Old 12-15-2012, 05:09 PM   #4243
Visconti
Drives: 05 STi
Originally Posted by jdzumwalt View Post
I'm still trying to figure out how any sort of traction control can benefit drifting in anyway. When drifting you install a hard and heavy 2 way diff to keep the slip angles, adding traction control could could make it so you get less power to the tires = less smoke and drifting is all about angles and smoke
First off I'm not offering anything called drift control
But if I were I'd set it up like I explained.
With enough power when your drifting you could spin the car all the way around..
Removing some steering angle would reduce power and preventing the car from spinning around...
There's a few more things I could do, but don't have the time to screw around with that.
Visconti is offline
Old 12-15-2012, 08:20 PM   #4244
Yruyur
Yruyur's Avatar
Well it's going to be 16 degrees tonight so hopefully that's cold enough for you guys for a cold start test. Jesus these stock tires are stupid on the ice that is everywhere. Will have to switch to pump gas in the morning because the closest e85 gas station I can find near flagstaff is in Prescott.
Sent from my flux capacitor using Taptalk
Yruyur is offline
Old 12-15-2012, 08:21 PM   #4245
Yruyur
Yruyur's Avatar
Yruyur is offline
Old 12-15-2012, 09:49 PM   #4246
cuddefred
Drives: Black 86 GT
Yep - I have same and sent message to Joihn
I noticed the idle dip sure fluctuates while the blower is on. Previous tune seemed to hold steady at 800. Anyone else?
cuddefred is offline
Old 12-15-2012, 11:53 PM   #4247
xjohnx
Grip>Slip
xjohnx's Avatar
nice. can't wait for video!
xjohnx is offline
Old 12-16-2012, 01:00 AM   #4248
Visconti
Drives: 05 STi
Nothing has changed in the flash that would have any effect on idle control.. Like nothing in the last 10 updates.
John
Visconti is offline
Old 12-16-2012, 03:21 AM   #4249
cuddefred
Drives: Black 86 GT
Not sure what it can be then. It was fine on the old flash, rock solid at 800 but goes between 600 and 950 on this one. Will try to reflash it and leave it to idel for longer - see if that hepls at all. Other than that the flash is great.
John
Old 12-16-2012, 04:03 AM   #4250
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
John
Well, In this flash I am getting major Idle dip again. It was almost nonexistent previously.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
Old 12-16-2012, 05:02 AM   #4251
Yruyur
Yruyur's Avatar
Did you guys have the blower on during the first idle and first 50 miles.
Yruyur is offline
Old 12-16-2012, 05:50 AM   #4252
cuddefred
Drives: Black 86 GT
Yep, summer in Oz at the moment so quite warm today. Have reflashed it and off to try it again now. Will let you know how it goes.
Update - Back from decent drive after re-flashing and idle problem has disappeared. With or without A/C on the idle stayed right on 800 and the more I drive this version, the better it feels. Great job John.
Old 12-16-2012, 08:25 AM   #4253
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I think your on the right path if anything was to be done for drifting it would be removing the nanny that kicks in during certain transitions.
I think now there is some sort of black box you can get that does it. Or I guess you can do some kind of dance, turn the car on, press the brake ect ect. It's posted somewhere else on how to remove the final TC that's built into the car.
I have a bit of drifting experience I have done several events with my 95 turbo 240sx I used to own.( Sold for this car) You don't want anything messing with wheel speed because this angle is controlled with the e brake while under power. The e brake kinda acts as your traction control but it's manual with the driver handing the modulation.
My 2 cents
Gregg
jdzumwalt is offline
Old 12-16-2012, 10:43 AM   #4254
Yruyur
Yruyur's Avatar
Getting ready for the cold start test...it just looks cold out there.
Yruyur is offline
Old 12-16-2012, 10:52 AM   #4255
Yruyur
Yruyur's Avatar
Should I turn the key and keep it turned. I think the starter will cut out automatically right? That way I can guarantee I have the key turned long enough.
Yruyur is offline
Old 12-16-2012, 10:55 AM   #4256
Visconti
Drives: 05 STi
Umm no
Just start it..
Actually, email me so I can send you a quick update before you start the car
Visconti is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
