Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 12-27-2012, 03:01 AM   #15
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Clear coating isn't going to fix the scratches unless you use a ton of it, and then you'll get runs and start this process all over again.
If you want the lights to be stock color and scratch free, you'll have to sand them down and polish them. I wouldn't recommend a machine for this. It'll take a while, but do it by hand. It's real easy to mess things up with a machine.
If you're going to do the spray tint over them again, you may still want to sand them down a bit. Are you taking about individual deep scratches or are you talking about a general dull appearance?
-Justin
Justin.b is offline   Reply With Quote
Old 12-27-2012, 03:53 AM   #16
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
-Justin
a general dull appearance. its only on one of the tail lights tho so i clear coated the one that's fine and it looks brand new now! just gotta fix up the dull one.. any suggestions?
Dispect is offline   Reply With Quote
Old 12-27-2012, 04:26 AM   #17
Justin.b
Try Meguiar's Plast-X polish on it. If there are any places that the polish doesn't clean up, you may need to wetsand them and then polish. I'd try to stick to the polish if possible.
Why did you spray clear on your other tail light? Stop spraying things on your tail lights.
-Justin
Old 12-27-2012, 05:14 AM   #18
Dispect
Dispect's Avatar
-Justin
so its glossy?? LOL okayyy
Old 12-27-2012, 10:33 AM   #19
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Have you thought of just replacing them with some nice aftermarkets ?
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-27-2012, 11:56 AM   #20
chutrain
chutrain's Avatar
Drives: WRB BRZ
Make sure you clean off the gasoline fully with water. I would avoid using anything harmful like gas, paint thinner, stripper, etc. Plastics generally do not work well with these products, and may cause melting or warping of the plastics.
Start with something like 600 and work slowly. Some of the heavier stuff might require 400, and then slowly work your way up to the high grit papers. I think 1000 should clean things up and give it a nice finish to work on again. No need to polish or buff the taillight before painting. Hit it with a mild water/iso mix to clean off any residue.
Before you try this again, go get some scrap plastic that you can test with. Start with a very light coat. It may not cover everything, but that will be fine. Check the can and see if it requires it to be fully dry, or something like a 15 minute wait between coats. The second coat should be a light coat as well and should cover the majority of the uncovered spots from the first pass. The last coat, which should be the third or it may become too dark, should be a slightly heavier coat. This will cover everything evenly and give it a glossy look.
Remember that the paint should be sprayed in nice even strokes. Do not stop in the middle. Keep your distance, approximately 8-12 inches as instructed by the can. Following this should keep the problems you got to a minimum.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 12-27-2012, 08:08 PM   #21
Dispect
Dispect's Avatar
Got it. Ill try it later tonight and ill post pictures of it when I'm done. Thanks
Old 12-27-2012, 08:16 PM   #22
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
gas or goo gone will remove the VHT nightshade but you will have to use a headlight restore kit on your tails to get their shine back.
you can also do what chutrain with the wet sanding and that works really good
either way if you want the shine back to your tails you will deff have to polish them
doesnt look too bad tho. looks like you caked the VHT tho decent and pretty heavy coats from the look of it. I would never recommend more than 2 coats of VHT black
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 12-27-2012, 08:26 PM   #23
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
...Or hope for the best that your tails are leaking with condensation and get new ones via warranty!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-27-2012, 09:33 PM   #24
Dispect
Dispect's Avatar
Thought of that. But since its been intentionally tempered with, they wouldn't replace it
Old 12-27-2012, 11:31 PM   #25
DaJo
FT86Club Vancouver
DaJo's Avatar
Not necessarily! Mr.Jay tinted his and he got them replaced under warranty because his were leaking. Lol
I think it depends on the dealerships...
2000 MR-S 5MT
2010-2012
Old 12-28-2012, 01:42 AM   #26
Dispect
Dispect's Avatar
OH nice! then i HOPE to god it leaks LOL. coz we used the same shitty dealership
Old 12-28-2012, 11:06 AM   #27
wparsons
wparsons's Avatar
Holy heavy coats of paint batman! VERY thin coats are your friend, especially with translucent paint.
To restore them just follow the advice about wet sanding in stages then polishing with a good plastic polish. They'll be as good as new with some time, just don't rush it at all.
flickr
Old 12-28-2012, 11:56 AM   #28
jshadeck
jshadeck's Avatar
I can fix these... Once i get my aftermarket ones, assuming i like them, ill have a set of stocks w optiguard for sale lol
jshadeck is offline   Reply With Quote
frs tails... frsguy707 Exterior Parts (Aero, Lighting, Etc.) 5 01-15-2013 11:30 AM
I need these tails Silp3 Cosmetic Modification (Interior/Exterior/Lighting) 7 12-01-2012 04:48 PM
WTB: Stock tails. wparsons Exterior Parts (Aero, Lighting, Etc.) 1 12-01-2012 12:31 AM
WTB: Stock tails. wparsons Canada Classifieds 0 11-21-2012 01:53 PM
Headlights and tails.. tintumz22 Cosmetic Modification (Interior/Exterior/Lighting) 12 11-11-2012 09:01 PM
