Old 12-08-2012, 11:39 AM   #71
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Trashed675 View Post
For those of you looking for a "dimmer" light output, wire one of THESE in line to the LED strip. Its basically a dimmer that cuts power totally when turned all the way off so it doesn't drain your battery.
AFAIK dimmers dont work with regular LEDs. When you lower the power, you will get flickering then transitioning to off.
Old 12-08-2012, 11:42 AM   #72
wbradley
Sarcastic SOB
wbradley's Avatar
Im going to wire in red 12V strip LEDs. The biggest challenge will be how many LEDs will be needed for the desired softness for the light.
Old 12-08-2012, 01:36 PM   #73
koteman
koteman's Avatar
Drives: Scion frs
Yeah tgat dimmer wont work you need a pwm dimmer. Just get a dimmer for desired brightness or wire in a resistir if its to bright
Sent from my Galaxy S3
koteman is offline   Reply With Quote
Old 12-14-2012, 08:22 AM   #74
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
I just wanted to post and say thanks for all the people sharing their knowledge. For those hesitant about this mod it is very easy.
I ran mine from the footwells to the center console and spliced them into the 12v accessory wires. I even installed a toggle switch so they can be turned off. If anyone is interested I can take off my console and snap a few pictures of how it is done.
tbwoodlee is offline   Reply With Quote
Old 12-14-2012, 08:39 AM   #75
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by BigJyoungblood View Post
So i did the lights today, too dark to do a diy but it was easy. I pulled the plug out of the back of the cig lghter in the glove box and used 2 wire taps, white is positive black is negative, then rand a connecting wire behind the stereo deck to hide it and to power both sides, taped it up and voila!
How did you get the wire through the dash behind the stereo? It is tight as hell there and I am now at the point where Im considering running the wiring all the way AROUND the console (thats right to the back seat and back) so please help!
BTW you can avoid splicing anything if you have an old lighter power plug you can sacrifice and splice.
Old 12-14-2012, 09:15 AM   #76
koteman
koteman's Avatar
Drives: Scion frs
If you pull the dash apart there's plenty of room. I fit all this back there
The Following User Says Thank You to koteman For This Useful Post:
wbradley (12-14-2012)
Old 12-14-2012, 10:42 AM   #77
Derik210
That Army Guy
Derik210's Avatar
Drives: Firestorm FR-S MT
Here are mine. I got mine at autozone and just wired it to the stereo
Derik210 is offline   Reply With Quote
Old 12-14-2012, 02:56 PM   #78
Blake
Drives: Ravin Scion FR-S
I like the lights in the footwells and in the door cup holder as well!! Very cool. When I get mine installed I"m going to ask for them to do that. I guess I will need to buy more lights for that?
Blake is offline   Reply With Quote
Old 12-14-2012, 04:44 PM   #79
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
can someone please post the pictures of the actual wiring process..
Thats where I am most confused and no one seems to have posted those steps via picture
Thanks
zex is offline   Reply With Quote
The Following User Says Thank You to zex For This Useful Post:
Minovsky (02-27-2013)
Old 12-14-2012, 08:54 PM   #80
koteman
koteman's Avatar
Drives: Scion frs
Positive tap in fuse panel
The Following 2 Users Say Thank You to koteman For This Useful Post:
illicitstylz (05-30-2014), zex (12-29-2012)
Old 12-17-2012, 12:48 AM   #81
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
@koteman
Did you splice your cup holder lights into the available wires in the door, or run new wires for them?
Old 12-17-2012, 12:29 PM   #82
koteman
koteman's Avatar
Drives: Scion frs
I ran a new pos, and neg to the door so they r attached to the switch. I along with the speaker grill and door handle lights
tbwoodlee (12-18-2012)
Old 12-17-2012, 01:37 PM   #83
wbradley
Sarcastic SOB
wbradley's Avatar
Just did the install over the weekend for my FR-S and also for my xB.
Red light is a good choice as it will have little effect on night vision and it is generally a less intense light. Used flexible LED light strips approx 12" long.
Just watched a documentary about night shift workers and how an opthamologist had lights installed to expose the workers to blue light at night while working to control their circadian rhythm and specifically how/when their brains produce melatonin. Based on this I dont want to mess with my brain/hormones so the red seemed the right choice.
Anyway I also tapped power from the jack behind the glove box except I used an old lighter plug to "plug in" this apparatus so no wires were spliced or cut. Also, I avoided opening the entire dash and just routed the wires under/around the centre console to the driver side wheel well. It looks excellent, isnt too bright and I can cut the light strips shorter if I decide there are too many LEDs per side.
On the passenger side I simply stuck the strip under the lower edge of the glovebox door. It works fine when the glovebox is opened as well. On the driver side there was nowhere to stick it so I zip tied it to some under dash parts.
The xB doesnt have a hidden power jack so I spliced in BEHIND the jack below the shifter for a nice invisible job.
Old 12-29-2012, 08:49 PM   #84
VROOOM
S5:F Gunmetal / Staggered
Drives: WHITEOUT 2013 SCION FRS
@wbradley... Could you describe a bit more about using a "old lighter plug" instead of splicing? And, did you remove your glove compartment to get access to the "power jack"? Did you use the same 12V power source as KENTONIC? When you routed the wires to the driver-side... is the wire hidden behind the center console... the wire isn't visible is it? Any additional information would be great!!!
I want to install the same Red LED in my FRS. Where did you purchase your material (e.g. Red LEDs ... etc)?
THANKS!!!!
VROOOM is offline   Reply With Quote
Differences In Types of Headlights/Lighting Asphalt Cosmetic Modification (Interior/Exterior/Lighting) 7 02-21-2013 07:49 AM
HID_Powerhouse offers HID kits and LED lighting for your FR-S/BRZ KI_ZN6 CANADA 2 07-27-2012 05:13 PM
interior lighting? fistpoint Scion FR-S / Toyota 86 GT86 General Forum 2 05-09-2012 01:52 AM
Stupid girl 2 foot driving GenkiElite Off-Topic Lounge [WARNING: NO POLITICS] 31 07-23-2011 08:33 PM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 04:20 PM
