#15 | |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
visibility from the halogens is quite remarkable. it cuts a perfect stream for a great distance. i forget to turn my High beams on sometimes. im going to find someone who can black out my stock headlights without effecting the brights, would be a lot cheaper than the JDM gt86 ones even though those are boss.
#16 | |
Drives: 2013 Scion FR-S 6AT, Asphalt
I was thinking of ordering the eurospec lights as well. If you order just the headlights, does it come with the bulbs ballasts and harness or do you have to order the one with the ecu and leveling sensor?
Thanks Quote:
#17 |
Drives: 2013 Boss 302 & 2013 FR-S
I'd love a set of the LHD lights. The price needs to come down though.
#18 |
I Void Warranties
Drives: Asphalt 86
Ah good question, thanks for bringing it up. I did not think of it. I have actually ordered mine now, so I can let you know when I receive them if no one else knows. I ordered the LHD lights without the ECU leveling sensor.
#19 |
Drives: White Lancer Evolution X
Yes mine came with bulbs and ballasts.
#20 |
I emailed Nigel-jdmparts and he responded "The headlight come with everything but the hid bulbs" and he believes they use the D4S bulbs.
#21 |
Drives: Many types of cars in R&D.
I think there is a correction that needs to be made where the Garage FRS says the High beams become LED. Actually there is a socket position changer that pulls the bulb back to high position built into the Japanese LED/HID Headlight and HID high beam can function fine with HID that's in there for the low beam.
The actuator is a simple 12V pin pair, and it can work just fine powering off the high beam leads on the FRS, as the low beam feed that powers the HID is still live in the USA models. The LED's should stay on Low voltage mode during the night as it is not directional. And when the resistor is bypassed on the USA socket the LED does work fine in the "high LED" mode at 3.3W as opposed to the "low LED" mode operating at 0.5w for night time, just enough to put the grid as decorative parking light strip. In short, the USA headlamp sockets and nearby resistor harness (to bypass it and feed 12V to DRL LED pin 12+) under the right front bumper area can supply all the feeds needed to power the Japanese LED/HID lamps as designed.
Moto Miwa
R&D Driving Engineer, Product Designs Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance. Last edited by Moto-P; 12-26-2012 at 07:17 AM. |
#22 |
Here's the pin identification if you anyone needs it.
Easiest and the most reliable way to wire the Japanese HID/LED lamps to Scion FRS halogen systems is to pull the pins out of both light assemblies and re-pin them into the proper socket location on the FRS lamp assembly connector. That way all connections are water-proof and original FRS sockets can be used without cutting most of them or tapping them at all, except one pin... One can easily find another single pin male/female connector for this... I used the aftermarket HID bulb 1 pin waterproof socket as it is commonly available. To remove the socket pins, you need to simply yank on the white plastic guide-locks to remove it, then finding the pin lock tabs for each one, move it up and pull gently on the wires from the back of the socket. Japanese HID/LED (GT-Limited) "socket" pins: #'s correspond to pin position in the 8 pin socket. 1. Not Used (Empty) 2. White - LED High (DRL 3.3W mode, 12V+ *must bypass the resistor on USA FRS to power this) 3. Green - LED Low (12V+ 0.5 w mode) 4. Black 12 Guage - LED Common GND 5. Red (12guage) - HID Ballast 12V + 6. Black (12 guage) - HID Ballast GND 7. Yellow - High Beam bulb position actuator 12+ 8. Blue - High Beam bulb position actuator GND On the USA Scion FRS 6 of the 7 necessary wires are all in the 6 pin socket, and it's a matter of re-pinning the sockets to proper locations. All of them except the pin needed for the DRL (LED-High 3.3w mode) are there. To wire the DRL properly, pull the DRL resistor located on the right front bumper just below the horn assembly. Tap into the live 12V side of the harness and leave the resistor unplugged so it does not feed the high beam actuator in the Japanese assembly. This is done because the USA FRS has the high beam bulb doing tha dual role of DRL and HIGH Beam, and Japanese assembly has LED High mode at 3.3 doing the DRL, and is separate from the actual HIGH beam which is done with HID main bulb with bulb position locator shifting the Low beam to high. Take