#15 |
First 86
Drives: Whiteout MT FR-S
Yes and it's bothered me enough that I'm finally going to get on the ground and look at it. Has anyone had it fixed at the dealer yet? I'd rather avoid using bar tape, as my fellow cyclist above did
![]() Thanks Brett
Don't shop, adopt!
#16 |
Same here. Mine is pretty loose, but not sure how to remove, or tighten?
#18 |
Anyone?
#19 |
Drives: Blue FRS 6sp, 95 M3
It removes with two long Christmas type fasteners. One in the top one in the bottom. You could order two new ones, but short of that, there is no way to tighten. The dead pedal is molded into the carpet. It may be tough to replace.
An aftermarket pedal could be fit. It would require drilling the underlying metal bracket which is welded to the floor. |
#20 |
Drives: 2007 Altima 3.5 SE 6sp
I had this issue and the dealer found the problem. The deadpedal uses clips and mine were worn out after only 11k kms. If your deadpedal is making noise or feels loose have the dealer check it out!
#21 |
Drives: tezla
yeah i think the same thing happened to mine but im too lazy to bring it in now... ill have it changed out when im bored and feeling like it...
#22 |
Drives: 2014 DGM BRZ MT
If it's any consolation, my dead pedal pops too (BRZ) -- kind of an "oil-canning" sound.
I'm curious what's making the noise but I'm not sure I'm willing to ask the dealer to look into it during the first service. When dealers take apart the interior to any extent, bad things can happen... |
#23 |
Drives: 2013 Scion FR-S - Argento
I just noticed this last weekend! But its only if I step on it fairly hard, like picking my butt up off the seat to stretch and putting my weight on the dead pedal.
Hmmm, going to have to see if I have some bar tape around! |
#24 |
Drives: Scion FR-S
Yes especially with pressure at top part. Was going to take a look at it this weekend.
#25 |
Canadian FR-S Member
Drives: FR-S '10 Series'
Bump. Anyone find any fixes other than bar tape? Does ordering new christmas trees actually fix the issue?
#26 |
Drives: FRS
yes mine squeaks when i put my foot on it
#27 |
Drives: FRS
#28 |
Drives: tezla
| Found Loose wire...?? IDK what it is | rikdrt1 | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 06-10-2020 01:42 PM |
| Red stitching is coming loose. | Chip | Issues | Warranty | Recalls / TSB | 7 | 11-01-2012 11:02 AM |
| Fuel Lid Tight or Loose? | JiB | Issues | Warranty | Recalls / TSB | 18 | 09-20-2012 01:50 PM |
| FR-S Stock Carpet Mats - anyone else's doing this? | kramerica_industries | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 08-24-2012 12:29 AM |
| Dead pedal height | bqe-lie-fdr | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 02-25-2012 09:21 AM |
