| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
Helicopter on a turntable
![]() So will it take off if the turn table was spinning at the exact same speed as the blades in the opposite direction? |
Bad Driver
Drives: Whiteout fr-s
Yes the blades will still be cutting through the air producing lift no matter what the turn table is doing. Same debate as the airplane on a moving runway...
Drives: '13 GBS Subaru BRZ
I assume by oppisite direction you mean that the blades would remain stationary relative to the world and the fuselage would instead spin. In that case there would be no relative movement between the rotor and the surrounding air and no lift.
Of course the tail rotor and drag of the fuselage would probably cause havoc, but not flight.
Mr. Sarcasm
Yes. The movment of the blades is not what causes it to lift, but the actual air it pushes down causing it to lift.
Speaking of lift...
#5 | |
The helicopter's wheels (or skids) are not oriented to move with rotation so the helicopter fuselage will spin with the turntable. Fun with physics
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Blades will be stationary, and the body of the helicopter will rotate rapidly instead.
Secondary question: Will the load on the engine be less than or greater than the load experience in flight? |
DEEEERP
hmm...
#8 | |
Sarcastic SOB
The airplane will not lift if taking off on a conveyor either since the net airspeed is zero hence no laminar flow on the wings to cause lift. A guy in my office is a former Learjet pilot and I'll throw this at him when he's in. He s not certifiable now due to medical issues related to neurological surgery.
Should be considerably less since there should be no drag from the blades moving through the air. Just any mechanical load from the transmission, and resistance from the tail rotor.
#10 | |
Site Moderator
Drives: Stuff
The helicopter won't take off. Lift is in this case determined by the rotors speed against the air. So if we assume the turntable is spinning at the same 5,000RPM (easy number) as the rotor shaft, in the opposite direction then the rotor would not actually move through the air at all, instead the airframe would. Of course I could be missing the trick with the helocopter.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#11 | |
Sarcastic SOB
No way the airplane can lift. If the prop is providing thrust for the plane to move forward on a treadmill/conveyer in the exact opposite to the movement of the belt then the net airspeed is still zero. The plane is standing still relatyive to the air/ground. In other words since the plane is not moving forward relative to the ground (or air) then there cannot be sufficient airflow over the wings to generate lift. Try launching a kite while running on a treadmill.
#12 | |
Site Moderator
Drives: Stuff
If you launch a kite while running on a treadmill, you are correct, it won't work. But that's because your legs are your interface generating speed. Instead, strap a jet pack on and try it again, your legs no longer matter, the kite will fly. Of course you'll fly off the treadmill too lol Think of it this way instead.. A Car running 60MPH on a treadmill traveling 60MPH in the opposite direction has a groundspeed of zero. That's because the WHEELS which are ON the treadmill provide thrust. An airplane traveling 60MPH on a treadmill traveling 60MPH in the opposite direction has a groundspeed of 60MPH and a (useless to know) wheelspeed of 120MPH. That's because the PROP/TURBINE is providing thrust by moving AIR which is completely unaffected by the treadmill.
-Dave
#13 | |
What I find really funny is many experienced pilots don't understand this, and will insist the plane couldn't take off.
#14 |
Hail Magnet
Why has nobody mentioned Mythbusters yet?
(Because I'm a noob and I don't know how to post video) But Neutron is correct. The drive, or thrust forward is provided by the prop, not the wheels. /argument |
