| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
#29 | |
The Answer
Drives: Mazda 2
#30 | |
Sarcastic SOB
Air speed= speed of aircraft through the air, which prevents stall. Not relative to the ground but relative to the air.
#31 | |
Sarcastic SOB
#32 | |
Site Moderator
Drives: Stuff
![]() You are focusing on WHEELSPEED which is the only thing the belt is really affecting. It's not preventing the prop from generating thrust which, unless the airframe is strapped to the stationary ground next to the belt, will move the airframe forward. The discussion on headwinds was just to show that WHEELSPEED is meaningless. Assuming zero wind, a plane travelling 100MPH on a belt will have an airspeed of 100MPH, a ground speed of 100MPH, and a wheelspeed of 200MPH. Your entire arguement boils down to this: The friction of the tires against the belt, combined with the wheels against the wheel bearing will exactly counteract the THRUST generated by the prop. That is the ONLY way the aircraft won't move forward.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#33 | |
Site Moderator
Drives: Stuff
The friction of the skids will be overcome, just not as violently.
-Dave
#34 |
You know you want it.
Drives: '13 FR-S
As far as the airplane it depends. Does the conveyor match the groundspeed, or the wheel speed? If the ground speed everything is fine and the plane takes of relatively normally.
If the conveyor matches the wheel speed then within nanoseconds the conveyor accelerates to ludicrous speed in an exponential attempt to constantly outpace the wheels ultimately causing the bearings to explode and unless the conveyor stops quickly the plane is flung rearwards at horrifying speed and spectators shriek "WHAT HAS SCIENCE DONE!!???!"
The Following User _________ Stay_Puft(09-13-2014) Says Thank You to MmmHamSandwich For This Useful Post: |
| The Following User Says Thank You to MmmHamSandwich For This Useful Post: | HunterGreene (12-12-2012) |
#35 | ||
Site Moderator
Drives: ichi 86 Project
Edit: I did some google and found this quote and pretty convincing to me. Quote:
#36 | |
Sarcastic SOB
In theory I am 100% sure I have the physics right. In the practical world due to the nature of wheel bearings low friction and treadmills low relative speed the plane can take off. I did see that episode of MB BTW. If you had a treadmill that was servo controlled for speed regulation and was capable of infinite speed the plane could not take off!
| The Following User Says Thank You to wbradley For This Useful Post: | ichitaka05 (12-11-2012) |
#37 | |
Sarcastic SOB
If a solid object is perfectly centered relative to its weight over the centre of the platter it will stay there if it is gently (not violently) accellerated up to speed. Why? If you accelerate to drastically then rotational acceleration > friction between object and platter. In other words you are exceeding the traction so it will break loose. Now, that isnot to say that while it rotates at massive speed there wouldnt be parts flying off in all directions until the thing rips apart. A perfectly balance metal ball with decent initial stick to the bottom of the platter should be able to be rotated to huge velocity in a vacuum if it is not accelerated violently. Again, if tracton wasnt a concern then you could accelerate violently. If centripedal force wasnt a concern, we'd use a ball of Jello. The difference here is some people are answering based on a theoretical situation whereas others are basing it on a practical situation. Incidently, in that case both are right but in this case I thought it was a theoretical question not a practical Myth Busters experiment.
#38 | |
Site Moderator
Drives: Stuff
Your treadmill would likely have to be spinning at tens of thousands of times faster than the speed of the plane. The tires would shred. The riddle is that if the plane is generating thrust to travel at 100MPH, and the belt is going 100MPH the other way, will it take off? And the answer is yes, because the friction in question is nothing compared to the thrust created. You can easily test this with an RC plane. Put a treadmill at the highest speed and it takes almost no throttle to move the plane forward on it, full throttle and it smashes into the treadmill That same minor throttle to overcome the wheel friction would basically be moving on solid ground too.So let's say a Cessna 172 turning 1,500RPM tevels (on solid ground) 50MPH, on a -50MPH treadmill it might only go 49.5... :shrug:
-Dave
#39 | |
Drives: '13 GBS Subaru BRZ
![]() I can see where you might be able to generate resistance through the wheels to cancel out the thrust of the prop, but the usual version of this myth is the plane needs say 60 mph airspeed to take off and the the belt is going 60 mph in the oppisite direction. In that case the plane will still fly. Again Mythbusters did this.
#40 | |
Site Moderator
Drives: Stuff
Pretty sure a helicopter isn't 1) balanced in that direction and 2) not going to be all centered over the center of rotation. It probably would break apart first though.
-Dave
#41 | |
Sarcastic SOB
Nobody is wrong here, the experiment is well known. So are the theories of physics. Please just admit that in theory I am correct. You are correct in practice however. Somebody please change this thread from "Helicopter on a Turntable" to "Hotdog Down a Hallway" cuz were gettin nowhere fast here.
#42 | |
Site Moderator
Drives: Stuff
Yes, it's absolutely possible to generate enough resitance to prevent the airplane from moving. You could just bolt it to the ground too Both of those solutions are outside the point of the riddle and (I thought) the conversation.
-Dave
