Old 12-08-2012, 01:53 PM   #1
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
hard shifting in sport mode AT
Hello all, I was accelerating onto the highway today in sport mode and had to let off of the pedal because another car was moving into my lane ahead of me, the transmission kicked kinda hard downshifting. Is this normal? I know in my mazda 3 it would do this if it was getting ready to go into a higher gear and you suddenly let off.
sofrsnsokleen is offline   Reply With Quote
Old 12-08-2012, 02:00 PM   #2
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Yeah I can manipulate the shifting with the throttle. It reminds me of the B&M kit I helped a friend put in his 454 c1500
Spartan65 is offline   Reply With Quote
Old 12-08-2012, 02:20 PM   #3
sofrsnsokleen
GEARS!!???
so it is normal???
Old 12-08-2012, 02:58 PM   #4
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
so it is normal???
Is it reproducible? One-off things are always abnormal, but because they only happen once, future occurrence doesn't matter.
This is how I use my brain.
b.e is offline   Reply With Quote
The Following User Says Thank You to b.e For This Useful Post:
whataboutbob (12-09-2012)
Old 12-08-2012, 03:28 PM   #5
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Ya couldn't put the pedal down harder and pass them, huh? Doesnt seem like anything too bad could have happened.
chulooz is offline   Reply With Quote
Old 12-08-2012, 04:46 PM   #6
Spartan65
Spartan65's Avatar
so it is normal???
Some times the car shift like a greased ape some times it just shift? I ordered the whiteline tranny bushing, I'll see if it changes it's current behavior.
Old 12-09-2012, 02:10 AM   #7
Craig
Craig's Avatar
Drives: Asphalt FRS
The trans shifts hard sometimes, I think we're all just hyperaware of whats going on with our cars. Any serious trans problems should throw a cel code (correct me if i'm wrong)
Craig is offline   Reply With Quote
Old 12-09-2012, 02:21 AM   #8
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
did you press the brake pedal? The car will auto blip in sport mode when braking to put you in the correct rpm range as you slow down
mechaghost is offline   Reply With Quote
Old 12-09-2012, 09:16 AM   #9
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
I have been noticing a similar, yet different problem with my FR-S AT.
If I hold the pedal at a certain spot any old spot, just hold it at the exact same on for a duration of time) I expect the gears to shift in a roughly time sequential manner, I.E 2 sec though first, 2.5 through second, 3 through third, 4 through 4th, etc.
What I find happening sometimes though, is that It shifts really randomly, eg 3 sec through first, 1.5 trough 2nd, 3 through third, 1 through 4th, etc. not any particular "standard sequence". I am not very familiar with how an AT works, but I would think that this is not normal. Remember also, I am holding the throttle at the exact same spot through all the gears, and it never does this near or at WOT, only at 1/4-3/4 throttle.
If I need a new thread on this, I can start it up, and sorry for jacking this one, but I saw an "odd shifting in AT" thread and thought it might be sufficiently related.
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna
5AD Spoiler
205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only)
Rally Armor mudflaps in black with red logos
RazorHawk is offline   Reply With Quote
Old 12-09-2012, 09:32 AM   #10
Tintiot
Tintiot
Drives: Raven FRS
I beleive is normal, Did it when i test drove the car, and now does it on my own.
Both in Acc and slowing down the sports mode makes hard shifts as you would if driving hard on a Manual.
hey just my 2 cents.
Dont know any better
Raven FRS AT Stock
Rebadged
Tintiot is offline   Reply With Quote
Old 12-09-2012, 10:29 AM   #11
chulooz
Registered you sir
chulooz's Avatar
Waaaaay to many variables to have your algorithm work like you expect it every time. What exactly is the problem though? Not shifting when you want it to, seems like you got the wrong transmission.
Old 12-12-2012, 11:13 AM   #12
Froylavin
Drives: GT86
This is the Dynamic Rev Matching system they have installed. Yes, it does hard down shifts and yea, its normal. What I noticed is it downshifts hard, when you're driving hard so that the car keeps up with you... as someone mentioned, like you would be doing when driving hard in a manual.
I love the system but I also don't know how it works exactly, but its definitely nothing to be worried at all. Its designed this way.
Froylavin is offline   Reply With Quote
The Following User Says Thank You to Froylavin For This Useful Post:
sofrsnsokleen (12-13-2012)
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 02:40 AM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
