Old 12-19-2012, 02:54 AM   #15
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Opposite question of above: How high can they go?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 12-19-2012, 05:04 AM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by crildz View Post
Stance coilovers are the best bang for buck coilover on the market currently
That's a bold statement with no facts to back it up
The Following 2 Users Say Thank You to JoeBoxer For This Useful Post:
2015firestormFRS (12-13-2014), Captain Snooze (11-18-2016)
Old 12-19-2012, 07:15 AM   #17
crildz
Drives: frs or brz
They ride smooth and are built very solid. They are a perfect all around coilovers since you can slam it or do autox or drift without having to adjust much of anything. Many of my frirnds have them and I have never heard anything bad except that the dampening adjustment can be that to reach
crildz is offline   Reply With Quote
Old 12-19-2012, 11:26 AM   #18
gmookher
Not hating them,
They look flimsy to me, but glad you like them.
SO long as you know what your buying, I dont know that youre gonna see any difference between tein, bc, buddy club, fortune, megan, stance, hsd. At that level, I often opt for a quality set of coils and a good set of inserts, like koni, but you dont get the drop you get with these.
RCE will only net you 20mm, and that works fine with a stock damper, any lower and you need to look at new shocks/struts. Some folks like too much drop./too much camber it seems.
These entry level coil overs get you a 'matched'(ehm) pair for cheap, so for DD use, I suppose they are fine. I have seen failures of chinese pot metal parts and cant say I trust them for the way I use my car. I dont know that I would run a BBK sticky rubber and get sideways on racetracks much with confidence.
The american made GC kit is MSRP $1400, with dampers from Koni, of Holland. I'm sure you can haggle it down for less. Are the stance branded worth a $400 savings to you? Not meaning to upset anybody, the OP did a great review and all. but the fact is for the same money I would just buy different parts, thats all my point is.
My only concern with stance is they are imported out of Illinois(Korea), they had offices out of Japan, moved to Korea for awhile if I remember correctly, then China, and now I think they are out of Korea again. HSD makes the coils in Korea now.AFAIK, I do dare to say 90% of the stuff made in china doesnt impress me. Sounds like you have tried KW, GC, Bilstein, and if this is what you like, cool. I'd have sooner seen you on the bottom level GC's or the RCE's. Curious to see how these hold up over time. I try and stick with that 10% stuff.
The Following User Says Thank You to gmookher For This Useful Post:
chulooz (01-01-2013)
Old 12-19-2012, 12:18 PM   #19
ill roller
Drives: BRZ/E30/IS300/LS400
I believe the highest they go is around stock height.
He shared his opinion on a forum, there's no laws on backing up all your statements on forums... I would agree with him though.
My only concern with stance is they are imported out of Illinois, they had offices out of Japan, moved to Korea for awhile if I remember correctly, then China, and now I think they are out of Korea again. HSD makes the coils in Korea now.AFAIK, I do dare to say 90% of the stuff made in china doesnt impress me. Sounds like you have tried KW, GC, Bilstein, and if this is what you like, cool. I'd have sooner seen you on the bottom level GC's or the RCE's. Curious to see how these hold up over time. I try and stick with that 10% stuff.
So you come in here and spout off all this nonsense just based on the way they look and no experience with the product?
Too much drop and too much camber? Who is to say what is too much? Am I breaking the law or something?
I've run ground control products before, and I will repeat what was said in my first post, I prefer these. You're concerned about the fact that they're imported out of illinois? I find that to be a good thing.
I'm already fully aware of how they'll hold up over time from my previous experiences with them. My IS300 Stance GR+ coilovers lasted 5 years (60,000 miles) before they needed a rebuild... In between I had a front lower bushing go bad, and it was warrantied and replaced with a revised one.
RISKY DEVIL // ILL PHOTOGRAHY
ill roller is offline   Reply With Quote
The Following 2 Users Say Thank You to ill roller For This Useful Post:
OmarGC (12-19-2012), RRnold (12-19-2012)
Old 12-19-2012, 12:44 PM   #20
gmookher
Thats awesome that your so confident of the product, very reassuring to buyers. I did a quick search and found a thread with three posters with the exact same issue. Hence my concern.
http://www.rx8club.com/wheels-tires-...inions-232656/
http://www.nissansilvia.com/forums/i...owtopic=417381
If it suits your needs usage and drving style, awesome. Ground control base kit is just sleeves and eibach springs, nothing really special. What makes the common "Ground Control" setup good is because it's paired with matched coils, matched Koni dampers which are going to be better than any of the asian made stuff. Just sayin,
Stance is alright for what it is. Not trying to start a debate.
