Old 12-06-2012, 10:20 AM   #561
jadewbj
jadewbj's Avatar
Originally Posted by Carwhisperer View Post
Theres still no dyno forreal? TRD just released theirs.. and its not even available to the public in the spring.
jadewbj is offline
Old 12-06-2012, 10:21 AM   #562
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by gmookher View Post
you need an actual test car, with this running, to get a dyno chart
is there such a thing?
Originally Posted by mines13 View Post
Well flatline, I will leak this much... Our current version, compared to a certain kit's posted graph, at an equivalent peak boost pressure, we are making in the neighborhood of 20lb/ft of torque more between 3000 RPM and 4500 RPM. Between 4500 RPM and 5700 RPM the spread grows to 38lb/ft. Peak torque starts to taper just after 5700 RPM in a linear and smooth fashion, the spread drops to 25lb/ft until about 6500 RPM then smoothly down to 14lb/ft to red line. Below 3000 RPM it only torque delivery only gets worse for the other system, as it builds boost with the slope of RPM. Basically, this translates to between 180lb/ft and 200lb/ft of torque between 3000 RPM and 7200 RPM at a similar boost level, to the wheels. Peak torque on the twin screw occurs at 5000 RPM vs 6500 RPM on the other kit. The twin screw also matches the peak torque value of the other kit 3500 RPM sooner...
I am rounding the numbers down as we use a different dyno with a higher parasitic loss, potentially different weather conditions, altitude, etc. But the trend would be the same, so the spread would likely be larger on the same day, same dyno.
Keep in mind, neither of these kits are 100% polished and ready, components, calibration, etc. can change before final release. As mentioned previously, they have not being tested identically. I do not think the other kit is inferior, it is just different and designed for a different type of customer. Simply weigh the cost and attributes of all the offerings and decide what is right for you. There really is no kit that will be all things to all people, just what you feel will work best for you.
:happy0180:
Looks like it, i sure hope they wouldn't make the numbers up.
JoeBoxer is offline
Old 12-06-2012, 10:29 AM   #563
Cheddar
Saving them pennies...
^ all i see the tqr numbers.....no graph....and nothing about whp.
Cheddar is offline
Old 12-06-2012, 10:32 AM   #564
JoeBoxer
JoeBoxer's Avatar
still means there is one running with this kit, that's all i was clarifying.
JoeBoxer is offline
The Following User Says Thank You to JoeBoxer For This Useful Post:
mines13 (12-06-2012)
Old 12-06-2012, 10:35 AM   #565
Cheddar
Im sure who ever is developing the system has it. But they wont release any info.
but seeing as TRD superchargers go. I dont expect TRD to break the 250 crank HP barrier.
They like to keep it simple for techs to install with as little as possible parts to change and as much money as possible from your pocket.
Cheddar is offline
Old 12-06-2012, 10:37 AM   #566
swift996
swift996's Avatar
Sorry if I missed this, but is there a picture of the kit installed on a car?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 12-06-2012, 11:45 AM   #567
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Yes GM, to clear up your confusion we have two dedicated company owned test cars, one domestically and the other over seas. These exclude the two employee owned vehicles which if the owners choose to take advantage, can run the the final version of either kit just prior to release.
mines13 is offline
Old 12-06-2012, 11:47 AM   #568
JoeBoxer
JoeBoxer's Avatar
Yes GM, we have two dedicated company owned test cars, as well as another two employee owned vehicles.
So i guess a beta tester is out of the question...
JoeBoxer is offline
Old 12-06-2012, 11:59 AM   #569
2forme
Already asked... a month ago :-p
2forme is offline
Old 12-06-2012, 12:18 PM   #570
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
Pics or it never happened!
Two V8s, one turbo, 12 Wheels total.
Batman is offline
Old 12-06-2012, 12:26 PM   #571
2forme
Oh snap, Batman has spoken. Better supply those dynos!
2forme is offline
The Following User Says Thank You to 2forme For This Useful Post:
Batman (12-06-2012)
Old 12-06-2012, 12:28 PM   #572
Pete
Pete's Avatar
Drives: 22 BRZ
Originally Posted by 2forme View Post
Mines, would you be opposed to me adding these referenced figures to my graph for those who are more visually inclined? I won't label you or the product, just to be used for estimated reference purposes
Here is a totally unrelated chart with some random numbers I made up from no input in particular.
Pete is offline
The Following User Says Thank You to Pete For This Useful Post:
Ryephile (12-07-2012)
Old 12-06-2012, 12:37 PM   #573
2forme
You beat me to it LOL
2forme is offline
Old 12-06-2012, 12:58 PM   #574
mines13
mines13's Avatar
I have to say, that is pretty impressive based on what I have sitting on my desk right now.
mines13 is offline
The Following User Says Thank You to mines13 For This Useful Post:
1strwdcar (12-11-2012)
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 03:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 10:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 06:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 07:10 AM
