Old 12-27-2012, 03:01 PM   #71
ayau
Drives: Some rust bucket
anyone know the differences between getting the 16mm vs the 14mm camber bolt?
and what happens if you do decide to install the 16mm camber bolt on the bottom slot?
Old 12-27-2012, 03:42 PM   #72
Dezoris
Dezoris's Avatar
The 14mm won't fit properly.
Also whiteline only recommend using the bottom hole for race because the bottom bolt is more load bearing and experiences higher loads. So using a camber bolt there should only be used for those who track the car. As more attention is paid to re-tq bolts, re-doing alignments etc.
On a street car they know those bolts wont be checked for damage, slipping and proper torque.
The Following User Says Thank You to Dezoris For This Useful Post:
ayau (12-27-2012)
Old 12-27-2012, 03:49 PM   #73
ayau
according to this thread, the 14mm will only fit if you slot it through the bottom hole, but as you mentioned, the bottom hole is more load bearing and not recommended for street use.
it appears that the 14mm works, but it's just not the ideal bolt for the brz/frs when adding negative front camber, correct?
Old 12-27-2012, 03:53 PM   #74
ayau
are these the same 16mm camber bolts as whiteline's?
http://www.summitracing.com/parts/sps-81280
Old 12-27-2012, 04:18 PM   #75
Dezoris
Dezoris's Avatar
It looks like the same exact bolt. Even matches up to the Whiteline specs.
(For RSX, RSX Type S)
http://www.spcalignment.net/instruct...80-INS_WEB.pdf
Thats correct
Old 12-27-2012, 04:37 PM   #76
ayau
Thats correct
thanks. it's weird how the silver finished bolt has lower torque spec compared to the traditional zinc bolt.
Old 12-27-2012, 05:17 PM   #77
Dezoris
Dezoris's Avatar
Yeah unless the metal is softer on the silver finished bolt or it may be referring to the 14mm?
Old 12-27-2012, 05:25 PM   #78
ayau
i think it assumes all silver finished bolts are to be torqued to that specific torque spec.
see the instructions below are found on the 81280.
http://www.spcalignment.com/componen...AFrom&to=USATo
Old 12-27-2012, 06:37 PM   #79
Dezoris
Dezoris's Avatar
Interesting that they use two different materials.
Old 01-16-2013, 02:20 PM   #80
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
I asked this in another thread as well, but does anybody know if you can use the Subaru crash bolts in an FRS?
Thanks!!
Aznsky is offline   Reply With Quote
Old 01-16-2013, 02:39 PM   #81
OrbitalEllipses
Drives: Attitude
Thanks!!
Yes.
Old 01-16-2013, 02:40 PM   #82
celica73
Thanks!!
Same part. Different sticker on the baggie.
Old 05-04-2013, 03:18 AM   #83
altezza280t
altezza280t's Avatar
Drives: Ultramarine FR-S
picking up my car monday. was doing some research thanks for all the good info here! esp the part numbers
altezza280t is offline   Reply With Quote
Old 06-03-2013, 12:54 PM   #84
empower-auto
Kouki-Monster
empower-auto's Avatar
just a bump...
camber plates alone do not offer much range of adjustment on the front of this car. you will need plates and upper bolts (whiteline kca416) to get a proper range. maxed out, my HSD coilover camber plates only allowed about -1.5 camber at most when lowered.
the rear is also finnicky... I have Cusco LCA's and they don't quite allow for neutral camber when lowered 1.5 inches or more. I recommend shorter arms with more range or a secondary camber correcting method for the rear as well.
factory caster adjustment is also not very ideal
toe adjustment is a non issue with factory parts
hope this is helpful
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
CircuitJerk (07-19-2013)
Installed coilover; Too much camber in the back. trueno86power Suspension | Chassis | Brakes -- Sponsored by 949 Racing 69 04-11-2016 07:00 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 10:09 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
