Old 12-26-2012, 12:27 PM   #15
makab
makab's Avatar
Drives: S2000/FR-S
Originally Posted by tuckdaddy View Post
I'd recommend taking a look at Adams polishes and maybe investing in a porter cable. I do all my own waxing polishing detailing and make a Saturday out of it. Needless to say I always had people walking up to the Tacoma I previously owned (2007 trd off road with rad red paint 4x4) and asking if it was brand new because the paint was in such good shape. My FR-S is the same way and the asphalt paint pops! Especially after a proper washing claying and wax. I wax maybe once a quarter and polish once every 6 months to once a year just depending on how hard I've been on the paint. Your buffing marks like previously stated will need to be polished out though gives Adams polishes a look
polish every 6 months? you are not worried about removing the clear coat after couple of years?
makab is offline   Reply With Quote
Old 12-26-2012, 12:28 PM   #16
makab
makab's Avatar
Drives: S2000/FR-S
Originally Posted by Missourifornian View Post
http://www.ft86club.com/forums/showthread.php?t=25018
Watch some of this guy's videos...He's probably a little too good to have the same results in your driveway but he gives good tips throughout all of his videos. Plus it's cool to see him detail really nice cars
thanks buddy, yeah there are a lot of videos about detailing. will watch it
Old 12-26-2012, 12:58 PM   #17
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I've only had my car for a couple weeks, cold and overall shitty weather. In between work, storms and darkness I managed to clay bar and at least get a coat of wax on it. The clay bar didn't pick up much of anything so there wasn't much grime collected during shipping. Plus there are protective films put on all the top surfaces during its trip from the factory.
The dealership, I assume, did however manage to get some pretty nice swirls and scuffs on the deck lid. I'm going to hold off till spring to do a good polish and overall paint detail. I may even color sand it. The factory paint really isn't so good. A lot of orange peel. Hoping there is a decent amount of clear on top of it.
Watch the videos, get a good buffer and pads and do it yourself. Its really hard to muck it up and something I enjoy doing.
FRSFirestorm is offline   Reply With Quote
Old 12-26-2012, 03:22 PM   #18
911fanatic
Drives: 2003 W8 Passat Wagen 4Motion
Originally Posted by mashal View Post
Take it to a Detailer who knows what they are doing , get a full exterior done with opti gaurd , you won't regret it .
Probably the best advice, although it can be safely resolved by a newbie with the right tools / supplies.
Originally Posted by ViCe86 View Post
If you want you can try this. It's amazing and usually does the job.
Any auto store should have it. It comes with an applicator pad and I use a soft polishing/microfiber cloth to wipe off the wax.
That is just a paint sealant ( no abrasives in it ) and unfortunately will do nothing to remove or even hide the swirls / holograms inflicted by the body shop.
Originally Posted by makab View Post
I think I need a polishing compound to permanently remove the holograms. Waxing only fills up the light scratches and will go away after couple of wash.
I may be wrong
Compounds and polishes are two totally different products. Polishes for the most part will remove swirls and light scratches inflicted during the wash process and can be followed up with the wax or sealant of your choice. Compounds typically are very aggressive for removing deeper defects and will need to be followed up with a polish to bring the gloss back to the paint before applying your wax or sealant. Wax itself will not hide anything but the lightest of swirls. Its not meant to do that job.
Originally Posted by CTB727 View Post
Wax alone will not remove the hologram/swirling. Unfortunately, holograms and swirling fall into the category where it will need to be polished out. And sadly, most auto parts stores don't really carry any good polish for removing stuff like that.
If you have a buffer (preferably dual action or an orbital) you'll need a light/fine polishing pad (Lake Country white pad for example) and a good, easy to use polish would be Meguiar's M205. Before you do any sort of buffing, you'll need to wash and clay the car.
1. Wash
2. Clay
3. Polish
4. Wax
Very good advice and easily accomplished with the right supplies and a bit of time.
yeah I thought so,
is the clay bar really necessary for a brand new car?
