Old 10-18-2012, 09:02 PM   #71
stout90
Drives: 2013 FR-S 6MT~FireStorm
any more pics of this car? from straight on front and back
stout90 is offline   Reply With Quote
Old 10-25-2012, 03:29 PM   #72
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
car is now on KW V3s, dropped about 1.5"
hope you don't mind that I posted the pics you sent me D1cker
front fitment, now w/ Whiteline Com-C and OEM 14mm bolts
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 10-25-2012, 03:48 PM   #73
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Sent you a message about the clearance of the front caliper and you never answered. How much clearance do you think the front caliper has between it and the wheel? Reason im asking is because i want to get this offset but i have a ap bbk.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 10-25-2012, 03:50 PM   #74
XTR Performance
Drives: 2012 WW Evo X
Send a message via AIM to XTR Performance
From his pictures... it looks like you will need spacers up front
XTR Performance is offline   Reply With Quote
Old 10-25-2012, 03:53 PM   #75
track_warrior
Track Junkie
Yeah i know thats why im waiting on purchasing these . I really want that offset and width but i have to make sure it can fit. Hopefully someone volunteers to measure the essex wheel template. Im running 17x8 +45 rpf1's right now and they clear perfectly.
Old 10-25-2012, 04:17 PM   #76
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
^ if you look at pics of others w/ 17x9 +35, the front actually pokes out about 5mm w/ 0 camber, if you add -1.5 to -2 degrees, it sits flush w/ the fender
Old 10-25-2012, 10:17 PM   #77
D1cker
Drives: B9 S4/ND2
Hey man sorry I'm a lazy asshole!!
I did try the essex template against my spare wheel and it looks like it will just barely touch. With a 3mm spacer it would clear but I am not sure if the componets will flex under hard corning and make contact.
A 5mm spacer should be enough though!
D1cker is offline   Reply With Quote
Old 10-25-2012, 10:42 PM   #78
track_warrior
Track Junkie
Thanks for the reply man, looks like i will have to go +45 since i dont want to run a spacer.
Old 10-26-2012, 12:08 AM   #79
D1cker
Drives: B9 S4/ND2
I think the 17x9 +45 will have less brake clearance, I'm pretty sure it's the same wheel with just less material on the backing pad.
The Following User Says Thank You to D1cker For This Useful Post:
JoeBoxer (10-26-2012)
Old 12-08-2012, 04:27 PM   #80
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
this brake clearance issue is just if your running a big brake kit?..i think in STX you cant run a big brake right?..anyway im just about set on getting these RPF1s in 17x9+45 so it would be good to know
Gearhd79 is offline   Reply With Quote
Old 12-08-2012, 04:42 PM   #81
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
this is the exact setup i want. it's great track material!
VSGTS14 is offline   Reply With Quote
Old 12-08-2012, 04:53 PM   #82
XTR Performance
If you are really looking for this.. here you go
http://www.ft86club.com/forums/showthread.php?t=23662
-Chris
Old 12-08-2012, 04:54 PM   #83
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
i can't yet
Old 12-08-2012, 05:04 PM   #84
XTR Performance
i can't yet
Why not
-Chris
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