Old 12-19-2012, 01:15 PM   #21
ill roller
No matter what suspension you buy, there's always a chance of problems, everyone should know that when they buy any coilovers, because I've had things break on every coilover I've owned (GC/Koni setup included), but as I said in the first post, no company has been as good with customer service as Stance... They stand behind their product, and if you have an issue, they get it fixed. If the issue turns out to be reoccurring, they revise their design to attempt to fix the problem.
I had GC/Koni's on my e30 drift car, and when the rears got worn out I switched to a stance rear coilover, and in no way regret it... The car is less bouncy than it was even when the GC's were in great shape, and just feels generally more stable and planted.
But yeah, you just go on blindly hating any asian made suspension.
Old 12-19-2012, 01:51 PM   #22
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
why does everyone just loooove to hate on everything on this forum?? this guy spent time to put out a helpful review for anyone looking into another coilover option. if you don't like it, gtfo. it's that simple. he's just trying to help out others here on the forum, which is the exact opposite as some of you. i appreciate the time you took to write this review as i am weighing coilover options as well
gabeg86 is offline   Reply With Quote
The Following 10 Users Say Thank You to gabeg86 For This Useful Post:
6-Shift (12-19-2012), AAI motorsports (12-26-2012), Baldoak (05-12-2015), giraffee (01-16-2013), ill roller (12-19-2012), lucchesi423 (08-16-2013), mwjcyber (07-23-2013), StayPuft209 (08-14-2016), Touge Factory (12-19-2012), _hollywood (01-01-2013)
Old 12-19-2012, 02:21 PM   #23
6-Shift
Señor Member
6-Shift's Avatar
Forgot to say thanks OP for the review!
The Following User Says Thank You to 6-Shift For This Useful Post:
Old 12-19-2012, 02:46 PM   #24
gmookher
I dont hate asian. I own plenty Apexi, Tokico, HKS, Greddy.
Really? You went and bought a whole new coilover? The whole idea of Koni Yellow and GC is that Koni is rebuildable. Last i checked it was like $120 per shock incl express return shipping, and bam, like new, with new damper internals, all you retain is the shaft and housing, unles yours are dented or bent which I think they replace at that flat rate as well if its NOT under warranty, like from crashing. They offer the same warranty on their bottom level as well as their top level offerings.
Koni has a lifetime warranty, so the cost of rebuild is a non issue.
When mine wear out, its both fast easy to get fresh valving done on them, same day, just go to somewhere like performanceshock.com. Rapid turn around, but then again with 80k miles on them and many many track days and some questionable driving by my wife who is still learning how to drive at the track, they are good as new, dont need a thing.
I will have to give stance a try sometime
Old 12-19-2012, 03:50 PM   #25
ill roller
Your experience with GC/Koni sounds not unlike my experiences with Stance. However I swapped out the GC/Konis because they were somehow both bouncy and too soft at the same time, even though the rates were pretty stiff. The fact that there was so much spring droop that I could jack the car up and take the spring off without unbolting anything just didn't seem ideal to me. And this was with a race proven e30 setup.
80k miles on a spring and shock combo doesn't sound unreasonable, but most coilover companies reccommend their coilovers be rebuilt every 20-30k miles, so I think my Stance coilovers did just fine.
Old 12-21-2012, 10:17 AM   #26
crildz
Drives: frs or brz
Not hating them,
HSD are awesome the euro drifters have proven it.
The Following User Says Thank You to crildz For This Useful Post:
ill roller (12-21-2012)
Old 12-23-2012, 09:27 AM   #27
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Thanks for the post OP. So is it safe to say that Stance are made in Japan or JDM? This is importance for me to clear up.
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 12-23-2012, 12:57 PM   #28
Justin91M
Justin91M's Avatar
Drives: Bagged RB8Six
I just ordered these coilovers yesterday A local shop I got them from is sponsored by stance and has these on all of their track drift cars.
My Bagged Rocket Bunny FRS!
2013 Asphalt FR-S MT.
IG: itsjay8six
Justin91M is offline   Reply With Quote
D2 RS/K-Sport Kontrol Pro Coilover Review DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 62 04-08-2016 01:32 PM
Stance Super Sport Coilovers FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2015 08:59 PM
►►Stance Super Sport Coilovers◄◄ Free Shipping - Photos and Video FT-86 SpeedFactory Brakes, Suspension, Chassis 43 01-31-2013 09:17 PM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 01:43 PM