the live side tapped wire to the LED high 12V wire on the Japanese headlight assembly so you get full 12V, and at the same time leave the socket off the resistor so it does not feed the High Beam actuator with attenuated voltage that normally powers the FRS high side halogen... (yes I said this twice to remind you)... On the Japanese headlamp, now you should have 6 wires left, after you connected the white to the DRL 12V circuit (with resistor bypassed) **I'd just simply remove this resistor altogether as you don't want a shop or dealer plugging it back in. The FRS only needs it so it can under-drive a halogen lamp on high beam at lower voltage during DRL. The Japanese system does not use it, as it has a LED array that is designed for this, separate from the HID high beam. Now you need to use this USA Scion FRS headlight "Harness side" custom socket diagram to put the pins in the right locations for the FRS socket to be used on the Japanese LED lamp to power the system correctly. USA Scion FRS lamp assembly socket pin (6 Pin connector) 1. Green (High beam) 12V ----> Blue bulb position actuator 12V+ 4. White (High beam) GND ---> Yellow bulb position actuator GND 3. Red - (Low beam) 12V------> Red HID Ballast 12V 2. Black - (low beam) GND-----> Black HID ballast GND 5. unused on FRS headlight but pre-wired on the car (parking GND)--------> 16guage Black LED Common GND 6. unused on FRS headlight but pre-wired on the car (parking 12V)--------->Green LED Low 0.5w mode 12V+ *7 not on the headlight socket, wired separately from the live side of the DRL resistor on the FRS DRL line. ------>White (LED High 3.3w mode 12V for DRL) * leave the resistor disconnected. Now you should be done. Check Operation: Parking lamp on = Low LED light up. Headlight on = HID Low beam + Low LED light up. High beam = HID Low and HIGH should now be lit with bulb relocated by actuator into the proper position inside the projector+ LOW LED lit. Flasher = HID should power with actuator in high beam mode, and upon releasing the High mode LED also flashes for a split second (latter if the headlight is on) DRL with all light switches in Off and with car in Reverse or Drive Gears, and parking brake down, engine on = DRL mode LED should be lit with full 5.5w really bright. There you have it. Properly working like a Japanese GT-Limited 86.
Moto Miwa
R&D Driving Engineer, Product Designs Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance. Last edited by Moto-P; 02-08-2013 at 05:15 PM. |
#23 |
I Void Warranties
Drives: Asphalt 86
Thank you very much @Moto-P and every one else for that matter. I will be sure to get pictures up as soon as I get the headlights and have them installed.
#24 |
Seems to be people wiring it wrong where DRL fires up the high beam on the HID and complaining it won't work.. That's because the High beam lead on the Japanese headlight merely changes the bulb position with an actuator and the signal merely triggers the actuator to refocus light in the projector lens, and does not fire another bulb.
Also, I would really advise NOT to wire the 3.3w High LED mode to the any light position used for night time, as it is pretty blinding to oncoming traffic as it is really bright and non-directional. You can't impress people, but merely really annoy them if they are coming at you at night. It's function is DAYTIME Running light... The color may be cool white, but what you'd do to oncoming traffic isn't cool at all. Right?
Moto Miwa
R&D Driving Engineer, Product Designs Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance. |
#25 | |
Now always work with killed wires and never with live wire. Good luck and have FUN!!
Moto Miwa
#26 | |
Drift Specialist
Drives: 180SX,GT86
looking forward for the pics
#27 | |
The japanese headlight is referenced here. Is the wiring the same for the eurospec headlights?
#28 |
KCCO From Canada
Drives: Asphalt FRS
| Tags |
| gt86, gt86 headlights, headlights, lhd |
| Plug N Play Super Bright LED Kits @ JWM- FREE SHIPPING! | JWMotoring | Interior Parts (Incl. Lighting) | 166 | 03-23-2014 08:08 PM |
| ECU Plug and Play | Mo707 | Engine, Exhaust, Transmission | 8 | 08-26-2012 11:21 AM |
| Xenon HID Conversion PLUG & PLAY | jarviz | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-01-2012 05:34 PM |
| HID Plug 'n Play Kit | JW89225 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 24 | 07-31-2012 12:17 AM |
| Which hid plug n play kit? | huma | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-20-2012 11:10 PM |
