Old 12-10-2012, 09:35 AM   #85
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
Originally Posted by XTR Performance View Post
Why not
-Chris
LOL.it's just not time, nor is there the funds. poopy.
VSGTS14 is offline   Reply With Quote
Old 12-10-2012, 09:50 AM   #86
XTR Performance
Drives: 2012 WW Evo X
Send a message via AIM to XTR Performance
haha alright man! Just let us know when you are ready. Hopefully we have a set in stock for you!
Thanks,
Chris
XTR Performance is offline   Reply With Quote
Old 12-10-2012, 12:01 PM   #87
ebphoto
Drives: FR-S, NA8, S13
Originally Posted by pcasso87 View Post
Thanks for the reply man, looks like i will have to go +45 since i dont want to run a spacer.
Originally Posted by D1cker View Post
I think the 17x9 +45 will have less brake clearance, I'm pretty sure it's the same wheel with just less material on the backing pad.
a +45 is going to have 10mm less pad with the same face.. from what im understanding.. which means you would definitely hit.
maybe an ugly convex face rpf1 would clear?
ebphoto is offline   Reply With Quote
Old 12-30-2012, 08:41 PM   #88
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
So I had a set of these dropped off on the 28th. I plan on running a 245/35/17 toyo r1r until it gets hot then switch to a 245/40/17 Rs3. Looking like the rce yellows springs and about -2 to -2.5 degree of camber. Currently on stock springs with -2 degree of camber with the whiteline bolts. I don't think there will be a issue but worried about it when the car is under load.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 01-27-2013, 09:04 PM   #89
whataboutbob
AutoX-10/10ths every run
I just picked up my 17x9 ET35 RPF1s from LSD Friday. Test fitted the wheel on the car tonight. Rear looks pretty good for clearance as the closest thing is the e-brake cable guide. The fronts I'm not sure about...see photo below. I'm planning on running 245/40R17 Z2s on these. What do you think?
Build thread:Here
Old 01-27-2013, 10:08 PM   #90
mad_sb
Drives: 2013 Asphalt FR-S
love the wheels, loath the stretch lol... at least put some 235's on those 9's lol
Old 01-27-2013, 11:02 PM   #91
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
they'll be fine, plenty of room... i am planning to put the +45s on the std struts, at least initially.
86•BRZ is offline   Reply With Quote
The Following User Says Thank You to 86•BRZ For This Useful Post:
whataboutbob (01-27-2013)
Old 01-30-2013, 12:57 AM   #92
MexByWheels
Drives: Gt86
Can you please put pics of your car once you done the installation. thanks man
MexByWheels is offline   Reply With Quote
Old 01-30-2013, 01:41 AM   #93
whataboutbob
For sure.
Build thread:Here
Old 01-30-2013, 10:35 PM   #94
MexByWheels
Drives: Gt86
For sure.
When-about-bob ? I have no patience.
Old 01-30-2013, 10:49 PM   #95
whataboutbob
I have very little as well. Unfortunately for the both of us the Z2s I chose won't be shipped from Tire Rack until mid-March.
Build thread:Here
Old 01-30-2013, 10:50 PM   #96
D1cker
Drives: B9 S4/ND2
^^^ They look like this with 245/40/17 : http://www.ft86club.com/forums/showp...3&postcount=73
D1cker is offline   Reply With Quote
Old 01-30-2013, 11:42 PM   #97
MexByWheels
Drives: Gt86
can ya foto chop them into black, matte please. Thank you sir
Old 01-31-2013, 11:44 AM   #98
TWMPerformance
Drives: Manual Transmission, All the Way!
Looks fantastic! Wheels, drop, everything!
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
