rip 04 golf gti rip 05 scion TC
I had rough starts twice now. It was like the car had no combustion
Nate219BRZ is offline   Reply With Quote
Old 01-05-2013, 09:49 PM   #26
srtblake
Chrysler/jeep/dodge tech
srtblake's Avatar
Drives: FR-S driver
I am having the same issue as well. I plan on going to scion sometime next week and I will discuss it with a writer/manager.
I dont see it being a battery issue. I bet a flash will become available to fix the issue.
False start member
srtblake is offline   Reply With Quote
The Following User Says Thank You to srtblake For This Useful Post:
_F-R-S_ (01-05-2013)
Old 01-05-2013, 11:49 PM   #27
Lonewolf
Lonewolf's Avatar
Drives: Moped
Turn key to ON, wait several seconds, crank. That is EXACTLY how to prime the fuel pump.
Yup. I have to do the same thing to my Civic when it sits overnight in really cold weather. If I prime, then it starts right up. If I don't, the car struggles or won't crank at first...
Old 02-26-2013, 10:07 PM   #28
SanDiegoFRS
SanDiegoFRS's Avatar
Drives: 86, Santa Fe, bicycle, sailboat
Originally Posted by Wolfking View Post
Whew! So I'm not the only one! I've had this happen twice. I pulled out of my garage and drove up the street less than a mile..."REDBOX return mission."
When I got back into my car (stereo on, heater set to LV.1) there was a hesitation. I was like wtf? I believe the outside temp. was 43F to 40F degrees. I'm not digging this at all. I sincerely hope this does not become a trend.
I drove 25miles to movie theater, two hours later cranked it and it struggled to turn over. Took me three times for it to turn over. It was 53 degrees. I don't have any mods and running 93octane. Only 1500 miles on it.
Hello, nice to meet you.
SanDiegoFRS is offline   Reply With Quote
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
sema rough nixeighty6 BRZ Photos, Videos, Wallpapers, Gallery Forum 0 11-01-2012 04:30 AM
Looks like CEL/Rough Idle is getting a lot more attention. wawro569 Scion FR-S / Toyota 86 GT86 General Forum 11 10-06-2012 12:24 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 10:28 PM
CEL and Rough Idle Issue Autonews.com article Yruyur Issues | Warranty | Recalls / TSB 11 10-04-2012 03:34 PM
