Old 12-14-2012, 10:49 PM   #4229
Yruyur
Yruyur's Avatar
On one of the pump gas and on one of the e85, no autoblip
Sent from my flux capacitor using Taptalk
Yruyur is offline
Old 12-15-2012, 07:58 AM   #4230
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
6 Speed USA & Europe Tunes or pump & e85 are all finished.
Working on Automatic updates.
-John
Is Australian tune different from those?
Blighty is offline
Old 12-15-2012, 08:19 AM   #4231
Visconti
Drives: 05 STi
Same
Visconti is offline
Old 12-15-2012, 08:57 AM   #4232
Blighty
Same
Thanks john. I might hold off till you release the new kit+tune, so don't worry about the purchase links for now.
Blighty is offline
Old 12-15-2012, 12:28 PM   #4233
Yruyur
Yruyur's Avatar
I noticed the idle dip sure fluctuates while the blower is on. Previous tune seemed to hold steady at 800. Anyone else?
Yruyur is offline
Old 12-15-2012, 12:29 PM   #4234
xjohnx
Grip>Slip
xjohnx's Avatar
@Yruyur - how was your cold start this am?
xjohnx is offline
Old 12-15-2012, 12:55 PM   #4235
Yruyur
Yruyur's Avatar
Just did one. One stall but not sure if I had the damn key turned long enough. If you know you are testing one thing I think it makes you question what you are doing. Of course I didn't do video thinking the logs were more important. Turns out videos are better. I'll try and get another one. I'm heading up north so gotta plan to see if they have e85 up there. I know it's a lot colder.
Does anyone else have e85 they can help john out. The more the better I think.
Yruyur is offline
Old 12-15-2012, 01:02 PM   #4236
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I'm running the rest of my pump gas out so I can load the E85 map. Will be sure to log/video some cold starts.
cobrabyte is offline
Old 12-15-2012, 02:17 PM   #4237
Yruyur
Yruyur's Avatar
I'm heading up north now. It's snowing up there.
Yruyur is offline
Old 12-15-2012, 02:29 PM   #4238
Visconti
Drives: 05 STi
Try out the RaceRom Traction Control !
Visconti is offline
Old 12-15-2012, 02:31 PM   #4239
xjohnx
Grip>Slip
xjohnx's Avatar
How does the e85 racerom drift control differ from racerom traction control?
xjohnx is offline
Old 12-15-2012, 03:09 PM   #4240
Visconti
Drives: 05 STi
EcuTek gives us empty custom maps that we can do what ever we with.
A few months back EcuTek started working on traction control stuff and wanted to call it drift control.
At the time the custom mapping only worked via the difference of front and rear wheel speeds.. There's nothing drift about that.
Since then I've spent a considerable amount of time improving on their idea.
My latest RaceRom Traction control is variable by steer wheel angle.
The way I set it up is NOT drift friendly, in fact the more steering angle you give it the more the traction control works.
If someone wants to go drifting i could change the settings to allow more wheel slip when the steering wheel had more of a angle - then maybe I could call that RaceRom Drift Control. Still think that name over sells what I'm trying to do.
-John
Visconti is offline
Old 12-15-2012, 04:09 PM   #4241
Opposed
Drives: 2013 Asphalt FR-S
Originally Posted by whtchocla7e View Post
Any before/after tune dyno charts for pump gas out there?
Click my username and find some of my posts. I have posted up before and after dyno's in several threads on here.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 12-15-2012, 05:05 PM   #4242
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
-John
I'm still trying to figure out how any sort of traction control can benefit drifting in anyway. When drifting you install a hard and heavy 2 way diff to keep the slip angles, adding traction control could could make it so you get less power to the tires = less smoke and drifting is all about angles and smoke
jdzumwalt is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
