Old 11-28-2012, 02:14 AM   #43
goke186
Originally Posted by SubieNate View Post
I've read a number of negative things about Wilwood on some BMW M car forums. What do you guys think? Problems with caliper flex etc. are the main complaints.
Most there recommended Stoptech if you can't spring for an AP, Alcon, or Brembo kit.
Nathan
A friend of mine had Willwood BBK on his tC and the brake lines were too short (by a small amount not noticable by the naked eye) but they ended up stretching and breaking while he was driving.
He contacted Willwood and was given the run around and told him he would have to buy new lines and that the ones he was given were correct for his car, they refused to admit that they were too short.
Other than that one instance I haven't really heard many negative things about Willwood. Just my $.02 i guess
FIVE AXIS DESIGN http://www.fivead.net (FIVE:AD Edition Ultramarine FR-S)
VTR http://vtrweb.com/ (Reccomended Pacific NW Shop!) [CLOSED]
AVO Turbo http://www.avoturboworld.com (Great Products for a Great Price!)
goke186 is offline   Reply With Quote
Old 12-14-2012, 09:17 PM   #44
Snake
Drives: ADM Toyota 86 GT
http://www.wilwood.com/BrakeKits/Bra...t%20STI&whl=15
I wonder if these would fit under the 16" ADM GT and JDM G spec wheels?
Snake is offline   Reply With Quote
Old 12-14-2012, 10:19 PM   #45
mswhong
Drives: FT86
Originally Posted by LazyZed View Post
Anymore info on these BBK's? Leaning more towards these but need them to be priced right for us Aussie boys. By god we get gouged
amen to that..
mswhong is offline   Reply With Quote
Old 12-15-2012, 04:55 AM   #46
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Nathan
Their calipers aren't known for being stiff. A NASCAR/brembo brake friend of mine has seen them flex like mad during testing. :shrug: probably enough fr most people still though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-15-2012, 05:40 AM   #47
OrbitalEllipses
Drives: Attitude
Same story on Subaru forums and Nissan forums (years back).
Old 12-15-2012, 11:25 AM   #48
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by ironchef View Post
Read in many places that said to avoid rotors that have been drilled. Slotted seems to be ok, but drilled is not.
Is this true?
Drilled is fine. Is only a problem if you drill them yourselves. Look at Porsche brakes
I would never, ever track a car hard that has cross drilled rotors. Not after seeing one made by a reputable manufacturer completely fail (explode into pieces) on a 951 at Road Atlanta, sending the car and driver into the wall, and driver getting medivac'ed to the hospital, thankfully making a full recovery after. The rotors hadn't showed signs of cracking after checking them after each session. Streeting with CDR's may be fine but when temperatures increase at the track, all bets are off.
That said, I'll be interested in final pricing of the Wilwoods with slotted rotors.
Old 12-15-2012, 11:30 AM   #49
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ATL BRZ View Post
I would never, ever track a car hard that has cross drilled rotors. Not after seeing a set fail on a 951 at Road Atlanta, sending the car and driver into the wall, and driver getting medivac'ed to the hospital, thankfully making a full recovery after. The rotors hadn't showed signs of cracking after checking them after each session. Streeting with CDR's may be fine but when temperatures increase at the track, all bets are off.
This. Even Porsche rotors crack and they aren't drilled, most guys replace them after a single weekend due to cracking, at least at Sebring. The hard core P car guys either run blanks, slotted or j hooks if they are running iron discs.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-19-2012, 09:59 PM   #50
gmookher
any pricing data or ordering data or availability on these? anyone buy these yet?
Old 12-20-2012, 11:28 AM   #51
bpracer
Drives: Asphalt FR-S
I don't think they are out yet. There was a name at Willwood in this thread that you can contact.
To get an idea of price, just plug in a 2004 WRX, you can compare the pieces in that kit to the one in their FRS/BRZ press release and see that they are made up of the same major components. The older WRX kit likely would work with our cars with possibly needing to flip the caliper bleed screws. Maybe they changed a bracket or two, but on the whole it can't be too far off in pricing. You can also get prices for all the different components if you drill down on the webpage.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 12-21-2012, 05:20 PM   #52
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We're working on getting a set in here ASAP.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Slartibartfast (12-21-2012)
Old 12-29-2012, 06:47 PM   #53
bpracer
BRZ/FR-S brakes now on Willwood's webpage
$1700-$1800 per axle
http://www.wilwood.com/BrakeKits/Bra...ion=All&whl=17
Edit - Comparing old WRX kits and these new kits according to their website, the calipers are different. The FRS/BRZ kit uses a newer "forged" caliper and is also a radial mount not axial. If true, a radial mount would allow you to go to a larger diameter 14" rotor with just adding a .56" spacer on longer caliper bolts. They have a 14" rotor that uses the same hat bolt pattern as the 12.88" rotor in the kit. That would give you more front brake torque with no other change. Probably need 18" wheels though. It would give you something to play with if there was too much rear brake bias.
Asphalt FR-S
Ducati 848
Old 01-08-2013, 06:02 PM   #54
WilwoodDiscBrakes
Drives: 2013 Scion FRS
We produced an install video for this kit. You can check it out at
WilwoodDiscBrakes is offline   Reply With Quote
Old 01-08-2013, 06:50 PM   #55
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Could we PLEASE get weights on the components? Thx in advance...
GTB/ZR-1 is offline   Reply With Quote
Old 01-08-2013, 07:14 PM   #56
RYU
RYU's Avatar
Drives: really slow...
Posted a question about this brake kit here. Hope to hear back thanks.
http://www.ft86club.com/forums/showp...9&postcount=15
RYU is offline   Reply With Quote
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 08:14 PM
