Old 12-26-2012, 09:11 PM   #15
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Yeah, I don't really understand the guys on here that take the time to put the VSC into sport mode when they're on the way to the grocery just tooling around town. What possible "fun" is that enabling on city streets with traffic, stoplights, etc. Don't drive like a 16 y.o. in a civic with a fart can. Nobody likes those guys.
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Freeman (12-26-2012)
Old 12-26-2012, 09:35 PM   #16
sirhc
sirhc's Avatar
Drives: fr-s
im surprised just having it in sport broke your tires loose like that. Mine does not do that. sport mode does not turn off traction control it just makes it less intrusive. Maybe you gave it more gas then you thought, or hit some oil.
chris
sirhc is offline   Reply With Quote
Old 12-26-2012, 10:56 PM   #17
root
Drives: Raven FR-S
chris
Actually if I recall Sport mode Does turn off the traction control, but it does not turn off the VSC, puts it into a less intrusive mode. So if you're spinning the tires in a straight line it'll let you go crazy, but when it detects enough yaw then it'll start trying to limit things.
Haven't really experimented, I only did my first autocross run forgetting to turn it off and it was awful. I only had a chance to hit the traction control button as I left the line & remembered so VSC was on full.
root is offline   Reply With Quote
Old 12-26-2012, 11:04 PM   #18
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Sport mode essentially does nothing but let you hold the gear longer and turns overdrive off it does NOTHING absolutely nothing to stability and traction control. They're are the two switches on the center console begin the shifter vsc sport lets you break the car slightly loose while still allowing the computer to control power to the wheels to also break the car loose you need to just push the traction button. If you hold the traction control button down for 5 seconds as well as pushing the vsc you will kill any stability and traction control in the car. Although it doesn't totally kill the traction it'll let you get the car sideways nicely and keep it a very fun predictable car
tuckdaddy is offline   Reply With Quote
Old 12-26-2012, 11:07 PM   #19
fistpoint
Drives: Supercharged Golf Cart
Were you under the impression that the nanny aid known as Traction Control completely eliminated spinning out? The sooner you learn that isn't the case, the better off you will be. Anti-lock brakes also aren't 100%...never put full faith in automobile gadgets.
fistpoint is offline   Reply With Quote
The Following 2 Users Say Thank You to fistpoint For This Useful Post:
CircuitJerk (12-26-2012), tuckdaddy (12-27-2012)
Old 12-27-2012, 12:22 AM   #20
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Ill second that!
Old 12-27-2012, 01:28 AM   #21
root
Drives: Raven FR-S
Sorry, I meant VSC Sport mode, I have a manual so don't have the tranny sport mode.
To turn off all traction & stabilitty, hold down just the traction control button for about 3 sec. no need the VSC sport button. VSC is really frustrating when you're expecting things to happen and it intervenes.
Old 12-27-2012, 01:37 AM   #22
tuckdaddy
Because Racecar
tuckdaddy's Avatar
No worries just clarifying I kinda figured you may have meant that haha just had to make sure! Vsc is very frustrating when it decides I shouldn't have fun here or there.. Needless to say since the test drive the nannies have been killed unless the roads are wet even then I don't drive like an asshat
The Following User Says Thank You to tuckdaddy For This Useful Post:
kidgogeta (12-27-2012)
Old 12-27-2012, 02:23 AM   #23
Dezoris
Dezoris's Avatar
I spin my car using pedals. I let go of wheel hurt my hands, dealership knows it.
Old 12-27-2012, 05:43 AM   #24
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
I have the rear twitch sometimes. i always half expect it tho. Its my first rwd car so im learning when to apply power and what not. pretty fun so far, except when it snows
mrlewistan is offline   Reply With Quote
Old 12-28-2012, 02:06 AM   #25
g0lden
Drives: 2013 Scion FR-S Argento
This happens when I do it on purpose. Make sure you know the dangers of a RWD car, especially in the rain. The rear can kick out so fast...
g0lden is offline   Reply With Quote
Old 12-28-2012, 02:43 AM   #26
Kensurs
Kensurs's Avatar
Drives: Raven FR-S 6MT
This thread is hilarious.
Kensurs is offline   Reply With Quote
Old 12-28-2012, 02:55 AM   #27
Alang
Alang's Avatar
Drives: 2013 Toyota 86 2.0 Std.
[ame="http://www.youtube.com/watch?v=j8qggahGNH0"]Toyota 86 Traction Control Demonstration [SKIDPAD] - YouTube[/ame]
Find a parKing lot or track and learn the car.
Adding power makes you faster on the straights, subtracting weight makes you faster everywhere - Colin Chapman
Alang is offline   Reply With Quote
The Following User Says Thank You to Alang For This Useful Post:
Ocala FR-S (12-28-2012)
Old 12-28-2012, 03:07 AM   #28
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Ill second that!
1st Oil Change Experience, Observations & a Surprise Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 100 09-14-2015 09:23 PM
Extra wiring (and a Usb surprise) twincamRob Electronics | Audio | NAV | Infotainment 34 01-08-2014 09:25 PM
Surprise! Your car is here! raul Scion FR-S / Toyota 86 GT86 General Forum 12 08-24-2012 09:24 PM
Surprise from the dealer in the mail! Pat1usmc BRZ First-Gen (2012+) — General Topics 102 03-11-2012 02:35 PM
