Old 12-20-2012, 03:47 PM   #491
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Originally Posted by Hanakuso View Post
@JRitt I was pondering if its possible for current "Sprint" owners later down the road to upgrade to the "Endurance" kit for the integrated ducting and larger rotors. It seems the only the brackets and rotors are the only items that would need replacement
Yes, you are correct. If you wanted to move up to the bigger system, you could use your existing calipers and purchase new discs and brackets.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 12-20-2012, 03:51 PM   #492
OrbitalEllipses
Drives: Attitude
I want a 4-piston Formula kit with 2pc Sprint rotors. Or that caliper, painted so I can use it on the street. Please?
Ro_Ja (12-30-2012)
Old 12-20-2012, 04:04 PM   #493
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
And hat to disc mounting hardware Plus a few misc bolts.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-20-2012, 04:09 PM   #494
Hanakuso
Awesome! Do you have any rough estimate of what it would cost?
I don't think the hard anodized finish is "unfriendly" for the streets. Most cars come without painted calipers from factory.
Hanakuso is offline   Reply With Quote
Old 12-20-2012, 04:10 PM   #495
OrbitalEllipses
Drives: Attitude
Whatever it is, road salt affects the caliper and that's an issue for me.
Old 12-20-2012, 04:13 PM   #496
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Move?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-20-2012, 04:18 PM   #497
gmookher
correct me if I am wrong here, but the comparion was between an alum piston and a steel one
go back and look closely, its not the caliper thats risking corrosion, its the unsealed(no dust boot) piston thats vulnerable to salt exposure, hence the effort to protect aluminum, which does corrode.
its the piston thats being double anno'd its alumium. I didnt see the language refer to hard anno, which is a different process. the steel/stainless machined is nicer imho, as the piston is a moving part and annodization goes on only so thick, and can wear off
Old 12-20-2012, 04:29 PM   #498
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The Essex Comp kits use a stainless piston. Jeff suggested to someone else swapping back to OEM brakes in the winter. It's work to do so but worth saving any BBK from the additional corrosion caused by road salt.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-20-2012, 04:35 PM   #499
03Z33
drift
03Z33's Avatar
Maybe you could swap the calipers in the Sprint or Endurance kit for some of the AP CP-5200 Series road calipers? You'd have to make sure piston sizes, rotor sizes and pad thickness are all compatible. Not sure if that's something Essex can assist with, may not be worth the trouble for just a one-off kit...
03Z33 is offline   Reply With Quote
Old 12-30-2012, 10:25 AM   #500
Hanakuso
First time out with the Essex kit installed and had zero problems. It was nice seeing 3 out of 6 BRZ/FRS had the Essex AP Racing kit
Old 12-30-2012, 04:22 PM   #501
ayau
Drives: Some rust bucket
have you considered getting a cheap second car to drive in the winter?
i can't bear seeing all the road salt touching the BRZ.
Old 12-30-2012, 05:02 PM   #502
OrbitalEllipses
Drives: Attitude
Yes, but that's not something for this thread.
Old 01-02-2013, 04:08 PM   #503
Hanakuso
Hey Jeff or anyone that knows, is the AP Racing brake caliper temp strips a one time use product? Will only show the max temp or is it like a thermometer that can go up and down? I want to test my titanium shims to see if they actually help prevent heat transfer to the calipers.
This might be a stupid question but what is the recommended way to push the pistons in to install new/thicker pads? I noticed the C300 has a slimmer depth and when I went back to the Hawk HPS it was a pain to get them in.
Old 01-02-2013, 04:20 PM   #504
gmookher
anyone on this thread have the ENDURANCE kit? I have a question...
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