Not always, but for the little bit of time it takes to ensure the paint is clean, its worth it. All the FRS / BRZ I've done have been clean on the horizontal panels as they are covered in plastic but the vertical panels have been littered in rail dust from transporting.
You could polish your car twice a year with a white pad and M205 or Menz Power Finish to remove light swirls and you would never go through the clear. Both of those combos remove such a small amount of clear, its not even measurable with the electronic paint thickness gauge I have. Using a heavy cutting compound first and following up with a polish may result in removing 2-3 microns but thats it and that king of polishing should only be necessary once if you are maintaining it properly.
These cars don't come with much in the way of clear so I'd stay away from wetsanding and live with any defects that a product like Megs 105 won't remove. 2000 grit sandpaper won't remove much clear but once you are past that in aggressiveness, the clear is gonna come off in a hurry. You are correct in that using a DA polisher like the Griots or a Porter Cable is very safe and any enthusiast should own one in order to keep their car mint.
911fanatic is offline   Reply With Quote
Old 12-26-2012, 09:13 PM   #19
Mr. Sparkle
Mr. Sparkle's Avatar
Drives: Mr. Sparkle Detailing Wagon
took the words right out of my mouth
Mr. Sparkle is offline   Reply With Quote
Old 12-27-2012, 01:07 AM   #20
Greg Nichols
Paint Correction Guru
Greg Nichols's Avatar
Drives: F150 Platinum
That level of damage needs someone that really knows what is going on. to say it nicely is very hard, but they did way more damage than polishing for 2 years.....in otherwords they removed 2 years of the cars paint life.
How in the world can the word get out that true detailing cannot be done by just anyone.
I would take it back to the dealership and show them the damage, I would photograph it, and tell them you expect them to pay to have it professionally fixed. They will want to do it......they don't have the skill set. They like most other neo detailers will glaze it up with lots of oily products that will look great for about 6 washes, then bam they appear again.
Ken above outline perfectly all the points that needed to be made.
If you need some contacts for AZ detailers let me know, I don't know anyone off the top of my head, but have lots of connections in states.....just need to look them up.
Cheers,
GREG
ps. It may sound like I'm scolding you, I'm not, it just pisses me off that so much damage can be done so quickly.....fixing it will take 10x's as long to restore it.
Greg Nichols is offline   Reply With Quote
Old 12-27-2012, 11:18 AM   #21
makab
makab's Avatar
Drives: S2000/FR-S
Cheers,
GREG
no worries. thanks for the advice.
Old 12-27-2012, 07:51 PM   #22
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
It depends on the pads and composition of the compounds you use doing a 1 step twice a year won't remove clear coat like your thinking it will. Been doing this for quite awhile.
tuckdaddy is offline   Reply With Quote
Old 12-28-2012, 01:10 AM   #23
Thomas Dekany
Drives: vw
If you are in the Phoenix area, I have someone for you,
Thomas Dekany is offline   Reply With Quote
Old 12-28-2012, 02:17 AM   #24
makab
makab's Avatar
Drives: S2000/FR-S
Couple of people already mentioned www.WindowsAndWheels.com, so I will get the car inspected by them soon. thanks
Old 12-28-2012, 04:08 AM   #25
Thomas Dekany
Drives: vw
He is good enough to do the job.
Have you been pulled over yet with a new exhaust? ggpaul Engine, Exhaust, Transmission 39 10-18-2012 11:20 PM
Have you been pulled over yet? shire1976 AUSTRALIA 47 09-23-2012 06:44 AM
First BRZ to get pulled over in NJ!! engee NY / NJ / CT / PA 33 08-28-2012 12:05 PM
Just got pulled over Partial Stall BRZ First-Gen (2012+) — General Topics 6 06-22-2012 10:20 AM
Anyone here every pulled headlights apart? DarrenDriven Northwest 16 06-15-2012 05:58 PM
