Old 12-09-2012, 06:07 PM   #29
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Originally Posted by SherbFrs View Post
Can i get in touch with him to ask some question and share progress!
Thks for let me now that i'm not alone
I asked and no one had his number if I see him around again I'll tell him to get on and message you.
Old 12-09-2012, 06:38 PM   #30
FirestormFRS
Sounds like severe detonation to me. Can't be 100% without hearing it in person. Could be a fuel injector that isn't fully closing and allowing fuel to leak into the cylinder on the exhaust stroke.
Does sound terminal for the engine if they don't get it fixed before the piston explodes (if it is for sure detonation).
FirestormFRS is offline   Reply With Quote
Old 12-09-2012, 07:02 PM   #31
wbradley
Sarcastic SOB
wbradley's Avatar
Fuel getting to the intake and detonating. So, the intake valve must be staying open too long, no? I'm not a mechanic, just using logic. Somehow the fuel must be leaking in during the compression stroke.
Otherwise a fuel injector mis-timed or a leak in the valve maybe? There must be enough leak for hot gas to contact and ignite fuel vapour.
Aside from OBDII perhaps check compression to try and find offending cylinder and maybe check VVTi cam angles.
Old 12-09-2012, 07:35 PM   #32
encity5
encity5's Avatar
yikesssss. good luck man seriously.
encity5 is offline   Reply With Quote
Old 12-09-2012, 07:56 PM   #33
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Could be one of the direct injection injectors leaking fuel in, or a valve problem where it opens early/late, or an ignition problem where it sparks at the wrong time. Could be a lot of things but hopefully they can diagnose it before any permanent damage happens.
OP please make sure to keep us up to date with the result in case this is a factory screw up or an actual failure and in case anyone has future similar issues.
pheoxs is offline   Reply With Quote
Old 12-09-2012, 09:36 PM   #34
sirhc
sirhc's Avatar
Drives: fr-s
what kind of gas are you using?
sirhc is offline   Reply With Quote
Old 12-10-2012, 12:22 AM   #35
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
sounds like a timing issue
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 12-10-2012, 02:42 AM   #36
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Well if they don't want to service it under warranty- make sure you blow it up before your warranty expires... I wouldn't want to keep an engine thats gone through that much premature wear! Who knows how bad the heads look with all that detonation.
Ravenlokk is offline   Reply With Quote
Old 12-10-2012, 04:37 PM   #37
SherbFrs
I've got some news. The director finaly gave me a phone call after my call to another dealer of the region and my idiot complaint to Toyota Canada. He's kind of piss of about me because i he's thinking i'm not fair with them ...
Anyway they told me that it's not the exaust and it's not about the air comming into the engine. They tested a lot of electronic part to control the air flow and the injection system. So the toyota ingineer would probalby order to change the engine and ship the old one back to them for further investigation. Finaly after more then 2 weeks they think it's the engine
And to blame my lack of patience that seems that before my numerous complaint the owner told them that maybe they should pay my month for compensation. So now they are pushing it to me that i was not fair and maybe they will not pay my month cause i've called another dealer and toyota canada ... So we will see what happen really soon.
Thks guy for your support. Hope the best for me.
SherbFrs is offline   Reply With Quote
Old 12-10-2012, 05:01 PM   #38
Gums
Drives: SWP BRZ
Wow! I personally would wait until you have your new engine and see if they compensate you. If not phone/talk to "the owner" giving him the option to reconsider compensation. If he's not forthcoming, go straight to Toyota Canada.
Good luck.
Gums is offline   Reply With Quote
Old 12-10-2012, 06:47 PM   #39
whtchocla7e
Drives: 2013 FR-S Hot Lava
Don't let them make you out to be the bad guy.
They totally blew you off and it took a formal complaint for them to take action.
Tell them to shut the fuck the up and fix the car.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 12-14-2012, 01:49 AM   #40
SherbFrs
Some news after excellent compression and leak test. They tested the injector and the #1 is faulty. So tha't was causing the bakcfire intake.
Finaly after 3 weeks they checked the injector
Old 12-14-2012, 08:50 AM   #41
xjohnx
Grip>Slip
xjohnx's Avatar
Sounds like complete BS to me. I'd ask him if you need to call Toyota again inform them of his (and by proxy, the dealership's) thinly veiled threats.
Old 04-13-2013, 07:05 PM   #42
FirestormFRS
Glad you got it fixed.
backfire, engine, intake, problem
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
Backfire when shifting canu_50 Issues | Warranty | Recalls / TSB 39 09-27-2012 01:55 AM
intake whitefrs Engine, Exhaust, Transmission 1 08-29-2012 11:19 PM
