Old 10-10-2012, 01:14 AM   #1
Gen
Drives: Scion FR-S
rear suspension clunk
I have about 4500 miles on the car and have developed a slight clunk in the rear suspension. Anyone notice a similar issue?
Gen is offline   Reply With Quote
Old 10-10-2012, 03:22 PM   #2
akustique
Drives: nice
I hear the same clunk on mine. Is that normal?
akustique is offline   Reply With Quote
Old 10-10-2012, 07:04 PM   #3
Subforever
Drives: SWP BRZ
I have similar sound from rear left corner. First thing to check is the poorly installed jack back there. In my case it was loose far from snug anyway so the jack jump in his enclosure and hit the cardboard and make the pok pok
Subforever is offline   Reply With Quote
Old 12-18-2012, 04:31 PM   #4
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Guess I have the rear deck rattle, but there also seems to be a separate passenger-rear suspension clunking type of sounds when going over dots.
Anybody figure out the source of the suspension clunking, other than a loose jack on driver side?
Mine almost sounds like a spring or shock clunking/rattling.
brz7400 is offline   Reply With Quote
Old 12-18-2012, 04:49 PM   #5
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
What do you mean by "dots"?
I hear a single pop/knocking noise from the driver side rear when going over a speed bump or a drive way in an angle. It seems to be louder when going left first. It's easy to reproduce the noise in a parking lot with speed bumps. I'm suspecting it's the rear deck making this noise. But it could be described as suspension clunk noise. I'm pretty sure mine is not the suspension because I can reproduce this noise at 2 mph and when the rear tires are not going over any type of bumps. I was just wondering if yours might be the rear deck too.
Old 12-19-2012, 04:31 PM   #6
brz7400
brz7400's Avatar
Drives: Subaru BRZ
those yellow dome like things they put in parking lots to rattle the car when you go over them.
Old 12-19-2012, 06:03 PM   #7
Sigh-on-Rice
I see. You and I are hearing a different noise then. That won't be enough of a body flex to make the noise I'm hearing.
Old 12-19-2012, 09:09 PM   #8
Cameronghanson
Drives: n/a
I hear the same thing. I talked to some subie techs and they all said its because its an LSD. The LSD can be kind noisy especially when you are turning, under torque load, etc
Cameronghanson is offline   Reply With Quote
Old 12-19-2012, 09:28 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Cameronghanson View Post
I hear the same thing. I talked to some subie techs and they all said its because its an open diff. The open diff can be kind noisy especially when you are turning, under torque load, etc
They have an LSD not an open diff and the sound they make on slow tight turn is more like scrubbing judder if that makes sense. Not a clunk or nock.
1974 TA22 Celica
2013 86 GT
Old 12-22-2012, 11:30 AM   #10
Cameronghanson
Drives: n/a
LSD is what i meant. I had my car in the shop for 3 weeks trying to find this noise. Plus they were able to reproduce it again and again with the clunk. Guess if all else fails everyone can get all the aftermarket braces struts and suspension components and see if that fixes it.
Old 12-23-2012, 07:05 AM   #11
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
sounds like the effect of the torsen, if you were slightly lifting a wheel
dori. is offline   Reply With Quote
Old 12-23-2012, 07:57 AM   #12
#87
I usually post drunk
#87's Avatar
I get driver side clunk over certain bumps. It is definitely not the lsd. Ive just been living with it, don't notice any adverse effects from it. Would be interested if someone found the cause though.
#87 is offline   Reply With Quote
Old 12-23-2012, 08:25 AM   #13
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I've noticed a similar sound, but only in the morning while backing up from my driveway. I believe its what is described in the TSB sticky section (Popping Sound from Trunk / Rear Shelf Area). Did the fix desribed (lubing the panel joints, etc.) and it seemed to have worked.
Old 12-23-2012, 06:01 PM   #14
Sigh-on-Rice
Interesting to know that torsen makes a popping sound. But I can reproduce the noise while in neutral too.
Did you do both of the fixes? One is in the trunk and another one is from the rear seat removing the rear deck panel.
Rear end clunk when shifting? HuntingtonFRS Issues | Warranty | Recalls / TSB 26 09-30-2024 11:10 PM
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 02:56 PM
Potential design flaw with factory rear suspension? (WATER in boot area) WTF Suspension | Chassis | Brakes -- Sponsored by 949 Racing 243 07-26-2018 03:06 PM
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 05:49 PM
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 12:10 AM
